2361|0
C6746 编译报错 INTERNAL ERROR: no match for ASG [复制链接]
在CCS3.3中建了一个C6746的工程,在头文件中定义了相关寄存器
extern cregister volatile Uint32 AMR;     /* Address Mode Register      */
extern cregister volatile Uint32 CSR;     /* Interrupt Return Pointer   */
extern cregister volatile Uint32 IFR;     /* Interrupt Flag Register    */
extern cregister volatile Uint32 ISR;     /* Interrupt Set Register     */
extern cregister volatile Uint32 ICR;     /* Interrupt Clear Register   */
extern cregister volatile Uint32 IER;     /* Interrupt Enable Register  */
extern cregister volatile Uint32 ISTP;    /* Interrupt Service Tbl Ptr  */
extern cregister volatile Uint32 ITSR;    /* Interrupt Task State Register  */
extern cregister volatile Uint32 IRP;     /* Interrupt Return Pointer   */
extern cregister volatile Uint32 NRP;     /* Non-maskable Int Return Ptr*/
在中断中希望对相关寄存器进行保护
  Uint32 irp,csr,ier,itsr;
irp = IRP;/* Interrupt Return Pointer   */
  csr = CSR;/* Interrupt Return Pointer   */
  itsr = ITSR;/* Interrupt Task State Register  */
  ier = IER;/* Interrupt Enable Register  */
IER = ier & (~(1<<6));//determine which interrupts should be allowed to pre-empt
CSR = csr | 1;//enable global interrupt
但是编译的时候会报INTERNAL ERROR: no match for ASG ( irp = IRP;/* Interrupt Return Pointer   */这一行)
如果将上面头文件中的定义数据类型Uint32改为Uint16则不会报错,但是上面的寄存器应该都是32位的,改为16位的应该会有问题。
报错的原因在哪?报的这个错误是什么?各位大侠有什么解决方法吗?
谢谢了!
中星联华&ADI明日直播
直播主题:大咖面对面,轻松玩转高速ADC性能测试
直播时间:3月25日(周二)14:00
活动奖励:京东卡、双肩包
