Copyright (C) 2014 Texas Instruments Incorporated - http://www.ti.com/
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the
distribution.
Neither the name of Texas Instruments Incorporated nor the names of
its contributors may be used to endorse or promote products derived
from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
"AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A
PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF
THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Application Name - UDP Socket
Application Overview - This particular application illustrates how
this
// device can be used as a client or server
for UDP
// communication.
Application Details -
http://processors.wiki.ti.com/in ... _Socket_Application
or
docs\examples\CC32xx_UDP_Socket_Application.pdf
\addtogroup udp_socket
#include
<stdio.h>
#include
<stdlib.h>
#include
<string.h>
simplelink includes
#include
"simplelink.h"
#include
"wlan.h"
driverlib includes
#include
"hw_ints.h"
#include
"hw_types.h"
#include
"hw_memmap.h"
#include
"rom.h"
#include
"rom_map.h"
#include
"interrupt.h"
#include
"prcm.h"
#include
"utils.h"
#include
"uart.h"
common interface includes
#include
"udma_if.h"
#include
"common.h"
#ifndef
NOTERM
#include
"uart_if.h"
#endif
#include
"i2c_if.h"
#include
"tmp006drv.h"
#include
"bma222drv.h"
#include
"pinmux.h"
#define
APPLICATION_NAME "UDP
Socket"
#define
APPLICATION_VERSION "1.1.1"
#define
IP_ADDR SL_IPV4_VAL(192,168,0,103)
#define
PORT_NUM 8001
#define
BUF_SIZE 1400
#define
UDP_PACKET_COUNT 1000
Application specific status/error codes
typedef
enum{
// Choosing -0x7D0 to avoid overlap w/ host-driver's error
codes
SOCKET_CREATE_ERROR =
-0x7D0,
BIND_ERROR =
SOCKET_CREATE_ERROR -
1,
SEND_ERROR =
BIND_ERROR -
1,
RECV_ERROR =
SEND_ERROR
-1,
SOCKET_CLOSE =
RECV_ERROR -1,
DEVICE_NOT_IN_STATION_MODE =
SOCKET_CLOSE -
1,
STATUS_CODE_MAX =
-0xBB8
}e_AppStatusCodes;
// LOCAL FUNCTION PROTOTYPES
int
BsdUdpClient(unsigned
short
usPort);
int
BsdUdpServer(unsigned
short
usPort);
static
long
WlanConnect();
static
void
DisplayBanner();
static
void
BoardInit();
static
void
InitializeAppVariables();
static
long
ConfigureSimpleLinkToDefaultState();
// GLOBAL VARIABLES -- Start
volatile
unsigned
long
g_ulStatus = 0;//SimpleLink Status
unsigned
long
g_ulGatewayIP = 0; //Network Gateway IP address
unsigned
char
g_ucConnectionSSID[SSID_LEN_MAX+1]; //Connection SSID
unsigned
char
g_ucConnectionBSSID[BSSID_LEN_MAX]; //Connection BSSID
unsigned
long
g_ulDestinationIp = IP_ADDR; //
Client IP address
unsigned
int
g_uiPortNum = PORT_NUM;
volatile
unsigned
long
g_ulPacketCount = UDP_PACKET_COUNT;
unsigned
char
g_ucSimplelinkstarted = 0;
unsigned
long
g_ulIpAddr = 0;
char
g_cBsdBuf[BUF_SIZE];
#if
defined(ccs) || defined(gcc)
extern
void (*
const
g_pfnVectors[])(void);
#endif
#if defined(ewarm)
extern uVectorEntry __vector_table;
#endif
// GLOBAL VARIABLES -- End
SimpleLink Asynchronous Event Handlers -- Start
\brief The Function Handles WLAN Events
\param[in] pWlanEvent - Pointer to WLAN Event Info
\return None
void
SimpleLinkWlanEventHandler(SlWlanEvent_t
*pWlanEvent)
if(!pWlanEvent)
return;
switch(pWlanEvent->Event)
case
SL_WLAN_CONNECT_EVENT:
SET_STATUS_BIT(g_ulStatus, STATUS_BIT_CONNECTION);
Information about the connected AP (like name, MAC etc) will be
available in 'slWlanConnectAsyncResponse_t'-Applications
// can
use it if required
slWlanConnectAsyncResponse_t *pEventData = NULL;
pEventData =
&pWlanEvent->EventData.STAandP2PModeWlanConnected;
Copy new connection SSID and BSSID to global parameters
memcpy(g_ucConnectionSSID,pWlanEvent->EventData.
STAandP2PModeWlanConnected.ssid_name,
pWlanEvent->EventData.STAandP2PModeWlanConnected.ssid_len);
memcpy(g_ucConnectionBSSID,
pWlanEvent->EventData.STAandP2PModeWlanConnected.bssid,
SL_BSSID_LENGTH);
UART_PRINT("[WLAN
EVENT] STA Connected to the AP: %s , "
"BSSID: %x:%x:%x:%x:%x:%x\n\r",
g_ucConnectionSSID,g_ucConnectionBSSID[0],
g_ucConnectionBSSID[1],g_ucConnectionBSSID[2],
g_ucConnectionBSSID[3],g_ucConnectionBSSID[4],
g_ucConnectionBSSID[5]);
break;
case
SL_WLAN_DISCONNECT_EVENT:
slWlanConnectAsyncResponse_t*
pEventData = NULL;
CLR_STATUS_BIT(g_ulStatus, STATUS_BIT_CONNECTION);
CLR_STATUS_BIT(g_ulStatus, STATUS_BIT_IP_AQUIRED);
pEventData = &pWlanEvent->EventData.STAandP2PModeDisconnected;
// If
the user has initiated 'Disconnect' request,
//'reason_code' is
SL_WLAN_DISCONNECT_USER_INITIATED_DISCONNECTION
if(SL_WLAN_DISCONNECT_USER_INITIATED_DISCONNECTION ==
pEventData->reason_code)
UART_PRINT("[WLAN
EVENT]Device disconnected from the AP: %s,"
"BSSID: %x:%x:%x:%x:%x:%x on application's request \n\r",
else
UART_PRINT("[WLAN
ERROR]Device disconnected from the AP AP: %s,"
"BSSID: %x:%x:%x:%x:%x:%x on an ERROR..!! \n\r",
memset(g_ucConnectionSSID,0,sizeof(g_ucConnectionSSID));
memset(g_ucConnectionBSSID,0,sizeof(g_ucConnectionBSSID));
break;
default:
UART_PRINT("[WLAN
EVENT] Unexpected event [0x%x]\n\r",
pWlanEvent->Event);
break;
\brief This function handles network events such as IP acquisition,
IP
//! leased, IP released etc.
\param[in] pNetAppEvent - Pointer to NetApp Event Info
\return None
void
SimpleLinkNetAppEventHandler(SlNetAppEvent_t
*pNetAppEvent)
if(!pNetAppEvent)
return;
switch(pNetAppEvent->Event)
case
SL_NETAPP_IPV4_IPACQUIRED_EVENT:
SlIpV4AcquiredAsync_t
*pEventData = NULL;
SET_STATUS_BIT(g_ulStatus, STATUS_BIT_IP_AQUIRED);
//Ip
Acquired Event Data
pEventData = &pNetAppEvent->EventData.ipAcquiredV4;
g_ulIpAddr = pEventData->ip;
//Gateway IP address
g_ulGatewayIP = pEventData->gateway;
UART_PRINT("[NETAPP EVENT] IP Acquired: IP=%d.%d.%d.%d , "
"Gateway=%d.%d.%d.%d\n\r",
SL_IPV4_BYTE(g_ulIpAddr,3),
SL_IPV4_BYTE(g_ulIpAddr,2),
SL_IPV4_BYTE(g_ulIpAddr,1),
SL_IPV4_BYTE(g_ulIpAddr,0),
SL_IPV4_BYTE(g_ulGatewayIP,3),
SL_IPV4_BYTE(g_ulGatewayIP,2),
SL_IPV4_BYTE(g_ulGatewayIP,1),
SL_IPV4_BYTE(g_ulGatewayIP,0));
break;
default:
UART_PRINT("[NETAPP EVENT] Unexpected event [0x%x] \n\r",
pNetAppEvent->Event);
break;
\brief This function handles HTTP server events
\param[in] pServerEvent - Contains the relevant event information
\param[in] pServerResponse - Should be filled by the user with the
//! relevant response
information
\return None
void
SimpleLinkHttpServerCallback(SlHttpServerEvent_t
*pHttpEvent,
SlHttpServerResponse_t
*pHttpResponse)
// Unused in this application
\brief This function handles General Events
\param[in] pDevEvent - Pointer to General Event Info
\return None
void
SimpleLinkGeneralEventHandler(SlDeviceEvent_t
*pDevEvent)
if(!pDevEvent)
return;
// Most of the general errors are not FATAL are are to be
handled
// appropriately by the application
UART_PRINT("[GENERAL EVENT] - ID=[%d] Sender=[%d]\n\n",
pDevEvent->EventData.deviceEvent.status,
pDevEvent->EventData.deviceEvent.sender);
This function handles socket events indication
\param[in] pSock - Pointer to Socket Event Info
\return None
void
SimpleLinkSockEventHandler(SlSockEvent_t
*pSock)
// This application doesn't work w/ socket - Events are not
expected
SimpleLink Asynchronous Event Handlers -- End
This function initializes the application variables
\param[in] None
\return None
static
void
g_ulStatus = 0;
g_ulGatewayIP = 0;
\brief This function puts the device in its default state. It:
//! - Set the mode to STATION
//! - Configures connection policy to Auto and
AutoSmartConfig
//! - Deletes all the stored profiles
//! - Enables DHCP
//! - Disables Scan policy
//! - Sets Tx power to maximum
//! - Sets power policy to normal
//! - Unregister mDNS services
//! - Remove all filters
\param none
\return On success, zero is returned. On error, negative is returned
static
long
SlVersionFull ver =
{0};
_WlanRxFilterOperationCommandBuff_t
RxFilterIdMask = {0};
unsigned
char ucVal =
1;
unsigned
char
ucConfigOpt = 0;
unsigned
char
ucConfigLen = 0;
unsigned
char ucPower
= 0;
long lRetVal
= -1;
long lMode =
-1;
lMode = sl_Start(0, 0,
0);
ASSERT_ON_ERROR(lMode);
// If the device is not in station-mode, try configuring it in
station-mode
if
(ROLE_STA !=
lMode)
if
(ROLE_AP ==
lMode)
// If
the device is in AP mode, we need to wait for this event
before doing anything
while(!IS_IP_ACQUIRED(g_ulStatus))
#ifndef
SL_PLATFORM_MULTI_THREADED
_SlNonOsMainLoopTask();
#endif
// Switch to STA role and restart
lRetVal = sl_WlanSetMode(ROLE_STA);
ASSERT_ON_ERROR(lRetVal);
lRetVal = sl_Stop(0xFF);
lRetVal = sl_Start(0, 0,
0);
// Check if the device is in station again
if
(ROLE_STA !=
lRetVal)
// We
don't want to proceed if the device is not coming up in STA-mode
return
DEVICE_NOT_IN_STATION_MODE;
// Get the device's version-information
ucConfigOpt = SL_DEVICE_GENERAL_VERSION;
ucConfigLen = sizeof(ver);
lRetVal = sl_DevGet(SL_DEVICE_GENERAL_CONFIGURATION, &ucConfigOpt,
&ucConfigLen, (unsigned
char
*)(&ver));
UART_PRINT("Host
Driver Version: %s\n\r",SL_DRIVER_VERSION);
UART_PRINT("Build
Version %d.%d.%d.%d.31.%d.%d.%d.%d.%d.%d.%d.%d\n\r",
ver.NwpVersion[0],ver.NwpVersion[1],ver.NwpVersion[2],ver.NwpVersion[3],
ver.ChipFwAndPhyVersion.FwVersion[0],ver.ChipFwAndPhyVersion.FwVersion[1],
ver.ChipFwAndPhyVersion.FwVersion[2],ver.ChipFwAndPhyVersion.FwVersion[3],
ver.ChipFwAndPhyVersion.PhyVersion[0],ver.ChipFwAndPhyVersion.PhyVersion[1],
ver.ChipFwAndPhyVersion.PhyVersion[2],ver.ChipFwAndPhyVersion.PhyVersion[3]);
// Set connection policy to Auto + SmartConfig
// (Device's default connection policy)
lRetVal = sl_WlanPolicySet(SL_POLICY_CONNECTION,
SL_CONNECTION_POLICY(1, 0, 0, 0, 1),
NULL, 0);
// Remove all profiles
lRetVal = sl_WlanProfileDel(0xFF);
// Device in station-mode. Disconnect previous connection if
any
// The function returns 0 if 'Disconnected done', negative number if
already
// disconnected Wait for 'disconnection' event if 0 is returned,
Ignore
// other return-codes
lRetVal = sl_WlanDisconnect();
if(0 ==
lRetVal)
// Wait
while(IS_CONNECTED(g_ulStatus))
#ifndef
#endif
// Enable DHCP client
lRetVal = sl_NetCfgSet(SL_IPV4_STA_P2P_CL_DHCP_ENABLE,1,1,&ucVal);
// Disable scan
ucConfigOpt = SL_SCAN_POLICY(0);
lRetVal = sl_WlanPolicySet(SL_POLICY_SCAN , ucConfigOpt, NULL, 0);
// Set Tx power level for station mode
// Number between 0-15, as dB offset from max power - 0 will set max
power
ucPower = 0;
lRetVal = sl_WlanSet(SL_WLAN_CFG_GENERAL_PARAM_ID,
WLAN_GENERAL_PARAM_OPT_STA_TX_POWER, 1, (unsigned
char
*)&ucPower);
// Set PM policy to normal
lRetVal = sl_WlanPolicySet(SL_POLICY_PM , SL_NORMAL_POLICY, NULL, 0);
// Unregister mDNS services
lRetVal = sl_NetAppMDNSUnRegisterService(0,
0);
// Remove all 64 filters (8*8)
memset(RxFilterIdMask.FilterIdMask, 0xFF,
8);
lRetVal = sl_WlanRxFilterSet(SL_REMOVE_RX_FILTER, (_u8 *)&RxFilterIdMask,
sizeof(_WlanRxFilterOperationCommandBuff_t));
lRetVal = sl_Stop(SL_STOP_TIMEOUT);
return
lRetVal; //
Success
\brief Parse the input IP address from the user
\param[in] ucCMD (char pointer to input string)
\return 0 : if correct IP, -1 : incorrect IP
int
IpAddressParser(char
*ucCMD)
int
i=0;
unsigned
int
uiUserInputData;
unsigned
long
ulUserIpAddress = 0;
char
*ucInpString;
ucInpString = strtok(ucCMD,
uiUserInputData = (int)strtoul(ucInpString,0,10);
while(i<4)
// Check Whether IP is valid
if((ucInpString != NULL) && (uiUserInputData <
256))
ulUserIpAddress |= uiUserInputData;
if(i <
3)
ulUserIpAddress = ulUserIpAddress <<
8;
ucInpString=strtok(NULL,".");
i++;
else
return
-1;
g_ulDestinationIp = ulUserIpAddress;
return
SUCCESS;
\brief Opening a UDP client side socket and sending data
This function opens a UDP socket and tries to connect to a Server
IP_ADDR
waiting on port PORT_NUM.
Then the function will send 1000 UDP packets to the server.
\param[in] port number on which the server will be listening on
\return 0 on success, -1 on Error.
int
short
usPort)
int iCounter;
short sTestBufLen;
SlSockAddrIn_t
sAddr;
int iAddrSize;
int iSockID;
int iStatus;
unsigned
long
lLoopCount = 0;
int iRet =
-1;
signed
char
cAccXT1,cAccYT1,cAccZT1;
char* str =
"x:%d\ty:%d\tz:%d";
// filling the buffer
for
(iCounter=0 ; iCounter<BUF_SIZE ; iCounter++)
g_cBsdBuf[iCounter] = (char)(iCounter % 10);
sTestBufLen = BUF_SIZE;
//filling the UDP server socket address
sAddr.sin_family =
SL_AF_INET;
sAddr.sin_port =
sl_Htons((unsigned
short)usPort);
sAddr.sin_addr.s_addr =
sl_Htonl((unsigned
int)g_ulDestinationIp);
iAddrSize = sizeof(SlSockAddrIn_t);
// creating a UDP socket
iSockID = sl_Socket(SL_AF_INET,SL_SOCK_DGRAM, 0);
if(
iSockID < 0 )
// error
ASSERT_ON_ERROR(SOCKET_CREATE_ERROR);
// for a UDP connection connect is not required
// sending 1000 packets to the UDP server
while
(lLoopCount < g_ulPacketCount)
// float fCurrentTemp;
// TMP006DrvGetTemp(&fCurrentTemp);
iRet = BMA222ReadNew(&cAccXT1, &cAccYT1, &cAccZT1);
if(iRet)
//In
case of error/ No New Data return
return;
sprintf(g_cBsdBuf,str,cAccXT1, cAccYT1, cAccZT1);
// sending packet
iStatus = sl_SendTo(iSockID, g_cBsdBuf, strlen(g_cBsdBuf), 0,
(SlSockAddr_t
*)&sAddr, iAddrSize);
MAP_UtilsDelay(1000000);
if(
iStatus <= 0 )
error
sl_Close(iSockID);
ASSERT_ON_ERROR(SEND_ERROR);
lLoopCount++;
UART_PRINT("Sent
%u packets successfully\n\r",g_ulPacketCount);
//closing the socket after sending 1000 packets
sl_Close(iSockID);
return
SUCCESS;
\brief Connecting to a WLAN Accesspoint
This function connects to the required AP (SSID_NAME) with Security
parameters specified in te form of macros at the top of this file
\param[in] None
\return status value
\warning If the WLAN connection fails or we don't aquire an IP
//! address, It will be stuck in this function
forever.
static
long
WlanConnect()
SlSecParams_t
secParams = {0};
long lRetVal
= 0;
secParams.Key =
(signed
char*)SECURITY_KEY;
secParams.KeyLen =
strlen(SECURITY_KEY);
secParams.Type =
SECURITY_TYPE;
lRetVal = sl_WlanConnect((signed
char*)SSID_NAME, strlen(SSID_NAME), 0, \
&secParams, 0);
while((!IS_CONNECTED(g_ulStatus)) ||
(!IS_IP_ACQUIRED(g_ulStatus)))
// Wait for WLAN Event
#ifndef
#endif
return
SUCCESS;
Application startup display on UART
\param none
\return none
static
void
DisplayBanner(char *
AppName)
UART_PRINT("\n\n\n\r");
UART_PRINT("\t\t
*************************************************\n\r");
UART_PRINT("\t\t CC3200 %s Application \n\r",
AppName);
UART_PRINT("\t\t
Board Initialization & Configuration
\param None
\return None
static
void
BoardInit(void)
/* In
case of TI-RTOS vector table is initialize by OS itself */
#ifndef
USE_TIRTOS
// Set vector table base
#if
MAP_IntVTableBaseSet((unsigned
long)&g_pfnVectors[0]);
#endif
#if defined(ewarm)
MAP_IntVTableBaseSet((unsigned long)&__vector_table);
#endif
#endif
// Enable Processor
MAP_IntMasterEnable();
MAP_IntEnable(FAULT_SYSTICK);
PRCMCC3200MCUInit();
// MAIN FUNCTION
void
main()
long lRetVal
= -1;
// Board Initialization
BoardInit();
// uDMA Initialization
UDMAInit();
// Configure the pinmux settings for the peripherals
exercised
PinMuxConfig();
// Configuring UART
InitTerm();
// Display banner
DisplayBanner(APPLICATION_NAME);
// Following function configure the device to default state by
cleaning
// the persistent settings stored in NVMEM (viz. connection profiles
// policies, power policy etc)
// Applications may choose to skip this step if the developer is
sure
// that the device is in its desired state at start of
applicaton
// Note that all profiles and persistent settings that were done on
the
// device will be lost
lRetVal = ConfigureSimpleLinkToDefaultState();
if(lRetVal
< 0)
if
(DEVICE_NOT_IN_STATION_MODE ==
lRetVal)
UART_PRINT("Failed to configure the device in its default state
\n\r");
LOOP_FOREVER();
// I2C Init
lRetVal = I2C_IF_Open(I2C_MASTER_MODE_FST);
if(lRetVal
< 0)
ERR_PRINT(lRetVal);
LOOP_FOREVER();
//Init Temprature Sensor
lRetVal = TMP006DrvOpen();
if(lRetVal
< 0)
ERR_PRINT(lRetVal);
LOOP_FOREVER();
//Init Accelerometer Sensor
lRetVal = BMA222Open();
if(lRetVal
< 0)
ERR_PRINT(lRetVal);
LOOP_FOREVER();
UART_PRINT("Device is configured in default state \n\r");
// Asumption is that the device is configured in station mode
already
// and it is in its default state
0);
if
(lRetVal < 0 || lRetVal != ROLE_STA)
UART_PRINT("Failed to start the device \n\r");
LOOP_FOREVER();
UART_PRINT("Device started as STATION \n\r");
UART_PRINT("Connecting to AP: %s ...\r\n",SSID_NAME);
//Connecting to WLAN AP
lRetVal = WlanConnect();
if(lRetVal
< 0)
UART_PRINT("Failed to establish connection w/ an AP \n\r");
LOOP_FOREVER();
UART_PRINT("Connected to AP: %s \n\r",SSID_NAME);
UART_PRINT("Device IP: %d.%d.%d.%d\n\r\n\r",
SL_IPV4_BYTE(g_ulIpAddr,0));
lRetVal = BsdUdpClient(PORT_NUM);
if(lRetVal
< 0)
ERR_PRINT(lRetVal);
LOOP_FOREVER();
UART_PRINT("Exiting Application ...\n\r");
// power off the network processor
while
(1)
Close the Doxygen group.
