4881|4
DSP-刚安好,test connection时一直报错。。求大神帮助 [复制链接]
[Start]
Execute the command:
%ccs_base%/common/uscif/dbgjtag.exe -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity
[Result]
-----[Print the board config pathname(s)]------------------------------------
C:\Users\ADMINI~1\AppData\Local\.TI\2658696708\
    0\0\BrdDat\testBoard.dat
-----[Print the reset-command software log-file]-----------------------------
This utility has selected a 100- or 510-class product.
This utility will load the adapter 'seedjca8990isa.dll'.
The library build date was 'Aug 20 2013'.
The library build time was '22:56:19'.
The library package version is '5.1.232.0'.
The library component version is '35.34.40.0'.
The controller does not use a programmable FPGA.
The controller has a version number of '1' (0x00000001).
The controller has an insertion length of '16' (0x00000010).
This utility will attempt to reset the controller.
A error occurred while attempting to reset the controller.
-----[An error has occurred and this utility has aborted]--------------------
This error is generated by TI's USCIF driver or utilities.
The value is '-342' (0xfffffeaa).
The title is 'SC_ERR_HUNG_COMMAND'.
The explanation is:
Failure due to the controller command-finish taking too long.
[End]
期待问题解决了。   详情 回复 发表于 2019-10-12 11:48
请问你的问题解决没?是驱动没装好?
2618
期待问题解决了。
快来报名!
