3367|0
lm3s615定时器产生pwm波总是高电平 [复制链接]
求助大神啊  困扰几天了 程序可以编译成功  代码如下
#include
#include
#include
#include
#include
int main(void)
        SysCtlClockSet( SYSCTL_SYSDIV_4 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN |
                    SYSCTL_XTAL_6MHZ );
        SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER1);
        SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC);
        GPIOPinTypeTimer(GPIO_PORTC_BASE,GPIO_PIN_6);
        TimerConfigure(TIMER1_BASE,TIMER_CFG_16_BIT_PAIR|TIMER_CFG_A_PWM|TIMER_CFG_B_PWM);
        TimerControlLevel(TIMER1_BASE,TIMER_B,true);
        TimerLoadSet(TIMER1_BASE,TIMER_B,6000);
        TimerMatchSet(TIMER1_BASE,TIMER_B,3000);
        TimerEnable(TIMER1_BASE,TIMER_B);
用mdk 引脚波形查看 一直是高电平
