2706|8
37
关于stm8的编程问题 [复制链接]
这是STVD中的程序怎么把它移植到IAR中,主要是STVD编译的东西反应速度过慢,而且当程序过于复杂会使得程序的屏幕的显示效果不如人意。
#include"stm8s105s4.h"
#include"stm8s_gpio.h"
#include"stdio.h"
#define uchar unsigned char
#define uint unsigned int
_Bool   LCD_RS  @PC_ODR:2;
_Bool   LCD_RW  @PC_ODR:3;
_Bool   LCD_EN  @PE_ODR:6;
_Bool   LCD_PSB  @PC_ODR:1;
_Bool   WELK   @PD_ODR:2;
_Bool   DULK   @PD_ODR:3;
_Bool   DOT    @PC_ODR:1;
extern const uchar  dis1[] = {"顺哥电子设计承接"};
extern const uchar  dis2[]= {"各种单片机项目"};
extern const uchar  dis3[]= {"51 PIC AVR 430等"};
extern const uchar  dis4[] = {"sgqrs_lab@163"};
void delayNOP(void)
{_asm("nop");_asm("nop");_asm("nop");_asm("nop");_asm("nop");}
void GPIO_Init1(void)
        PB_DDR= 0xff;
        PB_CR1 = 0xff;
        PC_DDR= 0x0e;
        PC_CR1 = 0x0e;
        PE_DDR= 0x40;
        PE_CR1 = 0x40;
        PD_DDR=0x0c;
        PD_CR1=0x0c;
void delay(int ms)
    while(ms--)
      uchar i;
          for(i=0;i<250;i++);
void delay0(uchar x)    //x*0.14MS
  uchar i;
  while(x--)
  for (i = 0; i<113; i++);
void lcd_wdat(const uchar dat)
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_EN = 0;
    PB_ODR= dat;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
                        delay(100);
void lcd_wcmd(const uchar cmd)
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_EN = 0;
    _asm("nop");
    _asm("nop");
    PB_ODR  = cmd;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
                delay(100);
void lcd_pos(uchar X,uchar Y)
   uchar  pos;
   if (X==0)
     {X=0x80;}
   else if (X==1)
     {X=0x90;}
   else if (X==2)
     {X=0x88;}
   else if (X==3)
     {X=0x98;}
   pos = X+Y ;
   lcd_wcmd(pos);     //显示地址
void lcd_init(void)
    LCD_PSB = 1;         //并口方式
    lcd_wcmd(0x34);      //扩充指令操作
    delay(5);
    lcd_wcmd(0x30);      //基本指令操作
    delay(5);
    lcd_wcmd(0x0C);      //显示开,关光标
    delay(5);
    lcd_wcmd(0x01);      //清除LCD的显示内容
    delay(5);
  main()
    uchar i;
                GPIO_Init1();
        PB_ODR = 0xff;
        WELK = 0;
         DULK = 1;
    delay(10);                 //延时
    lcd_init();                //初始化LCD
    lcd_pos(0,0);             //设置显示位置为第一行的第1个字符
     i = 0;
    while(dis1[i] != '\0')
     {                         //显示字符
       lcd_wdat(dis1[i]);
       i++;
    lcd_pos(1,0);             //设置显示位置为第二行的第1个字符
     i = 0;
    while(dis2[i] != '\0')
       lcd_wdat(dis2[i]);      //显示字符
       i++;
         lcd_pos(2,0);             //设置显示位置为第三行的第1个字符
     i = 0;
    while(dis3[i] != '\0')
       lcd_wdat(dis3[i]);      //显示字符
       i++;
         lcd_pos(3,0);             //设置显示位置为第四行的第1个字符
     i = 0;
    while(dis4[i] != '\0')
       lcd_wdat(dis4[i]);      //显示字符
       i++;
     while(1);
此帖出自stm32/stm8论坛
不好意思 给你发一个例子 你按照例程修改一下, _asm("nop"); 修改asm("nop");  详情 回复 发表于 2015-7-6 15:02
37
_asm("nop");这句在IAR中不能编译,PB_DDR= 0xff;这句需要建立一个.c文件定义函数引脚才能使用,但在IAR中不知道是我定义的问题还是怎么回事就是整个工程环境都出问题了,就连之前能用的程序编译都有问题。
此帖出自stm32/stm8论坛
37
更主要的问题是STVD用不了我之情的tim2中断程序。就算经过更该后也无法正常使用。对此我表示特别的郁闷。
此帖出自stm32/stm8论坛
2131
至上芯片
可以上传工程帮你修改一下
此帖出自stm32/stm8论坛
这个程序能在stvd下工作,不过速度有点慢。  详情 回复 发表于 2015-6-2 08:39
个人签名处处留心皆学问!
37
daicheng 发表于 2015-6-2 06:56
可以上传工程帮你修改一下
test2.zip
289.76 KB, 下载次数: 6
此帖出自stm32/stm8论坛
刚才上传错了现在是正确的。  详情 回复 发表于 2015-6-2 09:17
37
刚才上传错了现在是正确的。
此帖出自stm32/stm8论坛
37
查看本帖全部讨论,请登录或者注册
此帖出自stm32/stm8论坛
37
查看本帖全部讨论,请登录或者注册
此帖出自stm32/stm8论坛
2131
至上芯片
查看本帖全部讨论,请登录或者注册
STM8SVLDISCOVERY_Adc.rar
5.71 MB, 下载次数: 3
此帖出自stm32/stm8论坛
个人签名处处留心皆学问!
