4437|3
106
AM335X TI SDK 7.0 无法网络启动 [复制链接]
在TI sdk 7.0.0.0.0 中UBOOT目录下make am335x_evm 生成的Uboot,不能保存Uboot环境变量,Beaglebone black SD卡启动输出如下
上电后进入uboot命令行,
1setenv xxxx,提示
2016-08-16T22:11:38.333 - Saving Environment to NAND...
2016-08-16T22:11:38.349 - Erasing redundant NAND...
2016-08-16T22:11:38.349 - Attempt to erase non block-aligned data
2016-08-16T22:11:38.349 - Erasing NAND...
显然BeagleboneBlack,没有接NAND,所以是保存不了的,
  1. 2016-08-16T22:10:12.452 -
  2. 2016-08-16T22:10:12.452 - U-Boot SPL 2013.10-00189-g78d8ebd (Aug 16 2016 - 21:17:19)
  3. 2016-08-16T22:10:13.004 - reading args
  4. 2016-08-16T22:10:13.004 - spl: error reading image args, err - -1
  5. 2016-08-16T22:10:13.004 - reading u-boot.img
  6. 2016-08-16T22:10:13.020 - reading u-boot.img
  7. 2016-08-16T22:10:13.067 -
  8. 2016-08-16T22:10:13.067 -
  9. 2016-08-16T22:10:13.067 - U-Boot 2013.10-00189-g78d8ebd (Aug 16 2016 - 21:17:19)
  10. 2016-08-16T22:10:13.067 -
  11. 2016-08-16T22:10:13.114 - I2C:   ready
  12. 2016-08-16T22:10:13.114 - DRAM:  512 MiB
  13. 2016-08-16T22:10:13.567 - NAND:  0 MiB
  14. 2016-08-16T22:10:13.567 - MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
  15. 2016-08-16T22:10:13.567 - *** Error - No Valid Environment Area found
  16. 2016-08-16T22:10:13.567 - *** Warning - bad CRC, using default environment
  17. 2016-08-16T22:10:13.567 -
  18. 2016-08-16T22:10:13.660 - Net:   <ethaddr> not set. Validating first E-fuse MAC
  19. 2016-08-16T22:10:13.696 - Could not get PHY for cpsw: addr 0
  20. 2016-08-16T22:10:13.696 - cpsw, usb_ether
  21. 2016-08-16T22:10:13.790 - Hit any key to stop autoboot:  0
  22. 2016-08-16T22:10:22.311 - U-Boot# printenv netboot
  23. 2016-08-16T22:10:22.311 - netboot=echo Booting from network ...; setenv autoload no; dhcp; tftp ${loadaddr} ${bootfile}; tftp ${fdtaddr} ${fdtfile}; run netargs; bootz ${loadaddr} - ${fdtaddr}
  24. 2016-08-16T22:10:36.275 - U-Boot# setenv serverip 192.168.1.103
  25. 2016-08-16T22:10:47.421 - U-Boot# printenv bootfile
  26. 2016-08-16T22:10:47.421 - bootfile=zImage
  27. 2016-08-16T22:11:03.937 - U-Boot# printenv fdtfile
  28. 2016-08-16T22:11:03.937 - fdtfile=undefined
  29. 2016-08-16T22:11:35.272 - U-Boot# setenv fdtfile am335x-boneblack.dtb
  30. 2016-08-16T22:11:38.333 - U-Boot# saveenv
  31. 2016-08-16T22:11:38.333 - Saving Environment to NAND...
  32. 2016-08-16T22:11:38.349 - Erasing redundant NAND...
  33. 2016-08-16T22:11:38.349 - Attempt to erase non block-aligned data
  34. 2016-08-16T22:11:38.349 - Erasing NAND...
  35. 2016-08-16T22:11:38.349 - Attempt to erase non block-aligned data
  36. 2016-08-16T22:11:47.226 - U-Boot#
复制代码
2,查看了uboot目录下的boards.cfg,有对beaglebone black的定义
  1. Active  arm         armv7          am33xx      ti              am335x              am335x_boneblack                     am335x_evm:SERIAL1,CONS_INDEX=1,EMMC_BOOT        Tom Rini <trini@ti.com>
  2. Active  arm         armv7          am33xx      ti              am335x              am335x_evm                           am335x_evm:SERIAL1,CONS_INDEX=1,NAND        Tom Rini <trini@ti.com>
  3. Active  arm         armv7          am33xx      ti              am335x              am335x_evm_nor                       am335x_evm:SERIAL1,CONS_INDEX=1,NAND,NOR        Tom Rini <trini@ti.com>
  4. Active  arm         armv7          am33xx      ti              am335x              am335x_evm_norboot                   am335x_evm:SERIAL1,CONS_INDEX=1,NOR,NOR_BOOT        Tom Rini <trini@ti.com>
  5. Active  arm         armv7          am33xx      ti              am335x              am335x_evm_spiboot                   am335x_evm:SERIAL1,CONS_INDEX=1,SPI_BOOT        Tom Rini <trini@ti.com>
  6. Active  arm         armv7          am33xx      ti              am335x              am335x_evm_uart1                     am335x_evm:SERIAL2,CONS_INDEX=1,NAND        Tom Rini <trini@ti.com>
  7. Active  arm         armv7          am33xx      ti              am335x              am335x_evm_uart2                     am335x_evm:SERIAL3,CONS_INDEX=1,NAND        Tom Rini <trini@ti.com>
  8. Active  arm         armv7          am33xx      ti              am335x              am335x_evm_uart3                     am335x_evm:SERIAL4,CONS_INDEX=1,NAND        Tom Rini <trini@ti.com>
  9. Active  arm         armv7          am33xx      ti              am335x              am335x_evm_uart4                     am335x_evm:SERIAL5,CONS_INDEX=1,NAND        Tom Rini <trini@ti.com>
  10. Active  arm         armv7          am33xx      ti              am335x              am335x_evm_uart5                     am335x_evm:SERIAL6,CONS_INDEX=1,NAND        Tom Rini <trini@ti.com>
  11. Active  arm         armv7          am33xx      ti              am335x              am335x_evm_usbspl                    am335x_evm:SERIAL1,CONS_INDEX=1,NAND,SPL_USBETH_SUPPORT
复制代码
于是重新编译UBOOT,命令为:make am335x_boneblack
这次生成的Uboot能保存环境变量了,其默认存储在EMMC上,
2016-08-16T21:11:36.713 - U-Boot# saveenv
2016-08-16T21:11:36.713 - Saving Environment to MMC...
2016-08-16T21:11:36.822 - Writing to redundant MMC(1)... done
可是出现了一个新的问题,设置好
setenv bootfile uImage
setenv  rootpath ........
saveenv保存
之后运行run netboot,提示没有定义 bootfile ,
这是几个意思啊,然后打印 printenv bootfile 输出为空,明明我都设置好了,保存了额,tftp服务器上也有文件,为什么啊。
我单独下载 tftp 0x82000000 uImage 就可以下载啊。
结论是,运行了 netboot,会清空bootfile ,这怎么破。请大神支招。
  1. 2016-08-16T21:11:57.885 - U-Boot# run netboot
  2. 2016-08-16T21:11:57.885 - Booting from network ...
  3. 2016-08-16T21:11:57.885 - link up on port 0, speed 100, full duplex
  4. 2016-08-16T21:11:57.885 - BOOTP broadcast 1
  5. 2016-08-16T21:12:00.885 - BOOTP broadcast 2
  6. 2016-08-16T21:12:06.791 - cpsw Waiting for PHY auto negotiation to complete......... TIMEOUT !
  7. 2016-08-16T21:12:06.791 - link down on port 0
  8. 2016-08-16T21:12:06.791 - BOOTP broadcast 3
  9. 2016-08-16T21:12:09.447 - cpsw Waiting for PHY auto negotiation to complete..... done
  10. 2016-08-16T21:12:09.447 - link up on port 0, speed 100, full duplex
  11. 2016-08-16T21:12:13.510 - cpsw Waiting for PHY auto negotiation to complete....... done
  12. 2016-08-16T21:12:13.510 - BOOTP broadcast 4
  13. 2016-08-16T21:12:16.510 - BOOTP broadcast 5
  14. 2016-08-16T21:12:17.010 - *** Unhandled DHCP Option in OFFER/ACK: 52
  15. 2016-08-16T21:12:17.010 - *** Unhandled DHCP Option in OFFER/ACK: 52
  16. 2016-08-16T21:12:17.010 - DHCP client bound to address 192.168.1.104
  17. 2016-08-16T21:12:17.026 - link up on port 0, speed 100, full duplex
  18. 2016-08-16T21:12:17.026 - Using cpsw device
  19. 2016-08-16T21:12:17.026 - TFTP from server 192.168.1.103; our IP address is 192.168.1.104
  20. 2016-08-16T21:12:17.026 - Filename '
  21. 2016-08-16T21:12:17.026 - Load address: 0x80200000
  22. 2016-08-16T21:12:17.072 - Loading: *
  23. 2016-08-16T21:12:17.072 - TFTP error: 'File not found' (1)
  24. 2016-08-16T21:12:17.072 - Not retrying...
  25. 2016-08-16T21:12:17.088 - link up on port 0, speed 100, full duplex
  26. 2016-08-16T21:12:17.088 - Using cpsw device
  27. 2016-08-16T21:12:17.088 - TFTP from server 192.168.1.103; our IP address is 192.168.1.104
  28. 2016-08-16T21:12:17.088 - Filename 'am335x-boneblack.dtb'.
  29. 2016-08-16T21:12:17.088 - Load address: 0x80f80000
  30. 2016-08-16T21:12:17.338 - Loading: #######
  31. 2016-08-16T21:12:17.338 -          138.7 KiB/s
  32. 2016-08-16T21:12:17.338 - done
  33. 2016-08-16T21:12:17.338 - Bytes transferred = 34352 (8630 hex)
  34. 2016-08-16T21:12:17.338 - Bad Linux ARM zImage magic!
复制代码
20160816BeagleUboot.log (12.23 KB, 下载次数: 6)
20160816evm.log (1.98 KB, 下载次数: 7)
2016-08-16T22:10:13.567 - NAND:  0 MiB NandFlash 没有 识别, 你 参考 下辉为科技 的板子,内核源代码需要的话,加我QQ 942400696[attach]302204[/attach] http://v.youku.com/v_show/id_XMjY4MTU2NjQ1Mg==.html http://v.youku.com/v_show/id_XMjY4MTU2NjQ1Mg==.html   详情 回复 发表于 2017-5-19 17:01
106
附件20160816BeagleUboot.log是使用make am335x_boneblack 生产的Uboot,的运行记录
106
附件20160816evm.log是运行 make am335x_evm生产uboot的运行记录。
32
个人签名AM335 IMX6UL IMX6 A5D3X开发板工控板核心板 供应商
www.huiweit.com  IMX6UL社区群 175493668
