3284|5
msp430g2553测幅值和频率 [复制链接]
初学者,编的程序在下面,求大佬们看看为甚么我的程序幅值可以测量出来但是频率测不出来/*
#include "msp430g2553.h"
#include "user.h"
char data_display[10];
uint U_sample[20];
uint index=0;
float U1=0;
uint f=0;
uint num2=0;
uint period=0;
uint temp=0;
uint overfloat=0;
void GPIO_Init(void)
P1DIR &=~BIT2;
P1SEL |= BIT2;
P1REN |= BIT2;
P1DIR &=~BIT1;
P1SEL |= BIT1;
P1REN |= BIT1;
void BCS_Init(void)
if(CALBC1_8MHZ ==0xFF)
  while(1);
DCOCTL = 0;
BCSCTL1 = CALBC1_8MHZ;
DCOCTL = CALDCO_8MHZ;
BCSCTL2 |= DIVM_3;
__delay_cycles(100);
void Frequency(void)
TACTL = TASSEL_2 + MC_1 + TAIE + TACLR;        //SMCLK,Up to CCR0,Timer A counter clear
TACCTL1 = CM_1 + CCIS_0 + SCS + CAP + CCIE;        //Capture mode: 1 - pos. edge,Capture input select: 0 - CCIxA
if(period > 0)
  f = 1000000/period;
floatTochar(f,data_display,1);
StrDisplay(data_display,3,0,0);
void ADC_DY(void)
  ADC10CTL0 = SREF_1 + ADC10SHT_2 + ADC10ON + REFON + REF2_5V;            // ADC10ON, interrupt enabled
  ADC10CTL1=INCH_1;                                       // input A1
  ADC10AE0 |= 0x02;           // P1.1 ADC option select
  while(1)
   num2++;
   ADC10CTL0 |= ENC + ADC10SC;          // Sampling and conversion start
   U_sample[index] = ADC10MEM;
   index ++;
   if(index >= 20)
    index =  0;
    U1 = M_Filter(U_sample,20)*2.5/1023;
    U1 = U1*5;
    floatTochar(U1,data_display,2);
    StrDisplay(data_display,1,0,0);
   if(num2>40)
             num2=0;
             break;
void main(void)
WDTCTL = WDTPW +WDTHOLD;
BCS_Init();
GPIO_Init();
_EINT();
Lcd_Init();
Lcd_Clear();
StrDisplay("电压值:",0,0,0);
StrDisplay("频率:",2,0,0);
while(1)
  ADC_DY();
  Frequency();
#pragma vector = TIMER0_A1_VECTOR   //Timer_A中断向量
__interrupt void Timer_A(void)
switch (TA0IV)
case 2:
  temp++;
  if(temp == 1)
   overfloat = 0;
   TA0CTL = TACLR;
  if(temp == 2)
     period = CCR1;
     period = overfloat*65536 + period;
     temp = 0;
  break;
case 4:break;
case 10: overfloat++;break;              // TimerA溢出中断;
TAT感觉自己写的不是特别清楚但是真的尽力写了,希望有大神解答,感激不尽!!!!!
此帖出自单片机论坛
还没弄出来?  详情 回复 发表于 2017-5-2 15:23
4008
你先截一下period的值对不对
此帖出自单片机论坛
4008
uint 类型不对吧
此帖出自单片机论坛
unsigned int 不对吗?
此帖出自单片机论坛
4008
还没弄出来?
此帖出自单片机论坛
嗯嗯因为有事情就一直搁置了单片机还不在我这所以
此帖出自单片机论坛
