4587|0
28335的mcbsp模拟spi驱动AD7606,读出数据始终是0 [复制链接]
用28335的mcbsp模拟spi驱动AD7606
这是用自带spi读数据的程序,好使
#define DUMMYDATA 0x5a5a
int16 AD7606_Get_Word(void)
    int16 rdata;
    SpiaRegs.SPICTL.bit.TALK = 0;              // 禁止发送功能
    SpiaRegs.SPITXBUF = DUMMYDATA;
    while(SpiaRegs.SPIFFRX.bit.RXFFST == 0 ) {};          //等待接收数据
    rdata = SpiaRegs.SPIRXBUF;
    return  rdata;
这是mcbsp读数据的程序
int16 Mcbsp_Get_Word(void)
    int16 rdata;
    CS_L();
        McbspaRegs.DXR1.all= 0x00;
    while( McbspaRegs.SPCR1.bit.RRDY == 0 ) {}         // Master waits until RX data is ready
    rdata = McbspaRegs.DRR1.all;                      // Then read DRR1 to complete receiving of data
    CS_H();
    return  rdata;
用逻辑分析发现,mcbsp模拟spi读出的数据始终是0,根本接收不到数据该怎么解决?有没有像spi一样,可以禁止发送功能的?
以下为mcbsp的配置程序
        McbspaRegs.SPCR2.all=0x0000;     // Reset FS generator, sample rate generator & transmitter
        McbspaRegs.SPCR1.all=0x0000;        // Reset Receiver, Right justify word, Digital loopback dis.
        McbspaRegs.PCR.all=0x0F08;           //(CLKXM=CLKRM=FSXM=FSRM= 1, FSXP = 1)
        McbspaRegs.SPCR1.bit.DLB = 0;        //为0则禁止回送,为1则使用回送功能
        McbspaRegs.SPCR1.bit.CLKSTP = 2;     // Together with CLKXP/CLKRP determines clocking scheme       时钟停止模式,有时钟延迟
        McbspaRegs.PCR.bit.CLKXP = 0;       // CPOL = 0, CPHA = 0 rising edge no delay上升沿发送
        McbspaRegs.PCR.bit.CLKRP = 0;        //下降沿接收
        McbspaRegs.RCR2.bit.RDATDLY=01;      // FSX setup time 1 in master mode. 0 for slave mode (Receive)
        McbspaRegs.XCR2.bit.XDATDLY=01;      // FSX setup time 1 in master mode. 0 for slave mode (Transmit)
        McbspaRegs.RCR1.bit.RWDLEN1=2;     // 32-bit word  RWDLEN1=101 32bit
        McbspaRegs.XCR1.bit.XWDLEN1=2;     // 32-bit word  RWDLEN1=010 16bit
        McbspaRegs.SRGR2.all=0x2000;          // CLKSM=1, FPER = 1 CLKG periods
     //   McbspaRegs.SRGR1.all= 0x000F;       // Frame Width = 1 CLKG period, CLKGDV=16
        McbspaRegs.SRGR1.bit.CLKGDV = 4; // CLKG frequency = LSPCLK/(CLKGDV+1)增加波特率,原先为1不好使
        McbspaRegs.SPCR2.bit.GRST=1;         // Enable the sample rate generator
        delay_loop();                        // Wait at least 2 SRG clock cycles
        McbspaRegs.SPCR2.bit.XRST=1;         // Release TX from Reset
        McbspaRegs.SPCR1.bit.RRST=1;         // Release RX from Reset
        McbspaRegs.SPCR2.bit.FRST=1;         // Frame Sync Generator reset
  1. bit.RXFFST == 0 ) {};          //等待接收数据
  2.     rdata = SpiaRegs.SPIRXBUF;
  3.     return  rdata;
  4. }
复制代码
