1456|0
3836
MSP430调PMW程序例程(C语言) [复制链接]
MSP430单片机调PMW程序:
#include"msp430G2553.h"
#define uint unsigned int
uint Fre,temp1=50;
void delay( int ms)
  int i;
  while(ms--)
  for(i=0;i<120;i++);
int main( void )
  // Stop watchdog timer to prevent time out reset
  WDTCTL = WDTPW + WDTHOLD;
  DCOCTL=CALDCO_16MHZ;BCSCTL1 = CALBC1_16MHZ;
  BCSCTL2 |=SELM_1+DIVM_2;
  P1DIR &=~BIT3;
  P1REN |=BIT3;
  P1OUT |=BIT3;
  P1IE  |=BIT3;
  P1IES |=BIT3;
  P1DIR |=BIT0+BIT6;
  P1OUT &=~BIT6;
  P1OUT |=BIT0;
  _EINT();
  while(1)
    P1OUT ^=(BIT0);
    delay(temp1);
#pragma vector=PORT1_VECTOR
__interrupt void PORTP13(void)
  uint temp,pushkey=0;
  pushkey=BIT3 & (~P1DIR);
  __delay_cycles(10000);
  temp=P1IN;
  if((~temp) & BIT3==pushkey)
     Fre++;
     temp1 =temp1+100;
     P1IFG &=~BIT3;
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
