OPA847有多么给力,我们来看一下参数: FEATURES
● HIGH GAIN BANDWIDTH: 3.9GHz
● LOW INPUT VOLTAGE NOISE: 0.85nV/√Hz
● VERY LOW DISTORTION: –105dBc (5MHz)
● HIGH SLEW RATE: 950V/μs
● HIGH DC ACCURACY: V IO < ±100μV
● LOW SUPPLY CURRENT: 18.1mA
● LOW SHUTDOWN POWER: 2mW
● STABLE FOR GAINS ≥ 12
FEATURES DESCRIPTION
The LMH™6502 is a wideband DC coupled 23• V S = ±5V, TA = 25°C, RF = 1kΩ, RG = 174Ω, RL = 100Ω, AV = AV(MAX) = 10 Typical Values Unless differential input voltage controlled gain stage
followed by a high-speed current feedback Op Amp Specified.
which can directly drive a low impedance load. Gain • -3dB BW: 130MHz adjustment range is more than 70dB for up to 10MHz. • Gain Control BW: 100MHz
Maximum gain is set by external components and the • Adjustment Range (Typical Over Temp): 70dB gain can be reduced all the way to cut-off. Power • Gain Matching (Limit): ±0.6dB consumption is 300mW with a speed of 130MHz.
Output referred DC offset voltage is less than 350mV • Slew Rate: 1800V/μs
over the entire gain control voltage range. Device-to- • Supply Current (No Load): 27mA device Gain matching is within ±0.6dB at maximum • Linear Output Current: ±75mA gain. Furthermore, gain at any VG is tested and the
tolerance is ensured. The output current feedback Op • Output Voltage (RL = 100Ω): ±3.2V
Amp allows high frequency large signals (Slew Rate • Input Voltage Noise: 7.7nV/√Hz = 1800V/μs) and can also drive heavy load current • Input Current Noise: 2.4pA/√Hz (75mA). Differential inputs allow common mode • THD (20MHz, RL = 100Ω, VO = 2VPP): −53dBc rejection in low level amplification or in applications
where signals are carried over relatively long wires.
