7663|9
39
CC3200利用CCS建项目或TI SDK的example demo如何包TI_RTOS系统 [复制链接]
 急,cc3200 的SDK 已经安装好,使用编译环境是CCS(Code Composer Studio 6.1),利用其中的App Center 把TI_RTOS系统也已经安装,前提是我把SDK中的driverlib、oslib、simplelink都已经编译过。因为我要新建个项目,要用到TI_RTOS的多线程方面的应用,所以要包ti_rtos 相关的库等,但是我配置好项目编译时,一直存在以下错误:
undefined                                    first referenced
  symbol                                          in file
ti_sysbios_BIOS_start__E                     C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_family_arm_m3_Hwi_Params__init__S C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_family_arm_m3_Hwi_create          C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_family_arm_m3_Hwi_delete          C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_family_arm_m3_Hwi_disableFxn__E   C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_family_arm_m3_Hwi_getHandle__E    C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_family_arm_m3_Hwi_restoreFxn__E   C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_family_arm_m3_Hwi_setPriority__E  C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_knl_Clock_tickPeriod__C           C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_knl_Mailbox_create                C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_knl_Mailbox_delete                C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_knl_Mailbox_pend__E               C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_knl_Mailbox_post__E               C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_knl_Semaphore_Params__init__S     C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_knl_Semaphore_create              C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_knl_Semaphore_delete              C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_knl_Semaphore_pend__E             C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_knl_Semaphore_post__E             C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_knl_Task_Params__init__S          C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_knl_Task_create                   C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_knl_Task_delete                   C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_knl_Task_disable__E               C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_knl_Task_restore__E               C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_knl_Task_sleep__E                 C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
ti_sysbios_knl_Task_yield__E                 C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
xdc_runtime_Error_init__E                    C:/TI/CC3200SDK_1.1.0/cc3200-sdk/example/interrupt/ccs/../../../oslib/ccs/ti_rtos/ti_rtos.a
error #10234-D: unresolved symbols remain
error #10010: errors encountered during linking; "interrupt.out" not built
>> Compilation failure
gmake: *** [interrupt.out] Error 1
gmake: Target `all' not remade because of errors.
求大神帮忙!先谢谢了!
朋友们有没有TI_RTOS的中文资料  详情 回复 发表于 2016-5-28 21:41
1158
你有安装TI-RTOS吗,在app store里面
你看下我的配置,  详情 回复 发表于 2016-5-25 15:53
装了的,SDK 装好后,就到ccs app center 里面装TI_RTOS了!  详情 回复 发表于 2016-5-25 15:47
39
39
我是在TI SDK 中的example demo interrupt 的基础上加TI_RTOS 的,具体配置如下:
我是不是少配置了什么?
39
你看下我的配置,
好吧,暂时还没研究到这块,可能帮不到你。。  详情 回复 发表于 2016-5-25 16:36
1158
quake702 发表于 2016-5-25 15:53
你看下我的配置,
好的吧,赶紧研究啊,我也在广交吧友,一起研究这块板子呢!  详情 回复 发表于 2016-5-25 17:39
39
好的呢!  详情 回复 发表于 2016-5-25 21:03
1158
好的呢!
朋友们有没有TI_RTOS的中文资料
这个还真没有,抱歉,刚接触不久。另外,大部分资料我觉得TI 官网上很齐全的,当然全是外文文档啦!  详情 回复 发表于 2016-5-30 15:24
39
liaoiverson 发表于 2016-5-28 21:41
朋友们有没有TI_RTOS的中文资料
