3405|0
在DM8168的DVRRDK中添加采集和显示的各种分辨率的支持 [复制链接]
在DVRRDK中,系统提供了多个分辨率的标准(SYSTEM_STD_1080P_60、VSYS_STD_1080P_60、FVID2_STD_1080P_60),为用户层、link层、系统底层都定义了一套,而且支持程度不一,所以在添加的过程中,有点点繁琐
先说在hdvpss中添加输出分辨率
添加分辨率信息,时钟格式等信息和描述信息
ti_tools/hdvpss/dvr_rdk_hdvpss/packages/ti/psp/vps/drivers/src/fvid2_drvMgr.c
/** \brief FVID2 standard information table. */
static FVID2_ModeInfo gFdmStdInfoTable[] =
    /* Standard, FrameWidth, FrameHeight, ScanFormat, PixelClock (KHz), FPS,
       Reserved */
    {FVID2_STD_NTSC,             720u,  480u, FVID2_SF_INTERLACED,   27000u, 30u, 0u},
    {FVID2_STD_PAL,              720u,  576u, FVID2_SF_INTERLACED,   27000u, 25u, 0u},
    {FVID2_STD_480I,             720u,  480u, FVID2_SF_INTERLACED,   27000u, 30u, 0u},
    {FVID2_STD_576I,             720u,  576u, FVID2_SF_INTERLACED,   27000u, 25u, 0u},
/** \brief Standard string table. */
static Fdm_StdString gFdmStdStrTable[] =
    {FVID2_STD_NTSC,                    "NTSC"                      },
    {FVID2_STD_PAL,                     "PAL"                       },
    {FVID2_STD_480I,                    "480I"                      },
    {FVID2_STD_576I,                    "576I"                      },
    {FVID2_STD_CIF,                     "CIF"                       },
添加视频格式
ti_tools/hdvpss/dvr_rdk_hdvpss/packages/ti/psp/vps/fvid2.h
*  \brief Video standards.
typedef enum
    FVID2_STD_NTSC = 0u,
    /**< 720x480 30FPS interlaced NTSC standard. */
    FVID2_STD_PAL,
    /**< 720x576 30FPS interlaced PAL standard. */
    FVID2_STD_480I,
    /**< 720x480 30FPS interlaced SD standard. */
    FVID2_STD_576I,
    /**< 720x576 30FPS interlaced SD standard. */
添加分辨率的时序详细信息
ti_tools/hdvpss/dvr_rdk_hdvpss/packages/ti/psp/vps/hal/src/vpshal_hdvenc.c
HdVenc_StdModeInfo HdVencStdModeInfo[] = {
    {{FVID2_STD_1080P_60, 1920, 1080, FVID2_SF_PROGRESSIVE, 148500, 60,
        88, 148, 44, 4, 36, 5}, 3, 8, 0},
    {{FVID2_STD_1080P_50, 1920, 1080, FVID2_SF_PROGRESSIVE, 148500, 50,
        528, 148, 44, 4, 36, 5}, 3, 7, 0},
    {{FVID2_STD_1080P_30, 1920, 1080, FVID2_SF_PROGRESSIVE, 74250, 30,
        88, 148, 44, 4, 36, 5}, 3, 4, 0},
    {{FVID2_STD_1080P_25, 1920, 1080, FVID2_SF_PROGRESSIVE, 74250, 30,
        528, 148, 44, 4, 36, 5}, 3, 4, 0},
    {{FVID2_STD_1080P_24, 1920, 1080, FVID2_SF_PROGRESSIVE, 74250, 30,
        638, 148, 44, 4, 36, 5}, 3, 4, 0},
在MCFW中相关位置的调整
添加
VSYS_STD_xxxx格式分辨率
dvr_rdk/mcfw/interfaces/common_def/ti_vsys_common_def.h
    \brief Possible Video Standards - NTSC, PAL, CIF, etc
typedef enum
    VSYS_STD_NTSC = 0u,
    VSYS_STD_PAL,
    VSYS_STD_480I,
    VSYS_STD_576I,
添加
SYSTEM_STD_xxxx格式分辨率
dvr_rdk/mcfw/interfaces/link_api/system_const.h
    \brief Video standards..
    SUPPORTED in ALL platforms
typedef enum
    SYSTEM_STD_NTSC = 0u,
    SYSTEM_STD_PAL,
    SYSTEM_STD_480I,
    SYSTEM_STD_576I,
这里会对枚举的分辨率进行一次检验,应当多个格式标准的问题,所以添加分辨率的时候需要同步添加
dvr_rdk/mcfw/src_bios6/links_common/system/system_common.c
* enum's defined in system_const.h MUST match the enum's defined in FVID2
* driver's since they are passed directly to the driver without conversion
* Anytime a new const is added in system_const.h, MAKE sure to put a assert
* check in this function */
int System_enumAssertCheck()
    UTILS_COMPILETIME_ASSERT(SYSTEM_STD_NTSC == FVID2_STD_NTSC);
    UTILS_COMPILETIME_ASSERT(SYSTEM_STD_PAL == FVID2_STD_PAL);
    UTILS_COMPILETIME_ASSERT(SYSTEM_STD_480I == FVID2_STD_480I);
    UTILS_COMPILETIME_ASSERT(SYSTEM_STD_576I == FVID2_STD_576I);
    UTILS_COMPILETIME_ASSERT(SYSTEM_STD_CIF == FVID2_STD_CIF);
    UTILS_COMPILETIME_ASSERT(SYSTEM_STD_HALF_D1 == FVID2_STD_HALF_D1);
    UTILS_COMPILETIME_ASSERT(SYSTEM_STD_D1 == FVID2_STD_D1);
在这个里面还添加下面三个函数的支持
UInt32 Vsys_getStdSize(UInt32 std, UInt32 *width, UInt32 *height);
UInt32 Vsys_getStdRate(UInt32 std, UInt32 *frameRate);
UInt32 Vsys_isStdInterlaced(UInt32 std);
修改display输出的时候获取到正确的分辨率值
dvr_rdk/mcfw/src_bios6/links_m3vpss/display/displayLink_drv.c
Int32 DisplayLink_drvDisplayCreate(DisplayLink_Obj * pObj)
在视频输出的时候启动的时候会获取视频的时钟频率
dvr_rdk/mcfw/src_bios6/links_m3vpss/system/system_dctrl.c
Int32 System_getClk(UInt32 displayRes)
    Int32 clkValue = VSYS_STD_MAX;
    switch(displayRes) {
        case VSYS_STD_1080P_60:
        case VSYS_STD_1080P_50:
            clkValue = 148500u;
        break;
更新一下模式
dvr_rdk/mcfw/src_bios6/links_m3vpss/system/system_dctrl_modeInfo.c
Int32 System_getVencMode(Int32 resolution)
    Int32 vencMode;
    switch(resolution){
        case VSYS_STD_NTSC:
            vencMode = FVID2_STD_NTSC;
        break;
        case VSYS_STD_PAL:
            vencMode = FVID2_STD_PAL;
        break;
获取视频输出的分辨率
dvr_rdk/mcfw/src_bios6/links_m3vpss/system/system_m3vpss.c
Int32 System_getOutSize(UInt32 outRes, UInt32 * width, UInt32 * height)
    Vsys_getStdSize(outRes, width, height);
    return 0;
在DVRRDK中常用的视频格式基本是支持的,如果需要支持更多的分辨率,大家可以参考一下;
只是系统整个框架比较的大,一时没法完整的完成;
直播时间:4月22日(周二)10:00
直播奖励:京东卡、蓝牙温湿度计、定制水杯
