2789|1
530
【STM32F7英雄联盟大赛】多功能测试仪器-信号发生器部分的软件代码编写以及初步调试 [复制链接]
前言:今天来讲解一下这部分的软件代码测试和初步调试目的:利用初步的数据手册,进行代码编写和初步PCB调试,关于调试部分统一放在第五贴中;
代码编写参考材料:dds芯片手册;
注意事项在充分理解数据手册的基础上,进行PCB设计和严格参照数据手册进行代码编写;
废话不多说,直接上代码。
1.原始驱动代码:
  1. #include "driverlib.h"
  2. #define SET_FSYNC()        GPIO_setOutputHighOnPin(GPIO_PORT_P6,GPIO_PIN0)        //P6.0->FSYNC
  3. #define        CLR_FSYNC()        GPIO_setOutputLowOnPin(GPIO_PORT_P6,GPIO_PIN0)
  4. #define SET_SDO()        GPIO_setOutputHighOnPin(GPIO_PORT_P6,GPIO_PIN1)        //P6.1->SDATA
  5. #define CLR_SDO()        GPIO_setOutputLowOnPin(GPIO_PORT_P6,GPIO_PIN1)
  6. #define SET_SCL()        GPIO_setOutputHighOnPin(GPIO_PORT_P6,GPIO_PIN2)        //P6.2->SCLK
  7. #define CLR_SCL()        GPIO_setOutputLowOnPin(GPIO_PORT_P6,GPIO_PIN2)
  8. //Write AD9834 by 16 bit
  9. //data is written at the clock's falling edge
  10. void WriteToAD9834Word(unsigned short Buf)
  11. {
  12.        unsigned        short        ValueToWrite = 0;
  13.        //unsigned        char        i = 0;
  14.        unsigned char        j = 0;
  15.
  16.         SET_SCL();
  17.         CLR_FSYNC();                        //FSYNC become low, indicate the beginning of the write
  18.         ValueToWrite =        Buf;
  19.         for (j=0; j<16; j++)
  20.         {
  21.                 SET_SCL();
  22.                 if(0x8000 == (ValueToWrite & 0x8000))
  23.                 {
  24.                         SET_SDO();            //Wirte 1
  25.                 }
  26.                 else
  27.                 {
  28.                         CLR_SDO();            //Write 0
  29.                 }
  30.                 CLR_SCL();
  31.
  32.                 ValueToWrite <<= 1;        //Rotate data
  33.         }
  34.         SET_FSYNC();                          //FSYNC become high, indicate the end of the write
  35. }
  36. void main(void)
  37. {
  38.         //Stop WDT
  39.         WDT_A_hold(WDT_A_BASE);
  40.         //PA.x output
  41.         GPIO_setAsOutputPin(
  42.                 GPIO_PORT_P6,
  43.                 GPIO_PIN0 + GPIO_PIN1 + GPIO_PIN2
  44.                 );
  45.                 SET_SCL();
  46.         SET_FSYNC();
  47. //Write Sequence refer to Figure31,32 and Table 11 in the AD9834's datasheet
  48. //RESET: RESET=1,PIN/SW=0
  49.         WriteToAD9834Word(0X0100);//写控制寄存器,复位器件
  50. //Write a full 28-Bit Word to Frequency Register: B28=1, RESET=1
  51.         WriteToAD9834Word(0X2100);//写控制寄存器,复位器件,同时将B28=1可将一个完整字通过两次连续写入载入频率寄存器
  52. /************************************************************************************************************/
  53. //DB15  DB14  DB13  DB12  DB11  DB10    DB9    DB8     DB7    DB6       DB5      DB4      DB3  DB2   DB1   DB0
  54. //0      0    B28    HLB  FSEL  PSEL  PIN/SW  RESET  SLEEP1  SLEEP12  OPBITEN  SIGN/PIB  DIV2   0    MODE   0
  55. /************************************************************************************************************/
  56. //        1          1       1           0
  57. //Frequency0//PSEL=0, PIN/SW=0
  58.
  59.         WriteToAD9834Word(0X599A);//0101 1001 1001 1010 //750KHz Output, 75MHz MCLK  14LSB
  60.         WriteToAD9834Word(0X4666);//0100 0110 0110 0110           //14MSB
  61. //Frequency1
  62.         WriteToAD9834Word(0XB5C3);//WriteToAD9834Word(0XB5C3);        1011        //100kHz Output, 10MHz MCLK
  63.         WriteToAD9834Word(0X80A3);;//WriteToAD9834Word(0X80A3);
  64. //Phase0 and Phase1
  65.         WriteToAD9834Word(0XC000);
  66.         WriteToAD9834Word(0XE000);
  67. //Select the Frequency Source and CLEAR RESET: RESET BIT=0, FSEL=0,PSEL=0
  68.         //WriteToAD9834Word(0X0000);
  69. //Select the Frequency Source and CLEAR RESET: RESET BIT=0, FSEL=1,PSEL=1
  70.         // WriteToAD9834Word(0X0C00); //正弦波
  71.         //WriteToAD9834Word(0X0C02); //三角波
  72.        WriteToAD9834Word(0X0C38);
  73.         //while(1);
  74.
  75.         //Enter LPM4 w/interrupts enabled
  76.         __bis_SR_register(LPM4_bits + GIE);
  77.         //For debugger
  78.         __no_operation();
  79. }
复制代码
2.stm32代码:
头文件
  1. #ifndef _FACTION_H_
  2. #define _FACTION_H_
  3. #include "stm32f7xx_hal.h"
  4. //函数发生器
  5. #define SDATA(x)   (GPIOB->ODR = ((GPIOB->ODR>>15)&0X01)? GPIOB->ODR&GPIOB->ODR&~(1<<15):GPIOB->ODR|(x<<15))//PB15
  6. #define SCLK(x)    (GPIOI->ODR = ((GPIOI->ODR>>1)&0X01) ? GPIOI->ODR&GPIOI->ODR&~(1<<1):GPIOI->ODR|(x<<1))//PI1
  7. #define FSELECT(x) (GPIOI->ODR = ((GPIOI->ODR>>0)&0X01) ? GPIOI->ODR&GPIOI->ODR&~(1<<0):GPIOI->ODR|(x<<0))//PI0
  8. #define PSELECT(x) (GPIOA->ODR = ((GPIOA->ODR>>15)&0X01) ? GPIOA->ODR&GPIOA->ODR&~(1<<15):GPIOA->ODR|(x<<15))//PA15
  9. #define FSYNC(x)   (GPIOI->ODR = ((GPIOI->ODR>>2)&0X01) ? GPIOI->ODR&GPIOI->ODR&~(1<<2):GPIOI->ODR|(x<<2))//PI2
  10. #define RESET(x)   (GPIOA->ODR = ((GPIOA->ODR>>0)&0X01) ? GPIOA->ODR&GPIOA->ODR&~(1<<0):GPIOA->ODR|(x<<0))//PA0
  11. #define SJ  0X0C02//三角波
  12. #define Sin 0X0C00//正弦波
  13. void Faction_Test(unsigned short datas);
  14. #endif
复制代码
主函数
  1. #include "faction.h"
  2. void functionGenerator_GPIO_Init(void)
  3. {
  4.    //FSELECT-PI0,PSELECT-PA15,SI,SCK共用了,FSYNC-PI2,RESET-PA0
  5.          RCC->AHB1ENR   |= 1<<8;//GPIOI
  6.          GPIOI->MODER   &= 0XFFFFFFCC;
  7.          GPIOI->MODER   |= 0X00000011;//通用推完输出
  8.          GPIOI->OSPEEDR &= 0XFFFFFFCC;
  9.          GPIOI->OSPEEDR |= 0X00000000;//GPIO高速输出
  10.          GPIOI->PUPDR   &= 0XFFFFFFCC; //GPIO无上下拉
  11.
  12.          RCC->AHB1ENR   |= 1<<0;//GPIOA
  13.          GPIOB->MODER   &= 0X3FFFFFFC;
  14.          GPIOB->MODER   |= 0X40000001;//通用推完输出
  15.          GPIOB->OSPEEDR &= 0X3FFFFFFC;
  16.          GPIOB->OSPEEDR |= 0XC0000000;//GPIO高速输出
  17.          GPIOB->PUPDR   &= 0X3FFFFFFC; //GPIO无上下拉
  18. }
  19. //Write AD9834 by 16 bit
  20. //data is written at the clock's falling edge
  21. void WriteToAD9834Word(unsigned short Buf)
  22. {
  23.   unsigned        short        ValueToWrite = 0;
  24.   //unsigned        char        i = 0;
  25.   unsigned char        j = 0;
  26.
  27.         SCLK(1);
  28.   FSYNC(0);        //FSYNC become low, indicate the beginning of the write
  29.         ValueToWrite =        Buf;
  30.         for (j=0; j<16; j++)
  31.         {
  32.                 SCLK(1);
  33.                 if(0x8000 == (ValueToWrite & 0x8000))
  34.                 {
  35.                         SDATA(1);            //Wirte 1
  36.                 }
  37.                 else
  38.                 {
  39.                         SDATA(0);            //Write 0
  40.                 }
  41.                 SCLK(0);
  42.                 ValueToWrite <<= 1;        //Rotate data
  43.         }
  44.         FSYNC(1);                                  //FSYNC become high, indicate the end of the write
  45. }
  46. void Faction_Test(unsigned short datas)
  47. {
  48.         functionGenerator_GPIO_Init();
  49.         SCLK(1);
  50.   FSYNC(1);
  51. //Write Sequence refer to Figure31,32 and Table 11 in the AD9834's datasheet
  52. //RESET: RESET=1,PIN/SW=0
  53.         WriteToAD9834Word(0X0100);//写控制寄存器,复位器件
  54. //Write a full 28-Bit Word to Frequency Register: B28=1, RESET=1
  55.         WriteToAD9834Word(0X2100);//写控制寄存器,复位器件,同时将B28=1可将一个完整字通过两次连续写入载入频率寄存器
  56. /************************************************************************************************************/
  57. //DB15  DB14  DB13  DB12  DB11  DB10    DB9    DB8     DB7    DB6       DB5      DB4      DB3  DB2   DB1   DB0
  58. //0      0    B28    HLB  FSEL  PSEL  PIN/SW  RESET  SLEEP1  SLEEP12  OPBITEN  SIGN/PIB  DIV2   0    MODE   0
  59. /************************************************************************************************************/
  60. //        1          1       1           0
  61. //Frequency0//PSEL=0, PIN/SW=0
  62.
  63.         WriteToAD9834Word(0X599A);//0101 1001 1001 1010 //750KHz Output, 75MHz MCLK  14LSB
  64.         WriteToAD9834Word(0X4666);//0100 0110 0110 0110           //14MSB
  65. //Frequency1
  66.         WriteToAD9834Word(0XB5C3);//WriteToAD9834Word(0XB5C3);        1011        //100kHz Output, 10MHz MCLK
  67.   WriteToAD9834Word(0X80A3);;//WriteToAD9834Word(0X80A3);
  68. //Phase0 and Phase1
  69.         WriteToAD9834Word(0XC000);
  70.         WriteToAD9834Word(0XE000);
  71. //Select the Frequency Source and CLEAR RESET: RESET BIT=0, FSEL=0,PSEL=0
  72. //WriteToAD9834Word(0X0000);
  73. //Select the Frequency Source and CLEAR RESET: RESET BIT=0, FSEL=1,PSEL=1
  74. //WriteToAD9834Word(0X0C00); //正弦波
  75. //WriteToAD9834Word(0X0C02); //三角波
  76. //WriteToAD9834Word(0X0C38);
  77.   WriteToAD9834Word(datas);
  78.          //while(1);
  79.
  80.    //Enter LPM4 w/interrupts enabled
  81.    //__bis_SR_register(LPM4_bits + GIE);
  82.    //For debugger
  83.    //__no_operation();
  84. }
复制代码
查看本帖全部内容,请登录或者注册
此帖出自stm32/stm8论坛
530
V 自己留个脚印
此帖出自stm32/stm8论坛
直播时间:3月12日(周三)上午10:00
直播奖励:多功能榨汁机、蓝牙音箱、手机支架
