2408|6
希望各位大友们给看看 [复制链接]
#include
#define uint unsigned int
#define uchar unsigned char
sbit key1=P1^0;
sbit key2=P1^1;
sbit key3=P1^2;
sbit key4=P1^3;
sbit lcden=P2^2;
sbit lcdrs=P2^0;
sbit lcdrw=P2^1;
sbit led=P2^4;
sbit sound=P2^5;
uint a,b,i,min,hour,minge,minshi,hourge,hourshi,amin,ahour,aminge,aminshi,ahourge,ahourshi,sec;
//unsigned char code x[]={0xFF,0xC7,0x83,0x01,0x00,0x00,0x00,0x01,0x03,0x07,0x0F,0x1F,0x3F,0x7F,0xFF,0xFF};
//unsigned char code z[]={0xFF,0xE3,0xC1,0x80,0x00,0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0x7F,0xFF,0xFF};
uchar code table1[]={'0','1','2','3','4','5','6','7','8','9'};
uchar code table2[]="Time:00:00      "        ;
uchar code Alarm_1[]="Alarm:00:00     ";
uchar code nul[]="                 ";
uchar num1,num2;
void delay(unsigned int xms)        //????
        uint i,j;
         for(i=xms;i>0;i--)
                 for(j=124;j>0;j--);
void write_com(uchar com)                 //?LCD命令控制
        delay(5) ;
        lcdrs=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_data(uchar date)                   //?LCD数据控制
        delay(5);
        lcdrs=1;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void time()
        while(1)
                if(key1==0)
                         delay(10);
                        if(key1==0)
                                if(hour==23)                                 //        设置时间
                                        hour=0;
                                else
                                        hour++;
                                hourge=hour%10;
                                hourshi=hour/10;
                                write_com(0x0f);
                                delay(2);
                                write_com(0x80+6);
                                write_data(table1[hourge]);
                                delay(5);
                                write_com(0x80+5);
                                delay(2);
                                write_data(table1[hourshi]);
                                while(!key1);
                                //delay(1);
                if(key2==0)
                        delay(10);
                        if(key2==0)
                                if(min==59)                                        //分钟设置
                                        min=0;
                                else
                                        min++;
                                minge=min%10;
                                minshi=min/10;
                                write_com(0x0f);
                                write_com(0x80+9);
                                write_data(table1[minge]);
                                delay(1);
                                write_com(0x80+8);
                                write_data(table1[minshi]);
                                delay(1);
                                while(!key2);
                if(key3==0)
                        delay(10);
                        if(key3==0)
                                write_com(0x0c);
                                TR1=1;
                                while(!key3);
                                break;
void alarm()
        while(1)
                if(key1==0)
                         delay(10);
                        if(key1==0)
                                if(ahour==24)
                                        ahour=0;
                                else
                                        ahour++;
                                ahourge=ahour%10;
                                ahourshi=ahour/10;
                                write_com(0x0f);
                                //delay(2);
                                write_com(0x80+0x40+8);
                                write_data(':');
                                write_com(0x80+0x40+7);
                                write_data(table1[ahourge]);
                                delay(1);
                                write_com(0x80+0x40+6);
                                //delay(2);
                                write_data(table1[ahourshi]);
                                delay(1);
                                while(!key1);
                if(key2==0)
                        delay(10);
                        if(key2==0)
                                if(amin==59)
                                        amin=0;
                                else
                                        amin++;
                                aminge=amin%10;
                                aminshi=amin/10;
                                write_com(0x0f);
                                //delay(2);
                                write_com(0x80+0x40+10);
                                write_data(table1[aminge]);
                                delay(1);
                                write_com(0x80+0x40+9);
                        //        delay(2);
                                write_data(table1[aminshi]);
                                delay(1);
                                while(!key2);
                if(key3==0)
                        delay(10);
                        if(key3==0)
                                write_com(0x0c);
                                write_com(0x80+0x40);
                                for(i=0;i<11;i++)
                                write_data(nul);
                                while(!key3);
                                break;
void keyscan()
         if(key1==0)
                 delay(10);
                if(key1==0)
                        while(!key1);
                        time();
         else if(key2==0)
                 delay(10);
                if(key2==0)
                        while(!key2)
                        ahourge=ahour%10;
                        ahourshi=ahour/10;
                        delay(5);
                        delay(2);
                        aminge=amin%10;
                        aminshi=amin/10;
                        delay(5);
                        delay(2);
                        for(i=0;i<11;++i)
                        write_data(Alarm_1);
                        for(i=0;i<11;i++)
                        write_data(nul);
        else if(key3==0)
                 delay(10);
                if(key3==0)
                        while(!key3);
                                        ahourge=ahour%10;
                        ahourshi=ahour/10;
                        delay(5);
                        delay(2);
                        aminge=amin%10;
                        aminshi=amin/10;
                        delay(5);
                        delay(2);
                        for(i=0;i<11;++i)
                        alarm();
else if(key4==0)
                 delay(5);
                if(key4==0)
                        while(!key4);
                        a=a+1;
                        if(a%2==0)
                                for(b=0;b<6;b++)
                                        sound=~sound;
                                        delay(200);
                                sound=1;
                        else if(a%2==1)
                                sound=0;
                                delay(300);
                                sound=1;
                                delay(300);
                         sound=1;
void lcd_init()
        lcden=0;
        lcdrw=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        delay(2);
        write_com(0x80);
                        for(i=0;i<16;i++)
                                write_data(table2);
                                delay(1);
void init()
        key1=1;key2=1;key3=1;key4=1;sec=0;a=0;sound=1;amin=1;
        //led=1;
        TMOD=0x11;
        TH1=0x3C;
        TL1=0xB0;
        EA=1;
        ET1=1;
        TR1=1;
void led1() interrupt 3
        TH1=0x3C;
        TL1=0xB0;
        num1++;
        num2++;
        if(num1==10)
                num1=0;
                led=~led;
        if(amin==min&&ahour==hour&&a%2==0)
                        sound=0;
void main()
        lcd_init();
        init();
        while(1)
                keyscan();
        if(num2==20)
                num2=0;
                if(hour==23&&min==59&&sec==59)
                        hour=0;min=0;sec=0;
                else if(sec==59&&min==59)
                        sec=0;min=0;hour++;
                else if(sec==59)
                        sec=0;min++;
                else
                        sec++;
                        minge=min%10;
                        minshi=min/10;
                        write_com(0x80+9);
                        delay(5);
                        write_com(0x80+8);
                //        delay(2);
                        hourge=hour%10;
                        hourshi=hour/10;
                        write_com(0x80+6);
                        delay(5);
                        write_com(0x80+5);
                //        delay(2);
                        write_com(0x80+7);
                        write_data(':');
学友们,老师们,能给看看什么地方错了吗?给改下!
这是什么错误,能改下吗?
这是什么错误,能改下吗?
此帖出自51单片机论坛
把报错信息的图片发上来,是提示write_com(0x01),还是delay(2)..  详情 回复 发表于 2016-12-9 21:17
3471
你看看,write_com 这个函数,定义和声明的地方,是不是哪里少了个分号。
此帖出自51单片机论坛
我看了下,没有少啊
此帖出自51单片机论坛
把0x80那一行,注释掉,看看错误有什么变化。如果还是在write_com的语句上,看看函数定义,声明,以及前后是不是有语法错误。  详情 回复 发表于 2016-12-9 20:59
3471
小小胡先生 发表于 2016-12-9 20:39
我看了下,没有少啊
此帖出自51单片机论坛
ienglgge 发表于 2016-12-9 20:59
把0x80那一行,注释掉,看看错误有什么变化。如果还是在write_com的语句上,看看函数定义,声明,以及前 ...
注释了就提示上一行出错
此帖出自51单片机论坛
3471
小小胡先生 发表于 2016-12-9 21:12
注释了就提示上一行出错
此帖出自51单片机论坛
谢谢啦,我找到了
此帖出自51单片机论坛
