6681|9
51单片机60秒倒计时报警 [复制链接]
紧急求助 各路大神求帮忙啊 刚学单片机 不会弄 老师要用C++源程序的  要求是 按下开关后 显示器进入60秒倒计时 计时完后蜂鸣器响  无其他有求   大神们 帮一下哈
此帖出自51单片机论坛
如果你还觉得复杂,就一个IO不停地翻也行啊  详情 回复 发表于 2016-2-16 12:23
4008
51能用C++?用什么软件啊,没搞过呢学习一下
此帖出自51单片机论坛
98
3471
建议还是用C语言实现吧。单片机点亮两个数码管,仿真嘛,直接用单片机io口串电阻连数码管。写个定时器程序。蜂鸣器也好弄。
此帖出自51单片机论坛
929
/* --- STC MCU Limited ---------------------------------------------*/
/* --- STC89-90xx Series 16-bit Timer Demo -------------------------*/
/* --- Mobile: (86)13922805190 -------------------------------------*/
/* --- Fax: 86-0513-55012956,55012947,55012969 ---------------------*/
/* --- Tel: 86-0513-55012928,55012929,55012966----------------------*/
/* --- Web: www.STCMCU.com -----------------------------------------*/
/* --- Web: www.GXWMCU.com -----------------------------------------*/
/* If you want to use the program or the program referenced in the  */
/* article, please specify in which data and procedures from STC    */
#include "reg51.h"
typedef unsigned char BYTE;
typedef unsigned int WORD;
/* define constants */
#define FOSC 11059200L
#define T1MS (65536-FOSC/12/1000)   //1ms timer calculation method in 12T mode
/* define SFR */
sbit TEST_LED = P1^0;               //work LED, flash once per second
/* define variables */
WORD count;                         //1000 times counter
/* Timer0 interrupt routine */
void tm0_isr() interrupt 1 using 1
    TL0 = T1MS;                     //reload timer0 low byte
    TH0 = T1MS >> 8;                //reload timer0 high byte
    if (count-- == 0)               //1ms * 1000 -> 1s
        count = 1000;               //reset counter
        TEST_LED = ! TEST_LED;      //work LED flash
/* main program */
void main()
    TMOD = 0x01;                    //set timer0 as mode1 (16-bit)
    TL0 = T1MS;                     //initial timer0 low byte
    TH0 = T1MS >> 8;                //initial timer0 high byte
    TR0 = 1;                        //timer0 start running
    ET0 = 1;                        //enable timer0 interrupt
    EA = 1;                         //open global interrupt switch
    count = 0;                      //initial counter
    while (1);                      //loop
这是stc官网上的例程,里面有一秒了,至于怎么倒计时,你自己应该可以搞定吧。
此帖出自51单片机论坛
58
你们老师是考验你啊
此帖出自51单片机论坛
75
查看本帖全部讨论,请登录或者注册
此帖出自51单片机论坛
75
查看本帖全部讨论,请登录或者注册
此帖出自51单片机论坛
613
查看本帖全部讨论,请登录或者注册
此帖出自51单片机论坛
个人签名我是一头搞电子的猪,猪是一种好色的动物,猪八戒就是代表.
613
查看本帖全部讨论,请登录或者注册
此帖出自51单片机论坛
