3525|1
msp430g2553+ADC10采样正弦波峰值+12864显示问题 [复制链接]
1芯积分
液晶上有显示,但是总显示2.1,不知道是怎么回事,谢谢大家,急!!
#include
#define uint unsigned int
#define uchar unsigned char
#define CS_H P2OUT|=BIT2
#define CS_L P2OUT&=~BIT2
#define SID_H P2OUT|=BIT1
#define SID_L P2OUT&=~BIT1
#define SCLK_H P2OUT|=BIT0
#define SCLK_L P2OUT&=~BIT0
uint aver[64]={0};
uchar flag=0;
uchar zifu[10]={"0123456789"};
uint maxaver=0;
long dis=0;
double max=0,maxr=0;
void delay(uchar z)
  uint x,y;
  for(x = 110;x>0;x--)
    for(y = z;y>0;y--);
void Sys_init()
  uchar i;
  WDTCTL = WDTPW + WDTHOLD;
  BCSCTL1 = CALBC1_16MHZ;
  DCOCTL = CALDCO_16MHZ;//设置内部时钟8M
  do
    IFG1 &= ~OFIFG;
    for(i = 0xff;i>0;i--);
  while((IFG1 & OFIFG) != 0);
  BCSCTL2 |= SELM_0;
  BCSCTL2 |= DIVS_0;
void send_byte(uchar bbyte)
  uchar i,temp;
  for(i=0;i<8;i++)
//    P2DIR = 0xff;
    temp = bbyte & 0x80;
    if(temp)
      SID_H;
    else
      SID_L;
    SCLK_L;
    SCLK_H;
    bbyte = bbyte<<1;
void LCD12864_write_cmd(uchar ddata)
  uchar hdata,ldata;
  hdata = ddata & 0xf0;
  ldata = (ddata<<4) & 0xf0;
  CS_H;
  send_byte(0xf8);
  delay(5);
  send_byte(hdata);
  delay(1);
  send_byte(ldata);
  delay(1);
  CS_L;
void LCD12864_write_data(uchar ddata)
  uchar hdata,ldata;
  CS_H;
  send_byte(0xfa);
  delay(5);
  send_byte(hdata);
  delay(1);
  send_byte(ldata);
  delay(1);
  CS_L;
void LCD12864_init()
  P2DIR |= BIT0 + BIT1 + BIT2;
  delay(10);
  CS_H;
  LCD12864_write_cmd(0x34);
  delay(1);
  LCD12864_write_cmd(0x30);
  delay(1);
  LCD12864_write_cmd(0x0c);//
  delay(1);
  LCD12864_write_cmd(0x01);
  delay(1);
  LCD12864_write_cmd(0x02);
  delay(1);
void LCD12864_pos(uchar x,uchar y)
  uchar pos;
  switch(x)
  case 1:pos = 0x80;break;
  case 2:pos = 0x90;break;
  case 3:pos = 0x88;break;
  case 4:pos = 0x98;break;
  default:pos = 0x80;
  pos += y;
  LCD12864_write_cmd(pos);
void shuju()
  uchar j;
  maxr = 0;
  maxaver = 0;
  for(j = 0;j < 64;j+=2)
    if((aver[j]>maxaver) && (aver[j]<1024))
      maxaver = aver[j];
    maxr = (maxaver*3.56)/1023;
    max = maxr*10000;
    dis = max;
    LCD12864_pos(2,2);
    LCD12864_write_data(zifu[dis/10000]);
    LCD12864_write_data('.');
    LCD12864_write_data(zifu[dis/1000%10]);
    LCD12864_write_data(zifu[dis/100%10]);
    LCD12864_write_data(zifu[dis/10%10]);
    LCD12864_write_data(zifu[dis%10]);
void IO_init(void)
  P1DIR &= ~BIT3;
  P1SEL |= BIT3;
void ADC_init(void)
  ADC10CTL0 = ADC10ON + ADC10SHT_3 + MSC + ADC10IE + SREF_0;
  ADC10CTL1 |= CONSEQ_2 + INCH_1 + ADC10SSEL_0;
  ADC10AE0 |= BIT0 + BIT1;
  ADC10DTC1 = 0x40;
void main(void)
  IO_init();
//  P2DIR = 0XFF;
  LCD12864_init();
//  PORT_init();
  Sys_init();
  ADC_init();
//  _EINT();
  while(1)
    ADC10CTL0 &=~ENC;
    while(ADC10CTL1 & ADC10BUSY);
    ADC10CTL0 |= ENC + ADC10SC;
        ADC10SA = (unsigned int)aver;
//   ADC10CTL0&=~ADC10IFG;
    _BIS_SR(LPM0_bits + GIE);
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR(void)
  shuju();
//  dis =ADC10MEM;
  _BIC_SR_IRQ(CPUOFF + GIE);
你问题解决了吗?我现在在做用LCD1602显示的实验,你的程序可以给我看看吗?新手求指导!!!  详情 回复 发表于 2016-7-14 15:25
