3475|0
187
STM32F103R8T6 串口3 能发送 但不能进行中断接收 是什么问题? [复制链接]
如题:
主程序如下
int main(void)
#ifdef DEBUG
        debug();
#endif
        /* System Clocks Configuration */
        RCC_Configuration();
        GPIO_Configuration();
        NVIC_Configuration();
        USART3_Configuration();
        TIM_Configuration();
        TIM1_Configuration();
        GPIO_Deint();
        TXD_EXTENSION_ADDRESS = READ_adderss();
        GPIO_WriteBit(GPIOB, GPIO_Pin_5, Bit_RESET); //LED1  LIGHT
        RX_485;
        while(1)
                //Send_DATA_RS485();
中断程序如下
void USART3_IRQHandler(void)
        if(USART_GetITStatus(USART3, USART_IT_RXNE) == SET)
          USART_ClearITPendingBit(USART3,USART_IT_RXNE);
                                        GPIO_WriteBit(GPIOD, GPIO_Pin_2, Bit_RESET); //LED1  LIGHT
          RXDBUFFER[RxBufferSize_connter] = USART_ReceiveData(USART3);
          RxBufferSize_connter = RxBufferSize_connter + 1;
          if(RxBufferSize_connter == 26)
                                        RxBufferSize_connter = 0;
          if((RXDBUFFER[5] == 0XFF) && (RXDBUFFER[6] == 0X55) && (RXDBUFFER[7] == 0X5A)
             && (RXDBUFFER[8] == 0XA5) && (RXDBUFFER[9] == 0XAA) && (RXDBUFFER[11] == 0X90))
               RXD_FLAG = 1;
                                                         GPIO_WriteBit(GPIOD, GPIO_Pin_2, Bit_SET); //LED1  LIGHT
usart3配置如下
        USART_InitTypeDef USART_InitStructure;
        USART_InitStructure.USART_BaudRate = 9600;
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        USART_InitStructure.USART_StopBits = USART_StopBits_1;
        USART_InitStructure.USART_Parity = USART_Parity_No;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
        /* Configure the USARTx */
        USART_Init(USART3, &USART_InitStructure);
        /* Enable the USART Receive interrupt: this interrupt is generated when the USARTx receive data register is not empty */
        USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
        /* Enable USARTx */
        USART_Cmd(USART3, ENABLE);
nvic 如下
        NVIC_InitTypeDef NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
        /* Set the Vector Table base location at 0x20000000 */
        NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
        /* Set the Vector Table base location at 0x08000000 */
        NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
        /* Configure the NVIC Preemption Priority Bits */
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
        NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQChannel;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;//USART3_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_InitStructure.NVIC_IRQChannel = TIM1_UP_IRQChannel;//TIM1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQChannel;//TIM2_IRQn;
        NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQChannel;//TIM3_IRQn;
        NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQChannel;//TIM4_IRQn;
        NVIC_Init(&NVIC_InitStructure);
rcc 如下
        ErrorStatus HSEStartUpStatus;
        /* RCC system reset(for debug purpose) */
        RCC_DeInit();
        /* Enable HSE */
        RCC_HSEConfig(RCC_HSE_ON);
        /* Wait till HSE is ready */
        HSEStartUpStatus = RCC_WaitForHSEStartUp();
        if(HSEStartUpStatus == SUCCESS)
        /* HCLK = SYSCLK */
        RCC_HCLKConfig(RCC_SYSCLK_Div1);
        /* PCLK2 = HCLK */
        RCC_PCLK2Config(RCC_HCLK_Div1);
        /* PCLK1 = HCLK/2 */
        RCC_PCLK1Config(RCC_HCLK_Div2);
        /* Flash 2 wait state */
        FLASH_SetLatency(FLASH_Latency_2);
        /* Enable Prefetch Buffer */
        FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
        /* PLLCLK = 8MHz * 9 = 72 MHz */
        RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
        /* Enable PLL */
        RCC_PLLCmd(ENABLE);
        /* Wait till PLL is ready */
        while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
        /* Select PLL as system clock source */
        RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
        /* Wait till PLL is used as system clock source */
        while(RCC_GetSYSCLKSource() != 0x08)
        /*Enble GPIOA、GPIOB、GPIOC、GPIOD*/
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB
                                                        | RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD
                                                        | RCC_APB2Periph_TIM1,
                                                        ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2 | RCC_APB1Periph_TIM3
                                                        | RCC_APB1Periph_TIM4 | RCC_APB1Periph_USART3,
                                                        ENABLE);
gpio配置如下
        /*Configure PB10  as output for  USART3_TXD; RS485_TXD*/
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 ;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        /*Configure PB11  as input for  USART3_RXD; RS485_RXD*/
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 ;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
        /*Configure PB12  as output for  USART3_DIR; RS485_DIR*/
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 ;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
请高手指点!!
此帖出自stm32/stm8论坛
【直播时间】5月28日(周三)上午10:00
