3903|7
37
关于stm8驱动12864的问题 [复制链接]
/* MAIN.C file
* Copyright (c) 2002-2005 STMicroelectronics
//#include"stm8s.h"
#include"stm8s105s4.h"
#include"stdio.h"
#define uchar unsigned char
#define uint unsigned int
_Bool   LCD_RS  @PC_ODR:2;
_Bool   LCD_RW  @PC_ODR:3;
_Bool   LCD_EN  @PE_ODR:6;
_Bool   LCD_PSB  @PC_ODR:1;
_Bool   LCD_RST  @PE_ODR:5;
_Bool   DOT    @PC_ODR:1;
extern const uchar  dis1[] = {"顺哥电子设计承接"};
extern const uchar  dis2[]= {"各种单片机项目"};
extern const uchar  dis3[]= {"51 PIC AVR 430等"};
extern const uchar  dis4[] = {"sgqrs_lab@163"};
void delayNOP(void)
{_asm("nop");_asm("nop");_asm("nop");_asm("nop");_asm("nop");}
void delaynms(unsigned int di) //延时
unsigned int da,db;
for(da=0;da    for(db=0;db<10;db++);
void GPIO_Init1(void)
        PB_DDR= 0xff;
        PB_CR1 = 0xff;
        PC_DDR= 0x0e;
        PC_CR1 = 0x0e;
        PE_DDR= 0x60;
        PE_CR1 = 0x60;
void delay(int ms)
    while(ms--)
      uchar i;
          for(i=0;i<250;i++);
void delay0(uchar x)    //x*0.14MS
  uchar i;
  while(x--)
  for (i = 0; i<113; i++);
//12864检查状态
void Check12864state(void)
        PB_ODR=0xff;
        LCD_EN = 0;
        LCD_RS = 0;
        LCD_RW = 1;
        LCD_EN = 1;
        while((PB_IDR&0x80)==0x80);//等待空闲
        LCD_EN = 0;
        LCD_RS = 1;
        LCD_RW = 0;
void lcd_wdat(const uchar dat)
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_EN = 0;
    PB_ODR= dat;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
                        delay(100);
void lcd_wcmd(const uchar cmd)
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_EN = 0;
    _asm("nop");
    _asm("nop");
    PB_ODR  = cmd;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
                delay(100);
void lcd_pos(uchar X,uchar Y)
   uchar  pos;
   if (X==0)
     {X=0x80;}
   else if (X==1)
     {X=0x90;}
   else if (X==2)
     {X=0x88;}
   else if (X==3)
     {X=0x98;}
   pos = X+Y ;
   lcd_wcmd(pos);     //显示地址
void lcd_init(void)
    LCD_PSB = 1;         //并口方式
    LCD_RST=1;
                LCD_RST=0;
                LCD_RST=1;
    lcd_wcmd(0x34);      //扩充指令操作
    delay(5);
    lcd_wcmd(0x30);      //基本指令操作
    delay(5);
    lcd_wcmd(0x0C);      //显示开,关光标
    delay(5);
    lcd_wcmd(0x01);      //清除LCD的显示内容
    delay(5);
                lcd_wcmd(0x06);
/*指定在资料写入或读取时,光标的移动方向,DDRAM的地址计数器(AC)加1。*/
                delay(5);
void lcd_init2(void)           //LCD显示图片(扩展)初始化程序
  delaynms(10); //启动等待,等LCM讲入工作状态
  lcd_wcmd(0x34);
  lcd_wcmd(0x36);  //扩充指令集
  lcd_wcmd(0x3E);   //(DL=8BITS,RE=1,G=1)
  lcd_wcmd(0x02);  //清DDRAM
/*****************图像显示***************************/
void photodisplay(uchar *bmp)
  uchar i,j;
  lcd_wcmd(0x34);//写数据时,关闭图像显示
  for(i=0;i<32;i++)
   lcd_wcmd(0x80+i);//先写入水平坐标值
   lcd_wcmd(0x80);//写入垂直坐标值
   for(j=0;j<16;j++)
      lcd_wdat(*bmp++);
   delaynms(1);
  /********显示下半屏内容*****************/
  for(i=0;i<32;i++)
   lcd_wcmd(0x88);//写入垂直坐标值
   for(j=0;j<16;j++)
     lcd_wdat(*bmp++);
   delaynms(1);
  lcd_wcmd(0x36);//写完数据,开图像显示
  lcd_wcmd(0x30);//回到基本指令集
void lcdtest(void)        //图形方式下屏幕全黑
unsigned char i,j;
for(i=0;i<32;i++)
  { lcd_wcmd(0x80+i);lcd_wcmd(0x80);
    for(j=0;j<16;j++) lcd_wdat(0xff);
for(i=0;i<32;i++)
  { lcd_wcmd(0x80+i);lcd_wcmd(0x88);
void lcdcls(void)  //图形方式下清屏
unsigned char i,j;
for(i=0;i<32;i++)
    for(j=0;j<16;j++) lcd_wdat(0x00);
for(i=0;i<32;i++)
    for(j=0;j<16;j++) lcd_wcmd(0x00);
uchar readdat(void)
        uchar Rdata;
        Check12864state();
        PB_ODR=0xff;
        LCD_RS = 1;
        LCD_RW = 1;
  LCD_EN = 0;
        delayNOP();
        LCD_EN = 1;
        delayNOP();
        PB_DDR= 0x00;
        PB_CR1 = 0x00;
        Rdata=PB_IDR;
        LCD_EN = 0;
        delayNOP();
        return Rdata;
//填充GDRAM数据
void fill_GDRAM(uchar dat)//dat为填充数据
        uchar i,j,k;
        uchar GDRAM_X=0x80;//GDRAM水平地址
        uchar GDRAM_Y=0x80;//GDRAM垂直地址
        for(i=0;i<2;i++)
          for(i=0;i<2;i++)
             for(k=0;k<8;k++)
               lcd_wcmd(0x34);
                                 lcd_wcmd(GDRAM_Y+j);
                                 lcd_wcmd(GDRAM_X+k);
               lcd_wdat(dat);
                                lcd_wdat(dat);
GDRAM_X=0x88;
lcd_wcmd(0x36);
lcd_wcmd(0x30);
void Fill_point(uchar x,uchar y,uchar color)
        uchar x_Dyte,x_byte;//定义地址的字节在哪一位
        uchar y_Dyte,y_byte;
        uchar GDRAM_hbit,GDRAM_lbit;
        lcd_wcmd(0x36);
        //--XY坐标互换,及普通的X,Y坐标
        x_Dyte=x/16;//计算在18个字节中的哪一位
        x_byte=x&0x0f;//计算该字节中的哪一位
        y_Dyte=y/32;//0为上屏,1位下屏
        y_byte=y&0x1f;//计算在0——31中的哪一行
        lcd_wcmd(0x80+y_byte);//设定行地址(Y坐标),即垂直地址
        lcd_wcmd(0x80+x_Dyte+8*y_Dyte);//设定列地址(x坐标),并通8*y_Dyte选定上下屏,及水平地址
        readdat();
        GDRAM_hbit=readdat();
        GDRAM_lbit=readdat();
        delay(1);
        delay(10);
        if(x_byte<8)//判定其再高八位还是在低八位
         if(color==1)
         lcd_wdat(GDRAM_hbit|(0x01<<(7-x_byte)));
    else
     lcd_wdat(GDRAM_hbit|(0x01<<(~(7-x_byte))));
     lcd_wdat(GDRAM_lbit);//显示GDRA区低八位
        if(x_byte>=8)
        lcd_wdat(GDRAM_hbit);
        if(color==1)
                lcd_wdat(GDRAM_hbit|(0x01<<(15-x_byte)));
        else
                lcd_wdat(GDRAM_hbit|(0x01<<(~(15-x_byte))));
lcd_wcmd(0x30);
  main()
    uchar i;
                GPIO_Init1();
        //PB_ODR = 0xff;
        //WELK = 0;
        //DULK = 1;
        delay(10);                 //延时
        lcd_init();                //初始化LCD
        //lcdtest();
        //lcdcls();
        fill_GDRAM(0x00);
        Fill_point(1,1,1);
        while (1);
这段程序哪错了。
此帖出自stm32/stm8论坛
根据我调屏的经验,你试一下你画某个坐标点的函数,看看正常吗? https://bbs.eeworld.com.cn/thread-459436-1-1.html  详情 回复 发表于 2015-5-29 15:41
37
显示是这样的的,不知道是哪的问题。
此帖出自stm32/stm8论坛
确认一下驱动有没有问题,如果没有问题, 改一下字模的生成方式看看。  详情 回复 发表于 2015-5-29 14:18
1944
32
d907814868 发表于 2015-5-29 13:56
显示是这样的的,不知道是哪的问题。
确认一下驱动有没有问题,如果没有问题,
改一下字模的生成方式看看。
此帖出自stm32/stm8论坛
37
azhiking 发表于 2015-5-29 14:18
确认一下驱动有没有问题,如果没有问题,
改一下字模的生成方式看看。
驱动应该没问题,能实现字符的显示,只是不知道为什么不能画点。
此帖出自stm32/stm8论坛
855
此帖出自stm32/stm8论坛
个人签名作为一个菜逼,干货并没有多少。唯一会的就是水,所以回帖水分大。望见谅!
37
你这个延时函数是精确延时吗?
此帖出自stm32/stm8论坛
37
d907814868 发表于 2015-5-29 22:07
你这个延时函数是精确延时吗?
好像还是不行,估计是哪个读操作函数有问题。应为我去掉哪个读函数后有显示。
此帖出自stm32/stm8论坛
如果是测忙程序,该怎么改?  详情 回复 发表于 2015-5-29 22:51
37
如果是测忙程序出问题了,该怎么改?
此帖出自stm32/stm8论坛
