是带7位数码管的模100计数器
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity top is
port(clk,rst:in std_logic;
digit1,digit2:out std_logic_vector(6 downto 0));
end top;
architecture Behavioral of top is
begin
process(clk,rst)
variable temp1,temp2:integer range 0 to 10;
begin
if(rst='1')then
temp1:=0;
temp2:=0;
elsif(clk'event and clk='1')then
temp1:=temp1+1;
if(temp1=10)then
temp1:=0;
temp2:=temp2+1;
if(temp2=10)then
temp2:=0;
end if;
end if;
end if;
case temp1 is
when 0 => digit1 <= "1111110";
when 1 => digit1 <= "0110000";
when 2 => digit1 <= "1101101";
when 3 => digit1 <= "1111001";
when 4 => digit1 <= "0110011";
when 5 => digit1 <= "1011011";
when 6 => digit1 <= "1011111";
when 7 => digit1 <= "1110000";
when 8 => digit1 <= "1111111";
when 9 => digit1 <= "1111011";
when others => null;
end case;
case temp2 is
when 0 => digit2 <= "1111110";
when 1 => digit2 <= "0110000";
when 2 => digit2 <= "1101101";
when 3 => digit2 <= "1111001";
when 4 => digit2 <= "0110011";
when 5 => digit2 <= "1011011";
when 6 => digit2 <= "1011111";
when 7 => digit2 <= "1110000";
when 8 => digit2 <= "1111111";
when 9 => digit2 <= "1111011";
end case;
end process;
end Behavioral;
总是有如下的警告
WARNING:HDLCompiler:1369 - "C:\Users\zm\counter\top.vhd" Line 11: Possible infinite loop; process does not have a wait statement
WARNING:Xst:737 - Found 1-bit latch for signal >. Latches may be generated from incomplete case or if statements. We do not recommend the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
library IEEE;
entity top is
port(
end top;
begin
process(clk,rst)
begin
if(rst='1')then
temp1:=0;
temp2:=0;
temp1:=temp1+1;
if(temp1=10)then
temp1:=0;
temp2:=temp2+1;
if(temp2=10)then
temp2:=0;
end if;
end if;
end if;
case temp1 is
end case;
end if;
case temp2 is
end case;
end if;
end process;
end Behavioral;复制代码
详情回复
发表于 2017-8-11 11:57
