2324|4
麻烦大家帮我看看 fpga microcode 设计烧到板子无法运行 [复制链接]
麻烦各位大神帮我看看。
--Project3 --Toplevel.vhd --Boyuan Chen --12.11.14
-- top level
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity Toplevel is
         port (SW    : in  std_logic_vector(3 downto 0);
          Clock : in  std_logic;
          Reset : in  std_logic;
                         DY    : in  std_logic_vector(3 downto 0);
          addx  : out std_logic_vector(3 downto 0);
          LED   : out std_logic_vector(3 downto 0));
end Toplevel;
architecture Behavioral of Toplevel is
        signal clk_temp : std_logic;
        component Microcode is
        end component;
        component clockdiv is
                 Generic (NN :integer :=1 );
                 Port (clkin,clr : in  STD_LOGIC;
                                  clkout : out  STD_LOGIC);
        end component;
begin
        U1: Microcode port map(SW=>SW, Clock=>clk_temp, reset=>reset,
        DY=>DY, addx=>addx, LED=>LED);
        U2: ClockDiv  port map(clkin=>clock, clr=>reset, clkout=>clk_temp);
end Behavioral;
这是我的顶层
此帖出自FPGA/CPLD论坛
--project3 --Microcode --Boyuan Chen --12.1.14
--Data Path & Controler
library IEEE;
use IEEE.STD_LOGIC_arith.ALL;
use IEEE.STD_LOGIC_unsigned.ALL;
entity Microcode is
end Microcode;
architecture Behavioral of Microcode is
    signal addi, dx: integer range 0 to 3;
    signal Test : std_logic_vector(1 downto 0);
    signal Natt : std_logic_vector(3 downto 0);
    signal EnA, EnN, EnL,Wr : std_logic;
    signal EnC : std_logic_vector(1 downto 0);
    signal SelMux, SelAlu : std_logic_vector (1 downto 0);
    signal Zf, Cf: std_logic;
    signal X, Y, F, Kval, RegA, RegC, RegN, RegL: std_logic_vector(3 downto 0);
    subtype MREC is std_logic_vector(19 downto 0);
    type MSTORE is array (natural range<>) of MREC;
    constant MROM : MSTORE :=(
         "00"&"0000"&'0'&"00"&'1'&'0'&"11"&"10"&"0000"&'0',
         "11"&"0000"&'0'&"00"&'0'&'0'&"10"&"11"&"0001"&'0',
         "00"&"0000"&'1'&"00"&'0'&'0'&"10"&"10"&"0001"&'0',
         "00"&"0000"&'0'&"00"&'1'&'1'&"10"&"10"&"0000"&'0',
         "10"&"0000"&'0'&"00"&'0'&'0'&"00"&"00"&"0000"&'0',
         "00"&"0000"&'0'&"01"&'0'&'0'&"10"&"00"&"0000"&'0',
         "00"&"0000"&'0'&"00"&'1'&'1'&"00"&"00"&"0000"&'0',
         "01"&"0100"&'1'&"00"&'0'&'0'&"01"&"10"&"0000"&'0');
Begin
--Microstore Rom
    test   <= MROM(addi)(19 downto 18);
    natt   <= MROM(addi)(17 downto 14);
    EnA    <= MROM(addi)(13);
    EnC    <= MROM(addi)(12 downto 11);
    EnN    <= MROM(addi)(10);
    EnL    <= MROM(addi)(9);
    SelMux <= MROM(addi)(8 downto 7);
    SelAlu <= MROM(addi)(6 downto 5);
    Kval   <= MROM(addi)(4 downto 1);
    Wr     <= MROM(addi)(0);
    dx     <= CONV_INTEGER(natt);
--Address Counter
Process(Reset,Clock)
    begin
        if reset = '1' then
            addi <= 0;
        elsif Clock'event and Clock ='1' then
            addi <= addi +1;
            if test = "01" then
                addi <= dx;                                                 --always branch (next value in natt)
            elsif test ="10" then
                if cf = '1' then addi <= dx; --branch if c flag is high (next value in natt)
                end if;
            elsif test ="11" then
                if zf = '1' then addi <= dx; --branch if z flag is high (next value in natt)
                end if;
            end if;
        end if;
end process;
--RegA enable and load
    begin
        if reset = '1' then
            RegA <= "0000";
        elsif Clock'event and Clock = '1' then
            if EnA = '1' then
                RegA <= F;
            end if;
        end if;
End Process;
--RegC endable and load !!RegC represents RegD!!
    begin
        if reset = '1' then
            RegC <= "0000";
            if EnC = "10" then
                RegC <= DY;
                                elsif EnC(0) <= '1' then
                                    RegC <= F;
                                else RegC <= RegC;
                                end if;
        end if;
End Process;
--RegN endable and load
    begin
        if reset = '1' then
            RegN <= "0000";
            if EnN = '1' then
                RegN <= F;
            end if;
        end if;
End Process;
X         <= RegN;
--RegL endable and load
    begin
        if reset = '1' then
            RegL <= "0000";
            if EnL = '1' then
               RegL <= F;
            end if;
        end if;
End Process;
--multiplexer
Y <= RegA when SelMux = "00" else
     RegC when SelMux = "01" else
     Kval when SelMux = "10" else
     Sw   when SelMux = "11";
--Alu
process(X,Y,SelAlu)
    variable temp : std_logic_vector (4 downto 0);
    variable muxout : std_logic_vector(3 downto 0);
    variable zf1 : std_logic;
    begin
        temp := "00000";
        zf1  := '0';
        muxout := "0000";
        cf <= '0';
        case SelAlu is
            when "00" => temp := ('0' & X) + ('0' & Y); --addition
                         muxout := temp (3 downto 0);
                         cf <= temp(4);
            when "01" => temp := ('0' & X) - ('0' & Y); --subtraction
                         cf <= temp(4);
            when "10" => muxout := Y;                   --F = Y
            when "11" => muxout := X and Y;             --bitwise AND
                                when others => muxout := x;
        end case;
        for i in 0 to 3 loop                            --z flag check
            zf1 := muxout(i) or zf1;
        end loop;
        f  <= muxout;
        zf <= not zf1;
end process;
-- assign output values
LED <= RegL;
--convert integer to state address
ADDX <= conv_std_logic_vector(addi,4);
end Behavioral;
此帖出自FPGA/CPLD论坛
--ClkWork --ClockDiv.vhd --boyuan chen --11.16.14
--2Hz Clock
library IEEE;
entity ClockDiv is
         Generic (NN :integer :=12500000 );
    Port ( clkin,clr : in  STD_LOGIC;
end ClockDiv;
architecture Behavioral of ClockDiv is
        signal cnt : integer range 0 to NN-1;
        signal clk : std_logic :='1';
begin
        process(clkin,clr)
                begin
                        if clr='1' then
                                cnt<=0; clk<='1';
                        elsif clkin'event and clkin='1' then
                                if cnt =NN-1 then
                                        cnt<=0; clk<= not clk;
                                else
                                        cnt<=cnt+1;
                                end if;
                        end if;
        end process;
        clkout <= clk;
end Behavioral;
此帖出自FPGA/CPLD论坛
当我跑behavioral simulation 的时候结果正常
然而当我跑post-route simulation的时候结果就出不来了
对了我用的是ise 14.7
此帖出自FPGA/CPLD论坛
求大神啊求大神
此帖出自FPGA/CPLD论坛
