出租N9020B MXA 信号分析仪
东莞市塘厦国通电子仪器经营部
热线:13058577267肖生(微信同号)
电话;0769-87934782
地址:东莞市塘厦镇林村丹缇轩
提示:如果您找不到联系方式,请在浏览器上搜索一下:塘厦国通仪器肖康
频率 10 Hz 至 50 GHz
频率选件 3.6, 8.4, 13.6, 26.5, 32, 44, 50 GHz
最大分析带宽 160 MHz
带宽选件 25 MHz 标配,40、85、125、160 MHz
最大实时带宽 160 MHz
实时带宽选件 85, 125, 160 MHz
1 GHz 时的 DANL -172 dBm
1 GHz 时,10 kHz 频偏处的相位噪声 -114 dBc/Hz
1 GHz 时,30 kHz 频偏处的相位噪声 -114 dBc/Hz
1 GHz 时,1 MHz 频偏处的相位噪声 -136 dBc/Hz
总体幅度精度 ±0.23 dB
三阶截获(TOI),1 GHz 时 +20 dBm
1 GHz 时的最大三阶动态范围 116 dB
选件
Frequency range
N9020B-503 Frequency Range, 10 Hz to 3.6 GHz
N9020B-508 Frequency Range, 10 Hz to 8.4 GHz
N9020B-513 Frequency Range, 10 Hz to 13.6 GHz
N9020B-526 Frequency Range, 10 Hz to 26.5 GHz
N9020B-532 Frequency Range, 10 Hz to 32 GHz
N9020B-544 Frequency Range, 10 Hz to 44 GHz
N9020B-550 Frequency Range, 10 Hz to 50 GHz
Preamplifier
N9020B-P03 Preamplifier, 3.6 GHz
N9020B-P08 Preamplifier, 8.4 GHz
N9020B-P13 Preamplifier, 13.6 GHz
N9020B-P26 Preamplifier, 26.5 GHz
N9020B-P32 Preamplifier, 32 GHz
N9020B-P44 Preamplifier, 44 GHz
N9020B-P50 Preamplifier, 50 GHz
Bandwidth
N9020B-B1A Analysis Bandwidth, 125 MHz
N9020B-B1X Analysis Bandwidth, 160 Mhz
N9020B-B40 Analysis Bandwidth, 40 MHz
N9020B-B85 Analysis Bandwidth, 85 MHz
Performance Options
N9020B-FT2 Frequency Mask Trigger, Optimum Detection License
N9020B-MPB Microwave Preselector Bypass
N9020B-NF2 Noise Floor Extension
N9020B-PFR Precision Frequency Reference
N9020B-TDS Time Domain Scan
N9020B-DP2 Deep Capture Memory
N9020B-EA3 Electronic Attenuator, 3.6 GHz, Upgrade
N9020B-EDP Enhanced Display Package License
N9020B-EMC Basic EMC Functionality License
N9020B-FP2 Fast Power, Up To 40 MHz Bandwidth
N9020B-FT1 Frequency Mask Trigger, Basic Detection License
N9020B-RBE Resolution Bandwidth Extended
Baseband Inputs
N9020B-BBA I/Q Baseband Inputs, Analog
Calibration Options
N9020B-AMG Calibration + Uncertainties + Guardbanding (Accredited)
N9020B-A6J ANSI Z540-1-1994 Calibration
N9020B-UK6 Commercial Calibration Certificate with Test Data
Connection Options
N9020B-CR3 Connector, Wideband IF Output
N9020B-CRP Connector, Programmable Rear IF Output
N9020B-YAS Y-Axis Ouptut
External Mixing
N9020B-EXM External Mixing
Real time signal analysis
N9020B-RT1 Real-time analysis up to maximum available BW, basic detection
license
N9020B-RT2 Real-time analysis up to maximum available BW, optimum detection,
license
Portable Packaging
N9020B-PRC Portable Configuration
Security - PC features
N9020B-SF2 Security Features, Prohibit Saving Results
N9020B-SSD Additional Removable Solid State Drive
N9020B-SF1 Security Features, Exclude Launching Programs
Source Connectivity
N9020B-ESC External Source Control License
Application software
89601B - 89600 VSA 软件
