2952|0
CCS+C6678LE开发记录10:(图像)数据处理与传输框架 [复制链接]
探索了这么久也该上一点料,本文关注PC<-->DSP数据处理与传输的简单框架。
这个框架其实也很简单,具体描述如下:
1.PC端通过ETH0发送(图像)数据到DSP
2.DSP收到完整数据后进行处理(Image Processing...)
3.DSP端数据处理完毕后将数据发回给PC
4.PC端收到发回的处理结果,然后保存
下面是一段代码,数据处理执行的操作很简单:对图像像素值取补
newValue=255-oldValue
  1. int udpTransferTask( SOCKET s, UINT32 unused )
  2. {
  3.     printf("TASK execution %d\n",++task_counter);
  4.
  5.     struct timeval tv;
  6.     tv.tv_sec  = 1;
  7.     tv.tv_usec = 0;
  8.     setsockopt(s,SOL_SOCKET,SO_SNDTIMEO,&tv,sizeof(tv));
  9.     setsockopt(s,SOL_SOCKET,SO_RCVTIMEO,&tv,sizeof(tv));
  10.
  11.     struct sockaddr_in sin1;
  12.     int sz=sizeof(sin1);
  13.     int hlen=strlen(reply);
  14.     int nr,total=0;
  15.     HANDLE hBuffer=NULL;
  16.     unsigned char* pBuf=NULL;
  17.
  18.     int width,height,size;
  19.     int i,n=sizeof(int);
  20.     unsigned char* ptr=NULL;
  21.
  22.     // Image width
  23.     recvncfrom( s, (void**)&pBuf, 0, (PSA)&sin1, &sz, &hBuffer );
  24.     recvncfree( hBuffer );
  25.     ptr=(unsigned char*)&width;
  26.     for(i=0;i<n;++i) ptr[i]=pBuf[i];
  27.
  28.     // Image height
  29.     recvncfrom( s, (void**)&pBuf, 0, (PSA)&sin1, &sz, &hBuffer );
  30.     recvncfree( hBuffer );
  31.     ptr=(unsigned char*)&height;
  32.     for(i=0;i<n;++i) ptr[i]=pBuf[i];
  33.
  34.     // Image data size
  35.     size=width*height;
  36.
  37.     printf("Image Size: %d * %d\n",width,height);
  38.
  39.     // Data buffer
  40.     unsigned char* data=(unsigned char*)malloc(size);
  41.     if(data==NULL)
  42.     {
  43.         printf("Failed to allocate memory!\n");
  44.         return 2;
  45.     }
  46.
  47.     ptr=data;
  48.     while(1)
  49.     {
  50.         nr=recvncfrom( s, (void**)&pBuf, 0, (PSA)&sin1, &sz, &hBuffer );
  51.         if(nr<=0) break;
  52.         total+=nr;
  53.         for(i=0;i<nr;++i)
  54.         {
  55.             ptr[i]=pBuf[i];
  56.         }
  57.         ptr+=nr;
  58.         sendto( s, reply, hlen, 0, (PSA)&sin1, sz );
  59.         recvncfree( hBuffer );
  60.     }
  61.
  62.     if(total!=size)
  63.     {
  64.         free(data);
  65.         size=0;
  66.         printf("Data transfer is imcomplete!\n");
  67.         return 1;
  68.     }
  69.
  70.     processDataFrame(data,width,height);
  71.
  72.     total=0;
  73.     int unit=64;
  74.     int loop=size/unit;
  75.     int residue=size-loop*unit;
  76.     pBuf=data;
  77.     for(i=1;i<=loop;++i)
  78.     {
  79.         nr=sendto(s,pBuf,unit,0,(PSA)&sin1, sz);
  80.         pBuf+=unit;
  81.         total+=nr;
  82.     }
  83.     if(residue>0)
  84.     {
  85.         nr=sendto(s,pBuf,residue,0,(PSA)&sin1, sz);
  86.         total+=nr;
  87.     }
  88.     printf("Finished sending back %dB.\n",total);
  89.
  90.     free(data);
  91.     return 1;
  92. }
  93.
  94. void processDataFrame(unsigned char* data,int width,int height)
  95. {
  96.     printf("Processing data...");
  97.     int i, size=width*height;
  98.     unsigned char tmp;
  99.     for(i=0;i<size;++i)
  100.     {
  101.         tmp=data[i];
  102.         data[i]=255-tmp;
  103.     }
  104.     printf("Finished.\n");
  105. }
复制代码
发回数据时建议设置更小的分片大小,这里设置为64字节,实测效果尚可。
可能是因为C6678发送数据的机制不同,发送数据块不能太大,否则接收端不能正常接收。
经过几次测试发现这个示例尚存一些bug,例如发回的数据中明显存在数据失真问题
(原图1920*1080 RGB彩色,处理后为灰度图,下面的截图都缩放至800*450了)
原图(缩小)
结果(缩小)
可以看到很多“条带”,这些都是数据失真,初步估计是DSP处理过程中,发回数据出现问题。
关于这个问题,稍后会进一步分析。
关于博文开头提到的处理框架,通过这个测试用例可以看出来,基本可行。
