8866|2
1170
至上芯片
凤凰写卡器制作 [复制链接]
这是我在网上看到的凤凰写卡器,很简单,不过都是英文,相关的编程软件没有提供,不过通用的软件ICPROG应该是可以使用的.要制作可以刷写卫星电视接收卡就是这么简单.
元件清单:
25 LED green 590-345
26 LED red 590-339
27 IC 7407N 306-336
27b IC socket 14 pin 447-314
28 IC MAX232ECPE 225-8510
28b IC socket 16 pin 447-320
29 IC 74HC04N 217-5550
29b IC socket 14 pin 447-314
30 Secondary board, on top of smartcard connector.
Mount everything but the secondary board, leds and ICs
Mount top of leds into the secondary board, fasten secondary board to top of smartcard connector
after carefully first having put the led legs through the holes in main board.
Finally , ground yourselves to get rid of any statics and mount the ICs.
謝謝樓主,長些見識  详情 回复 发表于 2009-3-24 00:42
Re: 凤凰写卡器制作
谢谢了啊,圣诞快乐!
46
Re: 凤凰写卡器制作
謝謝樓主,長些見識
