5749|7
让数码管显示温度的代码,我是新手,希望大家可以帮我一下 [复制链接]
这是我的代码,可能会有很多错误,希望大神可以耐心的帮我看一下!!
#include
#include
#define uchar unsigned char
#define uint  unsigned int
sbit wd=P2^2;
sbit du=P2^6;
sbit we=P2^7;
sbit fm=P2^3;
float wendu;
uint warn_l1=270;
uint warn_l2=250;
uint warn_h1=300;
uint warn_h2=320;
sbit led0=P1^0;
sbit led1=P1^1;
sbit led2=P1^2;
sbit led3=P1^3;
char code table []={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,
                                        0x3f+0x80,0x06+0x80,0x5b+0x80,0x4f+0x80,0x66+0x80,0x6d+0x80,0x7d+0x80,0x07+0x80,0x7f+0x80,0x6f+0x80};
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void fuwei(void)
        uint i;
        wd=0;
        i=103;
        while(i>0)i--;
        wd=1;
        i=4;
        while(i>0)i--;
bit yigezijie()
        uint i;
        bit dat;
        wd=0;
        i++;i++;
        wd=1;
        i++;
        i=8;
        while(i--);
        return (dat);
uchar yigezifu()
        uint a,dat;
        dat=0;
        for(a=0;a<8;a++)
                a=yigezijie();
                dat=(a<<7)|(dat>>1);
void duyigezijie(uchar dat)
        uchar a,i;
        bit xie;
        for(a=0;a<8;a++)
                xie=dat&0x01;
                dat>>1;
                if(xie)
                        wd=0;
                        i++;i++;
                        wd=1;
                        i=8;
                        while(i--);
                else
                        wd=1;
                        i=8;
                        while(i--);
                        wd=0;
                        i++;i++;
void zhuanhua()
        fuwei();
        delay(1);
        duyigezijie(0xcc);
        duyigezijie(0x44);
uint duqushuju()
        uchar a,b;
        fuwei();
        delay(1);
        duyigezijie(0xcc);
        duyigezijie(0xbe);
        a=yigezifu();
        b=yigezifu();
        wendu=(a+b*256)*0.625;
        return wendu;
void xianshishuju(uchar a,uchar b)
        uchar c;
        c=~((0x01)<         we=1;
        P0=c;
        we=0;
        P0=0xff;
        du=1;
        P0=table;
        du=0;
void shujudefenpei(uchar t)
        uchar shi,ge,shii;
        shi=t/100;
        xianshishuju(0,shi);
        ge=t/100/10;
        xianshishuju(0,shi+10);
        shii=t%10;
        xianshishuju(0,shii);
void panduanwendu()
        if(wendu>warn_h2)
                P1=0xfe;
                shujudefenpei(duqushuju());
        else if(wenduwarn_h1)
                P1=0xfd;
        else if(wendu>warn_l1&&wendu         {
                P1=0xfb;
        else if(wendu         {
                P1=0xf7;
void chuankouchushihua()
        TMOD=0X20;
        PCON=0X00;
        SCON=0X50;
        TH1=0XFD;
        TL1=0XFD;
        TR1=1;
void comm(char *parr)
        do
                SBUF=*parr++;
                while(!TI);
                TI=0;
        }                 while(*parr);
void main()
        uchar buff[4],i;
        du=0;
        we=0;
        chuankouchushihua();
        while(1);
                zhuanhua();
                for(i=10;i>0;i++)
                shujudefenpei(wendu);
                printf(buff,"%f",wendu);
                for(i=10;i>0;i++)
                comm(buff);
                for(i=10;i>0;i++)
此帖出自51单片机论坛
显示部分有问题  详情 回复 发表于 2017-4-2 16:40
9864
24
你遇到什么问题啦
此帖出自51单片机论坛
现在的情况是:代码没有错误,有警告,数码管也不亮,我希望各位大神可以帮我看看代码哪里出错了。
此帖出自51单片机论坛
128
1. bit yigezijie()  这个是什么结构,没用过,里面的i貌似没有初始化;
2.建议 一个模块一个模块的调试,看数据转化貌似用的是ds18b20,可以下载相关例程看看  ;
3.排除软件问题,先仿真,再调试硬件。
个人建议,祝好~
此帖出自51单片机论坛
9864
24
我没有51单片机 不能帮你测试了 你可以按提示把警告消除 或者把警告发出来 大家帮你看看哪些需要解决 代码弄好后如果有示波器或逻辑分析仪可以看一下输出 如果没有需要写一些测试程序 比如控制对应的I/O输出 用万用表或者LED看一下输出是否正常 确定能输出了在看一下时序是不是正确 代码的输出需要和对应的硬件配套 如果你有硬件资料最好也发出来 不然之发代码 别人很难看出问题在哪里
此帖出自51单片机论坛
606
函数全是拼音感觉好奇怪啊 不过不要紧 看到你有添加串口打印调试信息 ,首先可以看调试信息确定程序执行下去没有,感觉跑不下去啊,前提是你的串口打印是正常的 。建议程序先简单点,可以先读取数据或者数码管显示正常了再加入下一部分的。
此帖出自51单片机论坛
个人签名疏雨客晚归,荒烟乱,几许江南无晴!又落花,残香织梦,莫  莫  莫,白首衷肠……
57
鏌ョ湅鏈笘鍏ㄩ儴璁ㄨ锛岃鐧诲綍鎴栬€�娉ㄥ唽
此帖出自51单片机论坛
此帖出自51单片机论坛
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
