685|0
28
SR360型号场效应管 [复制链接]
场效应晶体管(Field Effect Transistor缩写(FET))简称场效应管。主要有两种类型(junction
FET—JFET)和金属 - 氧化物半导体场效应管(metal-oxide semiconductor FET,简称MOS-FET)。
  与双极型晶体管相比,场效应管具有如下特点。
(1)场效应管是电压控制器件,它通过VGS(栅源电压)来控制ID(漏极电流);
(2)场效应管的控制输入端电流极小,因此它的输入电阻(107~1012Ω)很大。
(3)它是利用多数载流子导电,因此它的温度稳定性较好;
(4)它组成的放大电路的电压放大系数要小于三极管组成放大电路的电压放大系数;
(5)场效应管的抗辐射能力强;
(6)由于它不存在杂乱运动的电子扩散引起的散粒噪声,所以噪声低。
.  Plastic package has Underwriters Laboratory Flammability Classification 94V-0
.  Metal sliicon junction ,majority carriet conduction
. Guard ring for overcoltage protection
. Low power loss,high efficiency
. High current capability ,Low forward voltage drop
. High surge capability
. For use in low voltage ,high frequency inverters, free wheeling , and polarilty protection applications
. High temperature soldering guaranteed: 250/10 seconds at terminals, 0.375"(9.5mm)lead length, 5lbs.(2.3kg)tension
   MECHANICAL DATA
. Case: JEDEC DO-201AD molded plastic body
. Terminals: plated axial leads,solderable per MIL-STD-750,method 2026
. Polarity: coler band denotes cathode end
. Mounting Position: Any
. Weight: 0.041 ounce, 1.15 gram
