3028|4
41
I2C硬件数据传输 [复制链接]
用169做主机发送数据,然后用5529接收数据,现在发现169在发送数据,但是在5529中怎么也进不了接收数据的中断,上拉电阻也加了,大神们给点意见啊,附上代码:169主机的代码:#include /file:///C:\Users\ADMINI~1\AppData\Local\Temp\)QN1UH78VKP2T7)IA]ZM(FW.gifar TXData = 0;
int main (void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P3SEL |= 0x0A;                            // Select I2C pins
  P1OUT |= 0x00;
  U0CTL |= I2C + SYNC;                      // Recommended init procedure
  U0CTL &= ~I2CEN;                          // Recommended init procedure
  I2CTCTL |= I2CSSEL1;                      // SMCLK
  I2CNDAT = 0x01;                           // Write one byte
  I2CSA = 0x0048;                           // Slave Address is 048h
  I2CIE = TXRDYIE;                          // Enable RXRDYIFG interrupt
  U0CTL |= I2CEN;                           // Enable I2C
//  I2CDCTL |=0x00;
  __enable_interrupt();                     // Enable interrupts
  while (1)
    U0CTL |= MST;                           // Master mode
    I2CTCTL |= I2CSTT + I2CSTP + I2CTRX;    // Initiate transfer
    __bis_SR_register(CPUOFF);              // Enter LPM0
// Common ISR for I2C Module
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector=USART0TX_VECTOR
__interrupt void I2C_ISR(void)
#elif defined(__GNUC__)
void __attribute__ ((interrupt(USART0TX_VECTOR))) I2C_ISR (void)
#else
#error Compiler not supported!
#endif
     I2CDRB = 0x5A;                         // TX data
     while (I2CBUSY & I2CDCTL);             // I2C ready?
     P1OUT |= 0x01;
     P1DIR |= 0x01;
     __bic_SR_register_on_exit(CPUOFF);     // Clear LPM0
5529从机的代码:
#include
volatile unsigned char RXData;
int main(void)
  P3SEL |= 0x03;                            // Assign I2C pins to USCI_B0
  P1OUT = 0;
  UCB0CTL1 |= UCSWRST;                      // Enable SW reset
  UCB0CTL0 = UCMODE_3 + UCSYNC;             // I2C Slave, synchronous mode
  UCB0I2COA = 0x48;                         // Own Address is 048h
  UCB0CTL1 &= ~UCSWRST;                     // Clear SW reset, resume operation
  UCB0IE |= UCRXIE;                         // Enable RX interrupt
  while (1)
    __bis_SR_register(LPM0_bits + GIE);     // Enter LPM0, enable interrupts(就停在这里了
    __no_operation();                       // Set breakpoint >>here<< and read
  }                                         // RXData
// USCI_B0 Data ISR
#pragma vector = USCI_B0_VECTOR
__interrupt void USCI_B0_ISR(void)
void __attribute__ ((interrupt(USCI_B0_VECTOR))) USCI_B0_ISR (void)
#else
#endif
{                                  // Vector 10: RXIFG
    RXData = UCB0RXBUF;                     // Get RX data
    P1DIR |= 0X01;
    P1OUT =0x01;
    __bic_SR_register_on_exit(LPM0_bits);   // Exit LPM0
看你的反应,应该是没有进去中断,所以没有退出睡眠 推荐你看个帖子,很有用的,但是不是中断模式,是轮询模式 MSP430F5438 I2C学习笔记——AT24C02 https://bbs.eeworld.com.cn/forum ... 8538&fromuid=698700 (出处: 电子工程世界-论坛) 我有硬件I2C轮询成功的代码,你看看你需不需要  详情 回复 发表于 2017-4-14 13:56
2774
是不是 在调试中,还是独立运行中发现的问题?
就是在单步调试的时候发现进不去中断的。我又在中断的里加了一个亮灯的动作,但是在全速运行的时候灯也没亮,所以感觉也是没进中断的  详情 回复 发表于 2017-4-4 19:54
41
348
(出处: 电子工程世界-论坛)
非常感谢!1代码可以发到我的邮箱。然后再想另外一个问题,我现在用169发,MSP430F6638接数据时可以成功的,因为6638和5529是一个系列的,代码也没差多少,但是为啥我现在移动5529去,169之间就不发送数据了? 169的  详情 回复 发表于 2017-4-16 17:15
41
推荐你看个帖子,很有用的,但是不是中断模式,是轮询 ...
非常感谢!1代码可以发到我的邮箱1419324155@qq.com。然后再想另外一个问题,我现在用169发,MSP430F6638接数据时可以成功的,因为6638和5529是一个系列的,代码也没差多少,但是为啥我现在移动5529去,169之间就不发送数据了? 169的I2CDRB寄存器运行了,但是根本没有值写进去,这是为啥啊?
