2694|1
2700
初学altera FPGA [复制链接]
刚刚开始接触fpga,用quartus11.1,报错:
Error (199067): Quartus II software currently does not support the generation of timing analysis netlists for Cyclone IV E device family
Error: Quartus II 64-Bit EDA Netlist Writer was unsuccessful. 1 error, 0 warnings
        Error: Peak virtual memory: 313 megabytes
        Error: Processing ended: Thu Feb 12 00:37:55 2015
        Error: Elapsed time: 00:00:00
        Error: Total CPU time (on all processors): 00:00:01
Error (293001): Quartus II Full Compilation was unsuccessful. 3 errors, 9 warnings
请问是什么问题?用的是论坛的fpga助学板
此帖出自FPGA/CPLD论坛
2700
现在怀疑是软件的问题,是不是我没有装这个EDA工具呢?求大神解惑,第一次用alter和fpga
此帖出自FPGA/CPLD论坛
