7520|3
采用AD7746+stm32,使用I2C模拟,但一直没有ACK [复制链接]
  1. #define SDA_IN  {RCC->APB2ENR|=(unsigned int)1<<3;GPIOB->CRL&=0X0FFFFFFF;GPIOB->CRL|=(unsigned int)8<<28;GPIOB->ODR|=(unsigned int)1<<7;}
  2. #define SDA_OUT {RCC->APB2ENR|=(unsigned int)1<<3;GPIOB->CRL&=0X0FFFFFFF;GPIOB->CRL|=(unsigned int)3<<28;GPIOB->ODR|=(unsigned int)1<<7;}
  3. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  4. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  5. GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
  6. GPIO_Init(GPIOB, &GPIO_InitStructure);
  7. GPIO_SetBits(GPIOB,GPIO_Pin_6);
  8.
  9.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
  10.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  11.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
  12.         GPIO_Init(GPIOB,&GPIO_InitStructure);
  13.         GPIO_SetBits(GPIOB,GPIO_Pin_7);
  14. void IIC_SendByte(char ch)
  15. {
  16.         char i;
  17.         SDA_OUT;                        //to enable SDATA pin as an output
  18.         AD7746_SCLK = 0;                        //make sure that the clock line is low
  19.         //delay(20);
  20.         for(i=0;i<8;i++)
  21.         {
  22.                 AD7746_SDAout=0;
  23.                 if(ch&0x80)
  24.                         AD7746_SDAout=1;
  25.                 else
  26.                         AD7746_SDAout=0;
  27.                 ch = ch<<1;
  28.                 delay(5);
  29.                 AD7746_SCLK = 1;                //clock to send bit
  30.                 delay(5);
  31.                 AD7746_SCLK = 0;                //clear clock
  32.                 delay(5);
  33.                         //move ch's bit
  34.         }
  35.         SDA_IN;                        //release data line for acknowledge
  36.
  37.         AD7746_SCLK = 1;                //send clock for acknowledge
  38.         delay(2);
  39.         //AD7746_SDAout=1;
  40.         //delay(2);
  41.         if(!AD7746_SDAin)                                //no acknowledge, set flag
  42.         {
  43.
  44.                         IIC_Flag |= 1<<NOACK;
  45.         }
  46.
  47.         delay(20);
  48.         AD7746_SCLK = 0;                        //clear clock
  49. }
  50. void CDC_RDCAP(void)
  51. {
  52.         IIC_StartBit();
  53.         IIC_SendByte(SLAVEADD);
  54.         if(!(IIC_Flag&(1<<NOACK)))
  55.                 IIC_SendByte(CDC_CAPDATA_ADDR);
  56.         if(!(IIC_Flag&(1<<NOACK)))
  57.         {
  58.                 IIC_StartBit();                                //re-start
  59.                 IIC_SendByte(SLAVEADD+1);        //read function
  60.         }
  61.         if(!(IIC_Flag&(1<<NOACK)))
  62.                 CapResult_H = IIC_RcvByte(0);        //read cap data reg
  63.         if(!(IIC_Flag&(1<<NOACK)))
  64.                 CapResult_M = IIC_RcvByte(0);
  65.         if(!(IIC_Flag&(1<<NOACK)))
  66.                 CapResult_L = IIC_RcvByte(1);
  67.         IIC_StopBit();
  68.         if(IIC_Flag&(1<<NOACK))
  69.                 IIC_Flag |= 1<<ERR;
  70. }
复制代码
看了看代码,有帮助  详情 回复 发表于 2016-10-15 21:01
9864
24
测量一下SDA和SCL的信号对比一下
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
31
看了看代码,有帮助
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
