1998|0
MSP430G2553单通道重复测温度的程序温度显示一直都为0 [复制链接]
本程序用的是软件触发内部测温通道,问题应该在中断程序中,请大家帮忙看看
整个程序太多,所以这里省去了显示程序,有关的部分程序如下:
#define num 5
long IntDeg;
static unsigned long results[num]={0};
void main()
        WDTCTL=WDTPW+WDTHOLD;
        ADC10_graceInit();
        LCD_Init();
    while(1)
      ADC10CTL0 |= ENC + ADC10SC;
      LCD_Display();
void ADC10_graceInit(void)
    /* USER CODE START (section: ADC10_graceInit_prologue) */
    /* User initialization code */
    /* USER CODE END (section: ADC10_graceInit_prologue) */
    /* disable ADC10 during initialization */
    ADC10CTL0 &= ~ENC;
     * Control Register 0
     * ~ADC10SC -- No conversion
     * ~ENC -- Disable ADC
     * ~ADC10IFG -- Clear ADC interrupt flag
     * ~ADC10IE -- Disable ADC interrupt
     * ADC10ON -- Switch On ADC10
     * REFON -- Enable ADC reference generator
     * REF2_5V -- Set reference voltage generator = 2.5V
     * ~MSC -- Disable multiple sample and conversion
     * ~REFBURST -- Reference buffer on continuously
     * ~REFOUT -- Reference output off
     * ~ADC10SR -- Reference buffer supports up to ~200 ksps
     * ADC10SHT_3 -- 64 x ADC10CLKs
     * SREF_5 -- VR+ = VREF+ and VR- = VREF-/ VeREF-
     * Note: ~ indicates that has value zero
    ADC10CTL0 = ADC10ON | REFON | REF2_5V | ADC10SHT_3 | SREF_5;
     * Control Register 1
     * ~ADC10BUSY -- No operation is active
     * CONSEQ_2 -- Repeat single channel
     * ADC10SSEL_0 -- ADC10OSC
     * ADC10DIV_3 -- Divide by 4
     * ~ISSH -- Input signal not inverted
     * ~ADC10DF -- ADC10 Data Format as binary
     * SHS_0 -- ADC10SC
     * INCH_10 -- Temperature Sensor
    ADC10CTL1 = CONSEQ_2 | ADC10SSEL_0 | ADC10DIV_3 | SHS_0 | INCH_10;
    /* Software delay for REFON to settle */
    __delay_cycles(30000);
    /* enable ADC10 */
    ADC10CTL0 |= ENC;
    /* USER CODE START (section: ADC10_graceInit_epilogue) */
    /* User code */
    /* USER CODE END (section: ADC10_graceInit_epilogue) */
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR(void)
{    __delay_cycles(1000);
    static unsigned char index=0;
    results[index++]=ADC10MEM;
    if(index==num)
    { unsigned char i;
          unsigned long sum=0;
          index=0;
          ADC10CTL0 &= ~ENC;
          for(i=1;i<=num;i++)
                  sum=sum+results[i];
          sum=sum/num;
          IntDeg= (sum*7042/1024 - 2777)*10;    //IntDeg用于显示程序中去
此帖出自单片机论坛
