* GLOBAL VARIABLES
// This list should be filled with Application specific Cluster IDs.
const cId_t SampleApp_ClusterList[SAMPLEAPP_MAX_CLUSTERS] =
SAMPLEAPP_PERIODIC_CLUSTERID,
SAMPLEAPP_FLASH_CLUSTERID
// This is the Endpoint/Interface description. It is defined here, but
// filled-in in SampleApp_Init(). Another way to go would be to fill
// in the structure here and make it a "const" (in code space). The
// way it's defined in this sample app it is define in RAM.
endPointDesc_t SampleApp_epDesc;
* LOCAL VARIABLES
uint8 SampleApp_TaskID; // Task ID for internal task/event processing
// This variable will be received when
// SampleApp_Init() is called.
devStates_t SampleApp_NwkState;
uint8 SampleApp_TransID; // This is the unique message ID (counter)
* PUBLIC FUNCTIONS
* @fn SampleApp_Init
* @brief Initialization function for the Generic App Task.
* This is called during initialization and should contain
* any application specific initialization (ie. hardware
* initialization/setup, table initialization, power up
* notificaiton ... ).
* @param task_id - the ID assigned by OSAL. This ID should be
* used to send messages and set timers.
* @return none
void SampleApp_Init( uint8 task_id ) //初始化此任务
SampleApp_TaskID = task_id; //存储任务号
SampleApp_NwkState = DEV_INIT; //状态改为初始化状态
SampleApp_TransID = 0; //帧序列号初始化为0
// Device hardware initialization can be added here or in main() (Zmain.c).
// If the hardware is application specific - add it here.
// If the hardware is other parts of the device add it in main().
#if defined ( BUILD_ALL_DEVICES )
// The "Demo" target is setup to have BUILD_ALL_DEVICES and HOLD_AUTO_START
// We are looking at a jumper (defined in SampleAppHw.c) to be jumpered
// together - if they are - we will start up a coordinator. Otherwise,
// the device will start as a router.
if ( readCoordinatorJumper() )
zgDeviceLogicalType = ZG_DEVICETYPE_COORDINATOR;
else
zgDeviceLogicalType = ZG_DEVICETYPE_ROUTER;
#endif // BUILD_ALL_DEVICES
#if defined ( HOLD_AUTO_START )
// HOLD_AUTO_START is a compile option that will surpress ZDApp
// from starting the device and wait for the application to
// start the device.
ZDOInitDevice(0);
#endif
// Setup for the periodic message's destination address
// Broadcast to everyone
SampleApp_Periodic_DstAddr.addrMode = (afAddrMode_t)AddrBroadcast;//广播
SampleApp_Periodic_DstAddr.endPoint = SAMPLEAPP_ENDPOINT;
SampleApp_Periodic_DstAddr.addr.shortAddr = 0xFFFF;
// Setup for the flash command's destination address - Group 1
SampleApp_Flash_DstAddr.addrMode = (afAddrMode_t)afAddrGroup;//组播
SampleApp_Flash_DstAddr.endPoint = SAMPLEAPP_ENDPOINT;
SampleApp_Flash_DstAddr.addr.shortAddr = SAMPLEAPP_FLASH_GROUP;
// Fill out the endpoint description.
SampleApp_epDesc.endPoint = SAMPLEAPP_ENDPOINT;
SampleApp_epDesc.task_id = &SampleApp_TaskID;
SampleApp_epDesc.simpleDesc
= (SimpleDescriptionFormat_t *)&SampleApp_SimpleDesc;
SampleApp_epDesc.latencyReq = noLatencyReqs;
// Register the endpoint description with the AF
afRegister( &SampleApp_epDesc );
// Register for all key events - This app will handle all key events
RegisterForKeys( SampleApp_TaskID );
// By default, all devices start out in Group 1
SampleApp_Group.ID = 0x0001;
osal_memcpy( SampleApp_Group.name, "Group 1", 7 );
aps_AddGroup( SAMPLEAPP_ENDPOINT, &SampleApp_Group );
* @fn SampleApp_ProcessEvent
* @brief Generic Application Task event processor. This function
* is called to process all events for the task. Events
* include timers, messages and any other user defined events.
* @param task_id - The OSAL assigned task ID.
* @param events - events to process. This is a bit map and can
* contain more than one event.
* @return none
uint16 SampleApp_ProcessEvent( uint8 task_id, uint16 events )
afIncomingMSGPacket_t *MSGpkt;
(void)task_id; // Intentionally unreferenced parameter
if ( events & SYS_EVENT_MSG )
MSGpkt = (afIncomingMSGPacket_t *)osal_msg_receive( SampleApp_TaskID );
while ( MSGpkt )
switch ( MSGpkt->hdr.event )
// Received when a key is pressed
case KEY_CHANGE:
SampleApp_HandleKeys( ((keyChange_t *)MSGpkt)->state, ((keyChange_t *)MSGpkt)->keys );
break;
// Received when a messages is received (OTA) for this endpoint
case AF_INCOMING_MSG_CMD:
SampleApp_MessageMSGCB( MSGpkt );
break;
// Received whenever the device changes state in the network
case ZDO_STATE_CHANGE:
SampleApp_NwkState = (devStates_t)(MSGpkt->hdr.status);
if ( //(SampleApp_NwkState == DEV_ZB_COORD) ||
(SampleApp_NwkState == DEV_ROUTER)
|| (SampleApp_NwkState == DEV_END_DEVICE) )
// Start sending the periodic message in a regular interval.
osal_start_timerEx( SampleApp_TaskID,
SAMPLEAPP_SEND_PERIODIC_MSG_EVT,
SAMPLEAPP_SEND_PERIODIC_MSG_TIMEOUT );
else
// Device is no longer in the network
break;
default:
break;
// Release the memory
osal_msg_deallocate( (uint8 *)MSGpkt );
// Next - if one is available
// Send a message out - This event is generated by a timer
// (setup in SampleApp_Init()).
if ( events & SAMPLEAPP_SEND_PERIODIC_MSG_EVT )
// Send the periodic message
//SampleApp_SendPeriodicMessage();
SampleApp_Send_P2P_Message();
// Setup to send message again in normal period (+ a little jitter)
osal_start_timerEx( SampleApp_TaskID, SAMPLEAPP_SEND_PERIODIC_MSG_EVT,
(SAMPLEAPP_SEND_PERIODIC_MSG_TIMEOUT + (osal_rand() & 0x00FF)) );
* Event Generation Functions
* @fn SampleApp_HandleKeys
* @brief Handles all key events for this device.
* @param shift - true if in shift/alt.
* @param keys - bit field for key events. Valid entries:
* HAL_KEY_SW_2
* HAL_KEY_SW_1
* @return none
void SampleApp_HandleKeys( uint8 shift, uint8 keys )
(void)shift; // Intentionally unreferenced parameter
if ( keys & HAL_KEY_SW_1 )
/* This key sends the Flash Command is sent to Group 1.
* This device will not receive the Flash Command from this
* device (even if it belongs to group 1).
SampleApp_SendFlashMessage( SAMPLEAPP_FLASH_DURATION );
if ( keys & HAL_KEY_SW_2 )
/* The Flashr Command is sent to Group 1.
* This key toggles this device in and out of group 1.
* If this device doesn't belong to group 1, this application
* will not receive the Flash command sent to group 1.
aps_Group_t *grp;
grp = aps_FindGroup( SAMPLEAPP_ENDPOINT, SAMPLEAPP_FLASH_GROUP );
if ( grp )
// Remove from the group
aps_RemoveGroup( SAMPLEAPP_ENDPOINT, SAMPLEAPP_FLASH_GROUP );
else
// Add to the flash group
* LOCAL FUNCTIONS
* @fn SampleApp_MessageMSGCB
* @brief Data message processor callback. This function processes
* any incoming data - probably from other devices. So, based
* on cluster ID, perform the intended action.
* @param none
* @return none
void SampleApp_MessageMSGCB( afIncomingMSGPacket_t *pkt )
uint16 flashTime;
