CCS+C6678LE开发记录17:多核协作(OpenMP)示例更新
本次更新针对C6678多核图像处理示例mcip_omp_c6678中的一些细节问题进行修复。 另外PC端增加了C#版本GUI工具,详情见下图
替代了之前的简陋界面(操作稍显麻烦)
新的GUI工具操作简便,界面美观,功能也更加强大。 首先是打开图像,支持更多格式
打开图片之后,支持预览
开始传输数据之前请打开DSP
等待DSP初始化完成后,点击【TaskBegin】按钮开始 传输数据过程中能看到右下角的进度条指示
支持参数设定
目前仅做初步测试,也就设计了少数功能,更多功能待后期项目完善后再添加
测试结果输出如下(部分) - [C66xx_0]
- Multicore Image Processing using OpenMP
- Execute Task_create...
- Waiting for the start of the network...
- Execute NC_SystemOpen...
- Execute CfgNew...
- EVM in StaticIP mode at 192.168.2.100
- Set IP address of PC to 192.168.2.101
- PASS successfully initialized
- Ethernet subsystem successfully initialized
- Ethernet eventId : 48 and vectId (Interrupt) : 7
- Verify_Init: Expected 0 entry count for Queue number = 899, found 498 entries
- Registration of the EMAC Successful, waiting for link up ..
- IP Addr(1):192.168.2.100
- Execute NetworkOpen...
- NetworkOpen: Network started.
- Execute Mailbox_create...
- Wating for the request from PC...
- [--TASK EXECUTION 01--]
- @DataTrans: receiving source data from PC...
- @DataTrans: ImageSize = 1920 * 1080 = 2073600
- @DataTrans: sending message: SRCIMG_RECEIVED
- @Scheduler: received message: SRCIMG_RECEIVED
- @ImageProc: Image processing...
- @ImageProc: Image processing...Done.
- @Scheduler: sending message: IMGPROC_FINISHED
- @DataTrans: received message: IMGPROC_FINISHED
- @DataTrans: sending result data to PC...
- @DataTrans: sending message: SENDBACK_FINISHED
- @Scheduler: received message: SENDBACK_FINISHED
- Time used ImageProc: 338.336ms
- Time used WholeTask: 4531.708ms
- [--TASK EXECUTION 02--]
- @DataTrans: ImageSize = 2560 * 1600 = 4096000
- Time used ImageProc: 660.054ms
- Time used WholeTask: 7971.038ms
- [--TASK EXECUTION 03--]
- @DataTrans: ImageSize = 2336 * 4160 = 9717760
- Time used ImageProc: 1547.941ms
- Time used WholeTask: 17513.260ms
复制代码
