8519|4
95
运放的速度指标Slew rate和Rise time的区别? [复制链接]
手头有NE5532、NE5534;还有OP07、OP27、OP37。
做激光测距,现在需要一个能做成跟随器的高速运放。
看了一些手册发现Slew rate和Rise time这两个指标应该是反映运放速度的。但不确定具体应该看哪一个指标。
上图为NE5534的参数,SR为13V/us,也就是0到13V需要1us。但是上升时间确只有几十ns。哪一项反映速度?
上图为OP27的参数,只有SR,没有Slew rate!速度也太低了。
因为做激光测距,对运放的速度要求很高,1个ns的误差会造成距离出现30cm偏差。
现在需要一个高速运放做跟随器,不知道大家有没有什么高速运放芯片可以推荐的。
此帖出自模拟电子论坛
They are two different ways of looking at the same thing. Slew rate is a measure of how fast a signal is changing. How many volts it changes in a given period of time. Usually stated in volts per microsecond. Rise time tells you how long it takes to get from 10% of the peak to 90% of the peak and ignores the beginning and end of the signal. If you had a signal that went from 0 to 10 volts, the rise time would be how long it took to get from 1 to 9 volts. To use an automobile analogy: Slew rate would equal mph and rise tine would be the time it took to travel a certain distance. You can calculate one from the other. Both are related to the maximum frequency a device can reproduce. If the slew rate is too low it will not be able to reproduce the higher frequencies. This is rarely a limiting factor in audio devices although some feel that the higher the slew rate the better the device.  详情 回复 发表于 2017-11-5 18:04
384
1ns是15cm的偏差。。。基本都没有搞清楚怎么做。。。
此帖出自模拟电子论坛
激光功率有限 漫反射时 APD互阻放大信号幅度比较低 目前测试用的是直射的  详情 回复 发表于 2017-11-3 10:57
95
此帖出自模拟电子论坛
超级版主
都是反映速度的参数,但测试条件不同,也就是运放的工作状态不同。
此帖出自模拟电子论坛
473
此帖出自模拟电子论坛
