I2C: ready
DRAM: 256 MiB
WARNING: Caches not enabled
NAND: 256 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
*** Warning - bad CRC, using default environment
Net: not set. Validating first E-fuse MAC
cpsw
Hit any key to stop autoboot: 0
mmc0 is current device
SD/MMC found on device 0
reading uEnv.txt
214 bytes read in 4 ms (51.8 KiB/s)
Loaded environment from uEnv.txt
Importing environment from mmc ...
Running uenvcmd ...
reading uImage
4173768 bytes read in 464 ms (8.6 MiB/s)
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-3.2.0-00244-gcf99001-dirty
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4173704 Bytes = 4 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Linux version 3.2.0-00244-gcf99001-dirty (root@xlj-virtual-machine) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 Mon Nov 24 11:54:26 CST 2014
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: am335xevm
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM335X ES1.0 (sgx neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
[ 0.000000] Kernel command line: console=ttyO0,115200n8 androidboot.console=ttyO0 mem=256M root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait init=/init ip=off
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 256MB = 256MB total
[ 0.000000] Memory: 250008k/250008k available, 12136k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0787000 (7676 kB)
[ 0.000000] .init : 0xc0787000 - 0xc07dc000 ( 340 kB)
[ 0.000000] .data : 0xc07dc000 - 0xc08458f0 ( 423 kB)
[ 0.000000] .bss : 0xc0845914 - 0xc099d650 (1376 kB)
[ 0.000000] NR_IRQS:396
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[ 0.000000] omap_dm_timer_switch_src: Switching to HW default clocksource(sys_clkin_ck) for timer1, this may impact timekeeping in low power state
[ 0.000000] OMAP clocksource: GPTIMER1 at 24000000 Hz
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000218] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144)
[ 0.117106] pid_max: default: 32768 minimum: 301
[ 0.117245] Security Framework initialized
[ 0.117318] Mount-cache hash table entries: 512
[ 0.117753] CPU: Testing write buffer coherency: ok
[ 0.117821] ftrace: allocating 22040 entries in 65 pages
[ 0.186936] omap_hwmod: pruss: failed to hardreset
[ 0.187798] print_constraints: dummy:
[ 0.188025] NET: Registered protocol family 16
[ 0.189178] OMAP GPIO hardware version 0.1
[ 0.190279] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.191444] omap_i2c.1: alias fck already exists
[ 0.191969] omap2_mcspi.1: alias fck already exists
[ 0.192083] omap2_mcspi.2: alias fck already exists
[ 0.192231] edma.0: alias fck already exists
[ 0.192250] edma.0: alias fck already exists
[ 0.192268] edma.0: alias fck already exists
[ 0.202691] bio: create slab at 0
[ 0.203718] SCSI subsystem initialized
[ 0.204577] usbcore: registered new interface driver usbfs
[ 0.204695] usbcore: registered new interface driver hub
[ 0.204834] usbcore: registered new device driver usb
[ 0.205153] registerd cppi-dma Intr @ IRQ 17
[ 0.205166] Cppi41 Init Done Qmgr-base(d087a000) dma-base(d0878000)
[ 0.205176] Cppi41 Init Done
[ 0.205203] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[ 0.205356] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[ 0.205830] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[ 0.207118] tps65910 1-002d: JTAGREVNUM 0x0
[ 0.209313] print_constraints: VRTC:
[ 0.210664] print_constraints: VIO: at 1800 mV
[ 0.212880] print_constraints: VDD1: 600 <--> 1500 mV at 1137 mV normal
[ 0.215078] print_constraints: VDD2: 600 <--> 1500 mV at 1137 mV normal
[ 0.215990] print_constraints: VDD3: 5000 mV
[ 0.217312] print_constraints: VDIG1: at 1800 mV
[ 0.218657] print_constraints: VDIG2: at 1800 mV
[ 0.219980] print_constraints: VPLL: at 1800 mV
[ 0.221309] print_constraints: VDAC: at 1800 mV
[ 0.222640] print_constraints: VAUX1: at 1800 mV
[ 0.223987] print_constraints: VAUX2: at 3300 mV
[ 0.225316] print_constraints: VAUX33: at 3300 mV
[ 0.226663] print_constraints: VMMC: at 3300 mV
[ 0.226956] tps65910 1-002d: No interrupt support, no core IRQ
[ 0.227564] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.228179] Bluetooth: Core ver 2.16
[ 0.228247] NET: Registered protocol family 31
[ 0.228258] Bluetooth: HCI device and connection manager initialized
[ 0.228273] Bluetooth: HCI socket layer initialized
[ 0.228284] Bluetooth: L2CAP socket layer initialized
[ 0.228323] Bluetooth: SCO socket layer initialized
[ 0.228526] Switching to clocksource gp timer
[ 0.247166] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 0.247377] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[ 0.247571] MUSB0 controller\'s USBSS revision = 4ea20800
[ 0.248469] musb-hdrc musb-hdrc.0: USB OTG mode controller at d083c000 using DMA, IRQ 18
[ 0.248807] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[ 0.248966] MUSB1 controller\'s USBSS revision = 4ea20800
[ 0.249441] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 0.249541] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 0.249679] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.249695] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.249709] usb usb1: Product: MUSB HDRC host driver
[ 0.249720] usb usb1: Manufacturer: Linux 3.2.0-00244-gcf99001-dirty musb-hcd
[ 0.249732] usb usb1: SerialNumber: musb-hdrc.1
[ 0.250257] hub 1-0:1.0: USB hub found
[ 0.250286] hub 1-0:1.0: 1 port detected
[ 0.250736] musb-hdrc musb-hdrc.1: USB Host mode controller at d083e800 using DMA, IRQ 19
[ 0.251113] NET: Registered protocol family 2
[ 0.251321] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.251718] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.251875] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.251970] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.251983] TCP reno registered
[ 0.251995] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.252019] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.252227] NET: Registered protocol family 1
[ 0.252530] RPC: Registered named UNIX socket transport module.
[ 0.252544] RPC: Registered udp transport module.
[ 0.252553] RPC: Registered tcp transport module.
[ 0.252562] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.252819] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.370169] ashmem: initialized
[ 0.370443] VFS: Disk quotas dquot_6.5.2
[ 0.370506] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.371387] fuse init (API version 7.17)
[ 0.371621] msgmni has been set to 488
[ 0.372686] io scheduler noop registered
[ 0.372699] io scheduler deadline registered
[ 0.372772] io scheduler cfq registered (default)
[ 0.373366] Could not set LED4 to fully on
[ 0.374659] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[ 1.071287] console [ttyO0] enabled
[ 1.075441] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[ 1.083152] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[ 1.090820] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[ 1.098467] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[ 1.106139] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[ 1.113978] [drm] Initialized drm 1.1.0 20060810
[ 1.124882] brd: module loaded
[ 1.131256] loop: module loaded
[ 1.134719] i2c-core: driver [tsl2550] using legacy suspend method
[ 1.141216] i2c-core: driver [tsl2550] using legacy resume method
[ 1.147636] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.208568] No daughter card found on AM335x EVM
[ 1.213432] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.278565] The board is a AM335x Starter Kit.
[ 1.283810] omap_hsmmc.0: alias fck already exists
[ 1.289120] omap_hsmmc.1: alias fck already exists
[ 1.294973] da8xx_lcdc.0: alias fck already exists
[ 1.300302] da8xx_lcdc da8xx_lcdc.0: GLCD: Found NHD-4.3-ATXI#-T-1 panel
[ 1.316575] davinci-mcasp.1: alias fck already exists
[ 1.322187] am335xevm: bt init
[ 1.327921] (stk) :sysfs entries created
[ 1.332081] (stk) : debugfs entries created
[ 1.336407] (hci_tty): inside hci_tty_init
[ 1.341064] (hci_tty): allocated 251, 0
[ 1.345124] _regulator_get: 1-0018 supply Vdd not found, using dummy regulator
[ 1.352746] _regulator_get: 1-0018 supply Vdd_IO not found, using dummy regulator
[ 1.378613] usb 1-1: new low-speed USB device number 2 using musb-hdrc
[ 1.385623] lis3lv02d: unknown sensor type 0x87
[ 1.390481] lis3lv02d_i2c: probe of 1-0018 failed with error -22
[ 1.397342] NFC Driver for TI WiLink
[ 1.401850] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.408958] omap2-nand driver initializing
[ 1.413287] OneNAND driver initializing
[ 1.417819] CAN device driver interface
[ 1.421851] CAN bus driver for Bosch D_CAN controller 1.0
[ 1.468590] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[ 1.475045] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
[ 1.482384] davinci_mdio.0: probed
[ 1.485937] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
[ 1.493374] PPP generic driver version 2.4.2
[ 1.498006] PPP BSD Compression module registered
[ 1.502933] PPP Deflate Compression module registered
[ 1.508319] usbcore: registered new interface driver cdc_ether
[ 1.514485] usbcore: registered new interface driver cdc_eem
[ 1.520459] usbcore: registered new interface driver dm9601
[ 1.526317] usbcore: registered new interface driver cdc_subset
[ 1.532552] cdc_ncm: 04-Aug-2011
[ 1.535969] usbcore: registered new interface driver cdc_ncm
[ 1.541966] usbcore: registered new interface driver cdc_acm
[ 1.547870] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.556230] Initializing USB Mass Storage driver...
[ 1.561445] usbcore: registered new interface driver usb-storage
[ 1.567710] USB Mass Storage support registered.
[ 1.572686] usbcore: registered new interface driver usbserial
[ 1.578838] USB Serial support registered for generic
[ 1.638591] usb 1-1: device descriptor read/64, error -71
[ 1.868571] usb 1-1: device descriptor read/64, error -71
[ 2.098710] usb 1-1: new low-speed USB device number 3 using musb-hdrc
[ 2.218571] usb 1-1: device descriptor read/64, error -71
[ 2.448570] usb 1-1: device descriptor read/64, error -71
[ 2.678572] usb 1-1: new low-speed USB device number 4 using musb-hdrc
[ 3.098568] usb 1-1: device not accepting address 4, error -71
[ 3.218571] usb 1-1: new low-speed USB device number 5 using musb-hdrc
[ 3.638566] usb 1-1: device not accepting address 5, error -71
[ 3.644661] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 3.651150] usbcore: registered new interface driver usbserial_generic
[ 3.657957] usbserial: USB Serial Driver core
[ 3.662565] USB Serial support registered for GSM modem (1-port)
[ 3.669002] usbcore: registered new interface driver option
[ 3.674814] option: v0.7.2:USB Driver for GSM modems
[ 3.681706] gadget: Mass Storage Function, version: 2009/09/11
[ 3.687899] gadget: Number of LUNs=1
[ 3.691751] lun0: LUN: removable file: (no medium)
[ 3.697086] gadget: android_usb ready
[ 3.701033] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 3.706644] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[ 3.714480] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.721582] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.729129] usb usb2: Product: MUSB HDRC host driver
[ 3.734306] usb usb2: Manufacturer: Linux 3.2.0-00244-gcf99001-dirty musb-hcd
[ 3.741760] usb usb2: SerialNumber: musb-hdrc.0
[ 3.746993] hub 2-0:1.0: USB hub found
[ 3.750953] hub 2-0:1.0: 1 port detected
[ 3.755725] mousedev: PS/2 mouse device common for all mice
[ 3.762304] input: ti-tsc as /devices/platform/omap/ti_tscadc/tsc/input/input0
[ 3.770958] using rtc device, am33xx-rtc, for alarms
[ 3.776016] omap_rtc am33xx-rtc: rtc core: registered am33xx-rtc as rtc0
[ 3.783296] i2c /dev entries driver
[ 3.787141] Linux video capture interface: v2.00
[ 3.792302] usbcore: registered new interface driver uvcvideo
[ 3.798303] USB Video Class driver (1.1.1)
[ 3.804514] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 3.811069] device-mapper: uevent: version 1.0.3
[ 3.816080] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[ 3.824919] Bluetooth: HCI UART driver ver 2.2
[ 3.829570] Bluetooth: HCI H4 protocol initialized
[ 3.834564] Bluetooth: HCILL protocol initialized
[ 3.839480] Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0
[ 3.848502] cpuidle: using governor ladder
[ 3.852978] cpuidle: using governor menu
[ 3.966357] usbcore: registered new interface driver usbhid
[ 3.972223] usbhid: USB HID core driver
[ 3.976712] logger: created 256K log \'log_main\'
[ 3.981571] logger: created 256K log \'log_events\'
[ 3.986566] logger: created 256K log \'log_radio\'
[ 3.991508] logger: created 256K log \'log_system\'
[ 3.996987] tiadc tiadc: attached adc driver
[ 4.001880] usbcore: registered new interface driver snd-usb-audio
[ 4.009556] _regulator_get: 1-001b supply IOVDD not found, using dummy regulator
[ 4.017346] _regulator_get: 1-001b supply DVDD not found, using dummy regulator
[ 4.025069] _regulator_get: 1-001b supply AVDD not found, using dummy regulator
[ 4.032757] _regulator_get: 1-001b supply DRVDD not found, using dummy regulator
[ 4.043755] asoc: tlv320aic3x-hifi <-> davinci-mcasp.1 mapping ok
[ 4.050979] ALSA device list:
[ 4.054077] #0: AM335X EVM
[ 4.057076] oprofile: hardware counters not available
[ 4.062380] oprofile: using timer interrupt.
[ 4.067018] Netfilter messages via NETLINK v0.30.
[ 4.072076] nf_conntrack version 0.5.0 (3906 buckets, 15624 max)
[ 4.078702] ctnetlink v0.93: registering with nfnetlink.
[ 4.084310] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 4.091594] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 4.098034] xt_time: kernel timezone is -0000
[ 4.102843] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.108628] arp_tables: (C) 2002 David S. Miller
[ 4.113519] TCP cubic registered
[ 4.117062] NET: Registered protocol family 10
[ 4.122545] Mobile IPv6
[ 4.125137] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.131004] IPv6 over IPv4 tunneling driver
[ 4.136001] NET: Registered protocol family 17
[ 4.140713] NET: Registered protocol family 15
[ 4.145347] can: controller area network core (rev 20090105 abi 8)
[ 4.151930] NET: Registered protocol family 29
[ 4.156565] can: raw protocol (rev 20090105)
[ 4.161033] can: broadcast manager protocol (rev 20090105 t)
[ 4.167403] Bluetooth: RFCOMM TTY layer initialized
[ 4.172541] Bluetooth: RFCOMM socket layer initialized
[ 4.177902] Bluetooth: RFCOMM ver 1.11
[ 4.181828] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.187370] Bluetooth: BNEP filters: protocol multicast
[ 4.192832] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.199198] Registering the dns_resolver key type
[ 4.204180] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 4.212202] ThumbEE CPU extension supported.
[ 4.216720] mux: Failed to setup hwmod io irq -22
[ 4.222372] Power Management for AM33XX family
[ 4.227234] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[ 4.233935] Copied the M3 firmware to UMEM
[ 4.238296] Cortex M3 Firmware Version = 0x181
[ 4.247561] clock: disabling unused clocks to save power
[ 4.254741] Detected MACID=0:18:30:f2:9c:60
[ 4.261520] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 4.268951] omap_rtc am33xx-rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 4.278391] Waiting for root device /dev/mmcblk0p2...
[ 4.319646] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 4.330173] mmc0: new high speed SDHC card at address 1234
[ 4.336410] mmcblk0: mmc0:1234 SA04G 3.63 GiB
[ 4.343237] mmcblk0: p1 p2
[ 4.474711] EXT4-fs (mmcblk0p2): recovery complete
[ 4.483622] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 4.492153] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 4.498931] Freeing init memory: 340K
[ 4.958587] (stk) :line disc installation timed out
[ 7.078562] (stk) :line disc installation timed out
[ 9.029751] init: Timed out waiting for /dev/.coldboot_done
[ 9.041324] init: Unable to open persistent property directory /data/property errno: 2
[ 9.198571] (stk) :line disc installation timed out
[ 11.318561] (stk) :line disc installation timed out
[ 13.438562] (stk) :line disc installation timed out
[ 15.558568] (stk) :line disc installation timed out
[ 16.558578] Bluetooth: st_register failed -22
