2608|4
求一个msp430f149程序 [复制链接]
首先进入LPM3低功耗模式,然后通过定时器中断跳出低功耗模式,然后开始ADC采样,当输入电压大于3.6V时,接通后面的开关电路,当低于3.6V时,继续进入LPM3模式,LPM3模式要远远大于ADC采样时间(2s和2ms)
//  MSP430FR59xx Demo - ADC12B, Using an External Reference // //  Description: This example shows how to use an external positive reference for //  the ADC12B. The external reference is applied to the VeREF+ pin. AVss is used //  for the negative reference. A single conversion is performed on channel A0. //  The conversion results are stored in ADC12BMEM0 and Test by applying a voltage //  to channel A0, then setting and running to a break point at the "_NOP()" //  instruction. To view the conversion results, open an SFR window in debugger //  and view the contents of ADC12BMEM0. //  NOTE: VeREF+ range: 1.4V (min) to AVCC (max) //        VeREF- range: 0V (min) to 1.2V (max) //        Differential ref voltage range: 1.4V(min) to AVCC(max) //                        (see datasheet for device specific information) // // //                MSP430FR5969 //             ------------------- //         /|\|                   | //          | |                   | //          --|RST                | //            |                   | //     Vin -->|P1.0/A0            | //            |                   | //     REF -->|P1.1/VREF+/VeREF+  | //            |                   |  详情 回复 发表于 2017-5-2 08:06
483
自己根据需求修改下低功耗模式的程序就好了啊
348
这个程序你只要看会定时器和ADC这两个功能的例程,你就会写的,自己琢磨琢磨
就是我怎么能够设置参考电压位3.6V
// MSP430FR59xx Demo - ADC12B, Using an External Reference // // Description: This example shows how to use an external positive reference for // the ADC12B. The external reference is applied to  详情 回复 发表于 2017-5-2 08:06
348
lxyerye 发表于 2017-4-29 22:16
就是我怎么能够设置参考电压位3.6V
//                MSP430FR5969
//          --|RST                |
