2402|2
5310
453
[TI首届低功耗设计大赛]+学习型红外遥控 [复制链接]
1、硬件
学习红外:开启一体化红外接收头电源,然后TA0。2捕获输入信号
发送红外:TA1.1产生占空比1/4的38K信号,然后与TA0。1的包络信号
2、程序
发送部分初始化
//初始化
                    //TA0.1 / P1.0:包络信号
                    //TA1.1 / P1.2:38K载波信号
                    GPIO_setAsPeripheralModuleFunctionOutputPin(
                                                            GPIO_PORT_P1,
                                                            GPIO_PIN0 ,
                                                            GPIO_PRIMARY_MODULE_FUNCTION
                                                        GPIO_PORT_P1,
                                                        GPIO_PIN2 ,
                    //禁用GPIO电源默认高阻抗模式激活以前配置的端口设置
                    PMM_unlockLPM5(__MSP430_BASEADDRESS_PMM_FRAM__);
                    //Start timer TA1.1 / P1.2
                    //38kHz 1/4 duty-cycle carrier waveform length setting空比载波波形长度设置
                    TIMER_A_configureUpMode(        TIMER_A1_BASE,
                                                           TIMER_A_CLOCKSOURCE_SMCLK,
                                                    TIMER_A_CLOCKSOURCE_DIVIDER_2,  //8M/2=4M
                                                    105,//TIMER_PERIOD,//周期=时钟 / 频率
                                                     TIMER_A_TAIE_INTERRUPT_DISABLE,
                                                      TIMER_A_CCIE_CCR0_INTERRUPT_DISABLE,
                                                       TIMER_A_DO_CLEAR
                    TIMER_A_startCounter(   TIMER_A1_BASE,
                                                      TIMER_A_UP_MODE
                    //Initialize compare mode to generate PWM1
                    TIMER_A_initCompare(TIMER_A1_BASE,
                                                     TIMER_A_CAPTURECOMPARE_REGISTER_1,
                                            TIMER_A_CAPTURECOMPARE_INTERRUPT_DISABLE,
                                            TIMER_A_OUTPUTMODE_RESET_SET,        // output mode: reset/set   38K载波
                                            26//DUTY_CYCLE1
                    //TA0.1 / P1.0
                    TIMER_A_configureUpMode(        TIMER_A0_BASE,
        TIMER_A_CLOCKSOURCE_SMCLK,        //TA0CTL |= TASSEL_2
        640,//TIMER_PERIOD,//周期=时钟 / 频率 TA0CCR0 = 640;
                                                              TIMER_A_CCIE_CCR0_INTERRUPT_ENABLE,//TA0CCTL0 = CCIE;//中断使能
                                                             TIMER_A_DO_CLEAR        //TA0CTL |=   TACLR;
                    TIMER_A_startCounter(           TIMER_A0_BASE,
        TIMER_A_UP_MODE //TA0CTL |= MC_1
                    TIMER_A_initCompare(                TIMER_A0_BASE,
        TIMER_A_OUTPUTMODE_OUTBITVALUE,        //TA0CCTL2 |= OUTMOD_0; output mode: output   输出模式 包络信号
                                                        0//the initial time of TA0 should be longer than TA1TA0的初始时间应该比TA1更长
接收初始化
//TA0.2 / P1.1:接收信号
                        // 配置 IR 输入脚
                        //        P1DIR &= ~BIT1;        //Set P1.6 as input
                        //        P1SEL0|=  BIT1;        //Set P1.6 as TA0.2 input
                        GPIO_setAsPeripheralModuleFunctionInputPin(
        GPIO_PORT_P1,
        GPIO_PIN1 ,
                        //Timer_A clock source select : SMCLK
                        //Continuous mode: Timer counts up to 0FFFFh
                        //Timer_A clear
                         //TA0CTL = TASSEL__SMCLK |ID__2| MC__CONTINUOUS | TACLR;
                        TIMER_A_configureContinuousMode(         TIMER_A0_BASE,
        TIMER_A_CLOCKSOURCE_SMCLK,                //TA0CTL = TASSEL_2
        TIMER_A_DO_CLEAR                                   //TA0CTL =   TACLR
        TIMER_A_CONTINUOUS_MODE        //TA0CTL = MC_2
                        //Capture mode : Capture on both rising and falling edges
                        //Synchronize capture source : Synchronous capture
                        //Capture/compare input select : CCIxA
                        //Capture mode : Capture mode
                        //Capture/compare interrupt enable : Interrupt enabled
                        // TA0CCTL2 = CM_3 | CCIS_0 | SCS | CAP | CCIE;
                        TIMER_A_initCapture(        TIMER_A0_BASE,
        TIMER_A_CAPTURECOMPARE_REGISTER_2,
        TIMER_A_CAPTUREMODE_RISING_AND_FALLING_EDGE,
        TIMER_A_CAPTURE_INPUTSELECT_CCIxA,
        TIMER_A_CAPTURE_SYNCHRONOUS,
        TIMER_A_CAPTURECOMPARE_INTERRUPT_ENABLE,
3、界面
4、操作效果
遗憾!虽然信号产生,输入捕获都可以了,可是我最终没有完美的完成学习接收,转发!
这个板子好漂亮的说。  详情 回复 发表于 2015-1-4 11:13
赞赏
查看全部赞赏
1305
这个板子好漂亮的说。
呵呵,谢谢 活动前期花了太多时间在硬件设计方面了!  详情 回复 发表于 2015-1-4 11:18
5310
453
RE: [TI首届低功耗设计大赛]+学习型红外遥控
yang_alex 发表于 2015-1-4 11:13
这个板子好漂亮的说。
呵呵,谢谢
活动前期花了太多时间在硬件设计方面了!
