3182|3
67
流驱动函数的参数表是固定不能改变的吗? [复制链接]
RT
定义Len只是通用的做法  详情 回复 发表于 2009-8-20 12:16
DWORD GPIO_Write(DWORD dwData, LPCVOID pBuf, DWORD Len)
                 BYTE* pdatabuf;
                 BYTE  gpioNum;
                 BYTE  gpioState;
                 pdatabuf = (BYTE*)pBuf;
                 gpioNum = *pdatabuf++;
                 gpioState = *pdatabuf;
                 RETAILMSG(1,(TEXT("gpioNum  :  %d\r\n"),gpioNum));
                 RETAILMSG(1,(TEXT("gpioState  : %d\r\n"),gpioState));
                 if(gpioNum == 3 || gpioNum == 4 || gpioNum == 9)    //这里可以选择你要用的gpio口 GPIO0-31由寄存器GPDR0 GPSR0 GPCR0控制
                                                         //GPIO32-63 由GPDR1...控制 GPIO64-95由GPDR2...控制
                                 if(gpioState == 1)
         //GPIO96-   由GPDR3...控制
                                                 g_pGPIORegs->GPDR0 |= (1<                                                  g_pGPIORegs->GPSR0 |= (1<                                          }
                                 else
                                                 g_pGPIORegs->GPDR0 |= (1<                                                  g_pGPIORegs->GPCR0 |= (1<                                          }
             else if(gpioNum == 101 || gpioNum ==102 || gpioNum == 103 || gpioNum == 104)
                                 if(gpioState == 1)
                                                 g_pGPIORegs->GPDR3 |= (1<<(gpioNum % 32));
                                                 g_pGPIORegs->GPSR3 |= (1<<(gpioNum % 32));
                                 else
                                                 g_pGPIORegs->GPCR3 |= (1<<(gpioNum % 32));
                         return 1;
DWORD GPI_Read(DWORD dwData,  LPVOID pBuf, DWORD Len)
                BYTE* pdatabuf;
                BYTE  gpioNum;
                if(gpioNum == 3 || gpioNum ==4 || gpioNum == 9)
                        *pdatabuf =(g_pGPIORegs->GPLR0 & (1<
                        *pdatabuf =(g_pGPIORegs->GPLR3 & (1<<(gpioNum % 32)))?1:0;
                RETAILMSG(1,(TEXT("state:    %d\r\n"),*pdatabuf));
         return 1;
看这两个例程我感到很困惑 这里既没有对LEN做出处理 我想同时读2个gpio的状态都不行 还有里面只对部分寄存器进行了操作?
59
自己可以改
81
定义Len只是通用的做法
