2920|6
跪求大神帮忙看看程序哪里有问题,为什么输出都是U??? [复制链接]
以下是testbench程序(附件为所有的源程序):
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_textio.all;
use ieee.numeric_std.all;
use std.textio.all;
entity tb_med is
end tb_med;
architecture beh_tb of tb_med is
file input_file: text open read_mode is "input4tb.dat";
file output_file: text open write_mode is "output_tb.dat";
  component med_filter is
  port (
        clk: in std_logic;
        reset: in std_logic;
        data_in: in std_logic_vector(7 downto 0);
        data_out: out std_logic_vector(7 downto 0)
  end component med_filter;
  signal data_in: std_logic_vector(7 downto 0);
  signal data_out: std_logic_vector(7 downto 0);
        signal clk: std_logic := '0' ;
  signal reset: std_logic := '1';
  --signal data_valid: std_logic := '0';
  begin
    duv: med_filter
    port map (data_in => data_in,
              clk     => clk,
              reset   => reset,
              data_out => data_out
    reset_gen: process
    begin
        for n in 0 to 3 loop
           wait until falling_edge(clk);
        end loop;
        reset <= '0' ;
    end process reset_gen;
    clock: process
      constant half_clock_period: time := 5 ns;  -- for 100MHz
    begin
      clk <= '1';
      wait for half_clock_period;
      clk <= '0';
    end process clock;
process
variable inline, outline : line;
variable input : std_logic_vector(7 downto 0);
variable output : std_logic_vector(7 downto 0);
begin
  while not endfile(input_file) loop
        if (reset = '1') then
                        data_in <= (others => '0');
        else
                        readline(input_file, inline);
                        read(inline, input);
                        data_in <= input;
                        --data_valid <= '1';
                        output := data_out;
      write(outline, output);
      writeline(output_file, outline);
        end if;
  wait until clk = '1';
  end loop;
  --if rising_edge(clk) then
  --end if;
end process;
end beh_tb;
median_filter.rar
3.72 KB, 下载次数: 0
此帖出自FPGA/CPLD论坛
在定义信号和变量的时候赋给个初值就可以了。或者在modelsim里右键,force或者clock里填写 缺少初值,有的会仿真的时候自动生成,你不用管了。 有的如果不给赋初值,仿真结果会不对,显示一条红长线,这就需要赋初值啦。   详情 回复 发表于 2015-5-23 23:57
大神求帮忙!!
此帖出自FPGA/CPLD论坛
58
没有赋初值??
此帖出自FPGA/CPLD论坛
都说输出U是没有赋初值,但是我是新手,我不知道到底在哪该赋初值,求指点
此帖出自FPGA/CPLD论坛
testbench里,程序里,或者modelsim里都可以啊!  详情 回复 发表于 2015-5-21 01:35
58
此帖出自FPGA/CPLD论坛
我不知道在程序的哪个地方要赋初值,也不知道是哪个信号缺少初值。。
此帖出自FPGA/CPLD论坛
在定义信号和变量的时候赋给个初值就可以了。或者在modelsim里右键,force或者clock里填写 缺少初值,有的会仿真的时候自动生成,你不用管了。 有的如果不给赋初值,仿真结果会不对,显示一条红长线,这就需要  详情 回复 发表于 2015-5-23 23:57
58
此帖出自FPGA/CPLD论坛
