2148|0
86
USB开发--DEVICE_INFO [复制链接]
程序如下:
typedef struct _DEVICE_INFO
  uint8_t USBbmRequestType;       /* bmRequestType */
  uint8_t USBbRequest;            /* bRequest */
  uint16_t_uint8_t USBwValues;         /* wValue */
  uint16_t_uint8_t USBwIndexs;         /* wIndex */
  uint16_t_uint8_t USBwLengths;        /* wLength */
  uint8_t ControlState;           /* of type CONTROL_STATE */
  uint8_t Current_Feature;
  uint8_t Current_Configuration;   /* Selected configuration */
  uint8_t Current_Interface;       /* Selected interface of current configuration */
  uint8_t Current_AlternateSetting;/* Selected Alternate Setting of current
                                     interface*/
  ENDPOINT_INFO Ctrl_Info;
}DEVICE_INFO;
uint8_t In0_Process(void)
  uint32_t ControlState = pInformation->ControlState;//请问大神:这里的ControlState是什么意思?该如何理解结构体DEVICE_INFO???请大神指教~~~
  if ((ControlState == IN_DATA) || (ControlState == LAST_IN_DATA))
    DataStageIn();
    /* ControlState may be changed outside the function */
  else if (ControlState == WAIT_STATUS_IN)
    if ((pInformation->USBbRequest == SET_ADDRESS) &&
        (Type_Recipient == (STANDARD_REQUEST | DEVICE_RECIPIENT)))
      SetDeviceAddress(pInformation->USBwValue0);
      pUser_Standard_Requests->User_SetDeviceAddress();
    (*pProperty->Process_Status_IN)();
    ControlState = STALLED;
  else
  pInformation->ControlState = ControlState;
  return Post0_Process();
此帖出自stm32/stm8论坛
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 13
