2111|2
转手FPGA开发板 [复制链接]
全新开发板DE2 EP2C35F672C6 有意者可联系QQ:1693771436    价格在1200左右
DE2 Development and Education Board
Altera Cyclone® II 2C35 FPGA device
Altera Serial Configuration device - EPCS16
USB Blaster (on board) for programming and user API control; both JTAG and Active Serial(AS) programming modes are supported
512-Kbyte SRAM
8-Mbyte SDRAM
4-Mbyte Flash memory (1 Mbyte on some boards)
SD Card socket
4 pushbutton switches
18 toggle switches• 18 red user LEDs
9 green user LEDs
50-MHz oscillator and 27-MHz oscillator for clock sources
24-bit CD-quality audio CODEC with line-in, line-out, and microphone-in jacks
VGA DAC (10-bit high-speed triple DACs) with VGA-out connector
TV Decoder (NTSC/PAL) and TV-in connector
10/100 Ethernet Controller with a connector
USB Host/Slave Controller with USB type A and type B connectors
RS-232 transceiver and 9-pin connector
PS/2 mouse/keyboard connector
IrDA transceiver
Two 40-pin Expansion Headers with diode protection
此帖出自淘e淘论坛
如果是原装板,这个价格是不错的。  详情 回复 发表于 2015-7-17 12:07
裸片初长成(高级)
如果是原装板,这个价格是不错的。
此帖出自淘e淘论坛
绝对原版,我是在学校,教育部之前向高校分发的
此帖出自淘e淘论坛
