3073|0
用gdb-7.9编译出支持tic6x的gdb,调试程序时会挂掉 [复制链接]
本人用的gdb-7.9, --target=tic6x-elf ,编译出来的gdb 运行c6713的一个测试代码test.out(是elf格式的文件)时,
运行 ./gdb.exe   test.out
GNU gdb (GDB) 7.9
Copyright (C) 2015 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "--host=i686-pc-mingw32 --target=tic6x-elf".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
BFD: c:\work_space\618demo_test\618demo1_test.out: warning: sh_link not set for
section `.c6xabi.exidx'
Reading symbols from 618demo1_test.out...read symbols ok.
done.
到done的时候就会出现断错误并挂掉。
有高手曾编译出可以正确调试tic6713的gdb吗? 求交流。
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 12
