4464|1
导入motorware中的项目编译失败,请教解决方法? [复制链接]
环境  ccs6.1.2
如果按照默认不指定芯片具体型号,可以编译通过,但无法调试。
指定了具体的芯片型号,编译时出现如上错误,
错误信息
error #16008-D: file
   "C:/ti/motorware/motorware_1_01_00_13/sw/modules/fast/lib/32b/f28x/f2806x/28
   06xRevB_FastSpinROMSymbols.lib    j>" specifies ISA revision "C2800", which is not compatible with ISA
   revision "C28FPU32" specified in a previous file or on the command line
   revision "C2700" specified in a previous file or on the command line
   06xRevB_FastSpinROMSymbols.lib    bj>" specifies ISA revision "C2800", which is not compatible with ISA
   06xRevB_FastSpinROMSymbols.lib    on_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
   ISA revision "C2700" specified in a previous file or on the command line
   06xRevB_FastSpinROMSymbols.lib    _tmp.obj>" specifies ISA revision "C2800", which is not compatible with ISA
   06xRevB_FastSpinROMSymbols.lib    tmp.obj>" specifies ISA revision "C2800", which is not compatible with ISA
   06xRevB_FastSpinROMSymbols.lib    rams_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
   06xRevB_FastSpinROMSymbols.lib    otorParams_tmp.obj>" specifies ISA revision "C2800", which is not compatible
   with ISA revision "C2700" specified in a previous file or on the command
   line
   06xRevB_FastSpinROMSymbols.lib    l_tmp.obj>" specifies ISA revision "C2800", which is not compatible with ISA
   06xRevB_FastSpinROMSymbols.lib    IdleState_tmp.obj>" specifies ISA revision "C2800", which is not compatible
   line
请问是哪里出现问题?
看你的图好像导入的是ccs5的工程,ccs6的和ccs5的不兼容。你可以试着自己建立一个工程试一下  详情 回复 发表于 2016-3-14 16:49
1158
