void init_adc(void)
//Set P1.0 as Ternary Module Function Input.
GPIO_setAsPeripheralModuleFunctionInputPin(
GPIO_PORT_P1,
GPIO_PIN0,
GPIO_TERNARY_MODULE_FUNCTION
PMM_unlockLPM5();
//Initialize the ADC12B Module
* Base address of ADC12B Module
* Use internal ADC12B bit as sample/hold signal to start conversion
* USE smclk as clock source
* Use default clock divider/pre-divider of 1
* Not use internal channel
ADC12_B_initParam initParam = {0};
initParam.sampleHoldSignalSourceSelect = ADC12_B_SAMPLEHOLDSOURCE_SC;
initParam.clockSourceSelect = ADC12_B_CLOCKSOURCE_SMCLK;
initParam.clockSourceDivider = ADC12_B_CLOCKDIVIDER_1;
initParam.clockSourcePredivider = ADC12_B_CLOCKPREDIVIDER__1;
initParam.internalChannelMap = ADC12_B_NOINTCH;
ADC12_B_init(ADC12_B_BASE, &initParam);
//Enable the ADC12B module
ADC12_B_enable(ADC12_B_BASE);
* For memory buffers 0-7 sample/hold for 4 clock cycles
* For memory buffers 8-15 sample/hold for 4 clock cycles (default)
* Disable Multiple Sampling
ADC12_B_setupSamplingTimer(ADC12_B_BASE,
ADC12_B_CYCLEHOLD_4_CYCLES,
ADC12_B_MULTIPLESAMPLESDISABLE);
//Configure Memory Buffer
* Base address of the ADC12B Module
* Configure memory buffer 0
* Map input A0 to memory buffer 0
* Vref+ = AVcc
* Vref- = VSS
* Memory buffer 0 is not the end of a sequence
ADC12_B_configureMemoryParam configureMemoryParam = {0};
configureMemoryParam.memoryBufferControlIndex = ADC12_B_MEMORY_0;
configureMemoryParam.inputSourceSelect = ADC12_B_INPUT_A0;
configureMemoryParam.refVoltageSourceSelect =
ADC12_B_VREFPOS_AVCC_VREFNEG_VSS;
configureMemoryParam.endOfSequence = ADC12_B_NOTENDOFSEQUENCE;
configureMemoryParam.windowComparatorSelect =
ADC12_B_WINDOW_COMPARATOR_DISABLE;
configureMemoryParam.differentialModeSelect =
ADC12_B_DIFFERENTIAL_MODE_DISABLE;
ADC12_B_configureMemory(ADC12_B_BASE, &configureMemoryParam);
