4978|3
6105
【Nucleo深度评测】之一X-CUBE-BLE1 V2.2+OSXSmartConnPS.zip [复制链接]
新下了两个包,好像都是12月5号的,反正比原来的新。原来的好像是6月份的,应该是ST的新的更新,不敢私藏。于是上传。
x-cube-ble1.zip (6.39 MB, 下载次数: 31) The X-CUBE-BLE1 software package is an expansion for STM32Cube. This software provides drivers running on STM32 for STM's BlueNRG Bluetooth Low Energy device. It is built on top of STM32Cube software technology that ease portability across different STM32 microcontrollers.
X-CUBE-BLE1 software features:
  • Complete middleware to build applications using BlueNRG network processor.
  • Easy portability across different MCU families thanks to STM32Cube.
  • Sample applications that the developer can use to start experimenting with the code.
  • References to free Android and iOS App that can be used along with the sample applications.
  • Free user-friendly license terms.
  • Examples implementation available for X-NUCLEO-IDB04A1 STM32 expansion board plugged on top of one NUCLEO-F401RE or NUCLEO-L053R8.
The figure below shows the overall architecture.
有好几个例子,还有虚拟串口的。哈哈。
OSXSmartConnPS.zip (2.67 MB, 下载次数: 18)
这是后面这个包的说明
The Open.RF v1.0 package is an add-on to the X-CUBE-BLE1 v2.2 software
This package contains the BlueNRG library for BLE Profiles and a sample
application.
For instructions on how to use it, see the 'How to Install' section below and
then the Projects\Multi\Applications\Profiles_LP_RTC\readme.txt in this
package.
Contents
This package contains:
* readme.txt ................ This readme.txt
* Documentation
   * open.rf.chm ............. Documentation of the source code included in
                               this package
* Middlewares\ST\STM32_BlueNRG
   * BlueNRG_Lib ............. BlueNRG library for BLE profiles
   * Profile_Framework ....... BlueNRG library include files
* Projects\Multi\Applications\Profiles_LP_RTC
   * Profiles_LP_RTC ......... Sample application showing how to use BLE
                               Profiles (see the included readme.txt for
                               description)
* Utilities\Android_Software\Profiles_Central
   * STM32_BLE_Toolbox.apk ... App for Android to be used with
                               Profiles_LP_RTC sample application
   * license.txt ............. License terms and conditions
   * readme.txt .............. STM32_BLE_Toolbox App description and usage
                               instructions
How to Install
* OPTION A
  1. Download and install the X-CUBE-BLE1 v2.2 from http://www.st.com
  2. Select all the folders contained in this package and 'drag
     and drop' them in your X-CUBE-BLE1 folder. Then click "yes" to confirm
     that you want to merge the selected folders with the ones in your
     X-CUBE-BLE1.
  3. Enjoy!
* OPTION B
  2. copy $THIS_PACKAGE\Documentation\open.rf.chm
     to   $X-CUBE-BLE1_INST_PATH\Documentation\.
  3. copy $THIS_PACKAGE\Middlewares\ST\STM32_BlueNRG\BlueNRG_Lib
     to   $X-CUBE-BLE1_INST_PATH\Middlewares\ST\STM32_BlueNRG\.
  4. copy $THIS_PACKAGE\Middlewares\ST\STM32_BlueNRG\Profile_Framework
  5. copy $THIS_PACKAGE\Projects\Multi\Applications\Profiles_LP_RTC
     to   $X-CUBE-BLE1_INST_PATH\Projects\Multi\Applications\.
  6. copy $THIS_PACKAGE\Utilities
     to   $X-CUBE-BLE1_INST_PATH\.
  7. Enjoy!
结论:ST蛮够努力的!!!!!!
此帖出自stm32/stm8论坛
FREESCALE的技术支持不到位,根本就没有把中国尤其是深圳当做他们的重点。一个问题几天都不能解决,我们的要求是客户提出问题,不在国家法定节假日的话,最长12小时必须解决。否则这样的供应商直接出局。ST及其代理商的技术支持就很好。还有,价格因素。  详情 回复 发表于 2014-12-25 10:44
推荐
besk 发表于 2014-12-25 10:28
我挺ST。我的新产品不再考虑FREESCALE了,以后就是ST了
为什么呢?
此帖出自stm32/stm8论坛
535
此帖出自stm32/stm8论坛
为什么呢?  详情 回复 发表于 2014-12-25 10:29
个人签名做适合中国宝贝的教育机器人
535
此帖出自stm32/stm8论坛
个人签名做适合中国宝贝的教育机器人
