28335的最大工作频率是250M,其时钟有两种产生途径,第一是直接使用外部时钟(通过XCLKIN接入),第二种方法是在X1和X2引脚外接外部晶振或共振器。系统时钟框图如下:
上述过程产生CLKIN,直接供给CPU,CPU同时向外供给SYSCLKOUT给各个外设。SYSCLKOUT=SYSCLKIN.SYSCLK经过HISPCP LOSPCP的分频后可以送给各个外设,注意,HSPCLK和LSPCLK是独立设定的,也不一定存在。下面是一段初始化程序。
- void InitPll(Uint16 val, Uint16 divsel)
- // Make sure the PLL is not running in limp mode
- //若为1,检测时钟错误,未发现时钟
- if (SysCtrlRegs.PLLSTS.bit.MCLKSTS != 0)
- // Missing external clock has been detected
- // Replace this line with a call to an appropriate
- // SystemShutdown(); function.
- asm(" ESTOP0");
- // DIVSEL MUST be 0 before PLLCR can be changed from
- // 0x0000. It is set to 0 by an external reset XRSn
- // This puts us in 1/4
- //将分频设置为4,即CLKIN=1/4OSCCLK
- if (SysCtrlRegs.PLLSTS.bit.DIVSEL != 0) //判断,此位应为0,才能继续设置
- EALLOW;
- SysCtrlRegs.PLLSTS.bit.DIVSEL = 0;
- EDIS;
- // Change the PLLCR
- //结合上述设置 CLKIN=(OSCCLK * 10)/4
- if (SysCtrlRegs.PLLCR.bit.DIV != val)
- EALLOW;
- // Before setting PLLCR turn off missing clock detect logic
- SysCtrlRegs.PLLSTS.bit.MCLKOFF = 1; //关闭时钟错误检测
- SysCtrlRegs.PLLCR.bit.DIV = val; //设置PLL的乘因子
- EDIS;
- // Optional: Wait for PLL to lock.
- // During this time the CPU will switch to OSCCLK/2 until
- // the PLL is stable. Once the PLL is stable the CPU will
- // switch to the new PLL value.
- // This time-to-lock is monitored by a PLL lock counter.
- // Code is not required to sit and wait for the PLL to lock.
- // However, if the code does anything that is timing critical,
- // and requires the correct clock be locked, then it is best to
- // wait until this switching has completed.
- // Wait for the PLL lock bit to be set.
- // The watchdog should be disabled before this loop, or fed within
- // the loop via ServiceDog().
- // Uncomment to disable the watchdog
- DisableDog();
- //等待PLL稳定
- while(SysCtrlRegs.PLLSTS.bit.PLLLOCKS != 1)
- // Uncomment to service the watchdog
- // ServiceDog();
- EALLOW;
- SysCtrlRegs.PLLSTS.bit.MCLKOFF = 0; //使能时钟错误检测
- EDIS;
- // If switching to 1/2
- //传入参数为2,结合上述设置 CLKIN=(OSCCLK * 10)/2
- if((divsel == 1)||(divsel == 2)) //1为/4,2为/2
- EALLOW;
- SysCtrlRegs.PLLSTS.bit.DIVSEL = divsel;
- EDIS;
- // If switching to 1/1
- // * First go to 1/2 and let the power settle
- // The time required will depend on the system, this is only an example
- // * Then switch to 1/1
- if(divsel == 3) //只有直通方式或外部晶振方式才可设置此参数3
- EALLOW;
- SysCtrlRegs.PLLSTS.bit.DIVSEL = 2;
- DSP28x_usDelay(1500);
- SysCtrlRegs.PLLSTS.bit.DIVSEL = 3;
- EDIS;
复制代码 看门狗电路模块如下
关门狗电路设置一般如下:
- void DisableDog(void)
- EALLOW;
- SysCtrlRegs.WDCR= 0x0068;
- EDIS;
复制代码下面探讨一下如何配置外围系统的时钟 外设的时钟的总体框架为:
总体配置LOSPSP和HISPSP的代码如下
- SysCtrlRegs.HISPCP.all = 0x0000; // High speed clock = SYSCLKOUT/1
- SysCtrlRegs.LOSPCP.all = 0x0004; // Low speed clock= SYSCLKOUT/8
复制代码 对于xintf:
配置代码如下:
- XintfRegs.XINTCNF2.bit.XTIMCLK = 0; //XTIMCLK = SYSCLKOUT/1
- XintfRegs.XINTCNF2.bit.CLKMODE = 0; //XCLKOUT is equal to XTIMCLK
- XintfRegs.XINTCNF2.bit.CLKOFF = 0; //XCLKOUT is enabled. (default)
复制代码 配置ADC的代码如下:
- //The ADC module is clocked by the high-speed clock (HSPCLK)
- SysCtrlRegs.PCLKCR0.bit.ADCENCLK = 1; // ADC
复制代码 同理,对其他外设时钟的配置如下:
- SysCtrlRegs.PCLKCR0.bit.I2CAENCLK = 0; // I2C
- SysCtrlRegs.PCLKCR0.bit.SCIAENCLK = 1; // SCI-A
- SysCtrlRegs.PCLKCR0.bit.SCIBENCLK = 0; // SCI-B
- SysCtrlRegs.PCLKCR0.bit.SCICENCLK = 0; // SCI-C
- SysCtrlRegs.PCLKCR0.bit.SPIAENCLK = 1; // SPI-A
- SysCtrlRegs.PCLKCR0.bit.MCBSPAENCLK = 1; // McBSP-A
- SysCtrlRegs.PCLKCR0.bit.MCBSPBENCLK = 1; // McBSP-B
- SysCtrlRegs.PCLKCR0.bit.ECANAENCLK = 0; // eCAN-A
- SysCtrlRegs.PCLKCR0.bit.ECANBENCLK = 0; // eCAN-B
- SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0; // Disable TBCLK within the ePWM
- SysCtrlRegs.PCLKCR1.bit.EPWM1ENCLK = 1; // ePWM1
- SysCtrlRegs.PCLKCR1.bit.EPWM2ENCLK = 1; // ePWM2
- SysCtrlRegs.PCLKCR1.bit.EPWM3ENCLK = 0; // ePWM3
- SysCtrlRegs.PCLKCR1.bit.EPWM4ENCLK = 0; // ePWM4
- SysCtrlRegs.PCLKCR1.bit.EPWM5ENCLK = 1; // ePWM5
- SysCtrlRegs.PCLKCR1.bit.EPWM6ENCLK = 1; // ePWM6
- SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1; // Enable TBCLK within the ePWM
- SysCtrlRegs.PCLKCR1.bit.ECAP3ENCLK = 0; // eCAP3
- SysCtrlRegs.PCLKCR1.bit.ECAP4ENCLK = 0; // eCAP4
- SysCtrlRegs.PCLKCR1.bit.ECAP5ENCLK = 0; // eCAP5
- SysCtrlRegs.PCLKCR1.bit.ECAP6ENCLK = 0; // eCAP6
- SysCtrlRegs.PCLKCR1.bit.ECAP1ENCLK = 0; // eCAP1
- SysCtrlRegs.PCLKCR1.bit.ECAP2ENCLK = 0; // eCAP2
- SysCtrlRegs.PCLKCR1.bit.EQEP1ENCLK = 0; // eQEP1
- SysCtrlRegs.PCLKCR1.bit.EQEP2ENCLK = 0; // eQEP2
- SysCtrlRegs.PCLKCR3.bit.CPUTIMER0ENCLK = 1; // CPU Timer 0
- SysCtrlRegs.PCLKCR3.bit.CPUTIMER1ENCLK = 1; // CPU Timer 1
- SysCtrlRegs.PCLKCR3.bit.CPUTIMER2ENCLK = 1; // CPU Timer 2
- SysCtrlRegs.PCLKCR3.bit.DMAENCLK = 1; // DMA Clock
- SysCtrlRegs.PCLKCR3.bit.XINTFENCLK = 1; // XTIMCLK
- SysCtrlRegs.PCLKCR3.bit.GPIOINENCLK = 1; // GPIO input clock
复制代码 完整设置代码如下:
- void InitPeripheralClocks(void)
- EALLOW;
- // HISPCP/LOSPCP prescale register settings, normally it will be set to default values ???
- SysCtrlRegs.HISPCP.all = 0x0000; //分频值为此值乘2,0为1,分频值为2. ADC 60M, High speed clock = SYSCLKOUT/1
- SysCtrlRegs.LOSPCP.all = 0x0004; //分频值为此值乘2,0为1.SCI,SPI,McBsp 15M100 Low speed clock= SYSCLKOUT/8
- // XCLKOUT to SYSCLKOUT ratio. By default XCLKOUT = 1/4 SYSCLKOUT
- // XTIMCLK = SYSCLKOUT/2
- // XCLKOUT = XTIMCLK/2
- // Enable XCLKOUT
- // Peripheral clock enables set for the selected peripherals.
- // If you are not using a peripheral leave the clock off
- // to save on power.
- // Note: not all peripherals are available on all 2833x derivates.
- // Refer to the datasheet for your particular device.
- // This function is not written to be an example of efficient code.
- // *IMPORTANT*
- // The ADC_cal function, which copies the ADC calibration values from TI reserved
- // OTP into the ADCREFSEL and ADCOFFTRIM registers, occurs automatically in the
- // Boot ROM. If the boot ROM code is bypassed during the debug process, the
- // following function MUST be called for the ADC to function according
- // to specification. The clocks to the ADC MUST be enabled before calling this
- // function.
- // See the device data manual and/or the ADC Reference
- // Manual for more information.
- ADC_cal();
- EDIS;
复制代码
