2381|4
2549
【TI首届低功耗设计大赛】卡在5969的AD上了,求解啊 [复制链接]
写了一个5969双通道的AD程序,A2和A3通道轮流采样,但采集到的A2通道是错误的,A3通道没数据,程序如下:
void ADC12_init()
   ADC12CTL0 = ADC12SHT0_5 | ADC12ON;   //设置采样时间,开启中断
   ADC12CTL1 |= ADC12SHP;
   ADC12CTL2 |= ADC12RES_2;  //12位分辨率
   while(REFCTL0 & REFGENBUSY);  //开启参考电压,2.5v
   REFCTL0 |= REFVSEL_2 | REFON;
void start_ADC12()
  //A2通道
  ADC12IER0 |= ADC12IE0;  //开中断
  ADC12MCTL0 |= ADC12INCH_2| ADC12VRSEL_2;  //选择通道2,参考电压2.5v
  ADC12CTL0 |= ADC12ENC | ADC12SC;  //转换使能,开始转换
  while(ADC12CTL1&ADC12BUSY!=0);//判断是否转换完毕
  ADC12CTL0 &= ~(ADC12ENC | ADC12SC);  //关转换使能,停止转换
  ADC12IER0 &= ~ADC12IE0;   //关中断
  //A3通道
  ADC12IER0 |= ADC12IE1;
  ADC12MCTL1 |= ADC12INCH_3| ADC12VRSEL_2; ;
  ADC12IER0 &= ~ADC12IE1;
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector = ADC12_VECTOR
__interrupt void ADC12_ISR(void)
#elif defined(__GNUC__)
void __attribute__ ((interrupt(ADC12_VECTOR))) ADC12_ISR (void)
#else
#error Compiler not supported!
#endif
  switch(__even_in_range(ADC12IV, ADC12IV_ADC12RDYIFG))
    case ADC12IV_NONE:        break;        // Vector  0:  No interrupt
    case ADC12IV_ADC12OVIFG:  break;        // Vector  2:  ADC12MEMx Overflow
    case ADC12IV_ADC12TOVIFG: break;        // Vector  4:  Conversion time overflow
    case ADC12IV_ADC12HIIFG:  break;        // Vector  6:  ADC12BHI
    case ADC12IV_ADC12LOIFG:  break;        // Vector  8:  ADC12BLO
    case ADC12IV_ADC12INIFG:  break;        // Vector 10:  ADC12BIN
    case ADC12IV_ADC12IFG0:                 // Vector 12:  ADC12MEM0 Interrupt
     result= ADC12MEM0;
          break;
    case ADC12IV_ADC12IFG1:
     result1= ADC12MEM0;
         __bic_SR_register_on_exit(LPM0_bits);
              break;
    case ADC12IV_ADC12IFG2:   break;        // Vector 16:  ADC12MEM2
    case ADC12IV_ADC12IFG3:   break;        // Vector 18:  ADC12MEM3
    case ADC12IV_ADC12IFG4:   break;        // Vector 20:  ADC12MEM4
    case ADC12IV_ADC12IFG5:   break;        // Vector 22:  ADC12MEM5
    case ADC12IV_ADC12IFG6:   break;        // Vector 24:  ADC12MEM6
    case ADC12IV_ADC12IFG7:   break;        // Vector 26:  ADC12MEM7
    case ADC12IV_ADC12IFG8:   break;        // Vector 28:  ADC12MEM8
    case ADC12IV_ADC12IFG9:   break;        // Vector 30:  ADC12MEM9
    case ADC12IV_ADC12IFG10:  break;        // Vector 32:  ADC12MEM10
    case ADC12IV_ADC12IFG11:  break;        // Vector 34:  ADC12MEM11
    case ADC12IV_ADC12IFG12:  break;        // Vector 36:  ADC12MEM12
    case ADC12IV_ADC12IFG13:  break;        // Vector 38:  ADC12MEM13
    case ADC12IV_ADC12IFG14:  break;        // Vector 40:  ADC12MEM14
    case ADC12IV_ADC12IFG15:  break;        // Vector 42:  ADC12MEM15
    case ADC12IV_ADC12IFG16:  break;        // Vector 44:  ADC12MEM16
    case ADC12IV_ADC12IFG17:  break;        // Vector 46:  ADC12MEM17
    case ADC12IV_ADC12IFG18:  break;        // Vector 48:  ADC12MEM18
    case ADC12IV_ADC12IFG19:  break;        // Vector 50:  ADC12MEM19
    case ADC12IV_ADC12IFG20:  break;        // Vector 52:  ADC12MEM20
    case ADC12IV_ADC12IFG21:  break;        // Vector 54:  ADC12MEM21
    case ADC12IV_ADC12IFG22:  break;        // Vector 56:  ADC12MEM22
    case ADC12IV_ADC12IFG23:  break;        // Vector 58:  ADC12MEM23
    case ADC12IV_ADC12IFG24:  break;        // Vector 60:  ADC12MEM24
    case ADC12IV_ADC12IFG25:  break;        // Vector 62:  ADC12MEM25
    case ADC12IV_ADC12IFG26:  break;        // Vector 64:  ADC12MEM26
    case ADC12IV_ADC12IFG27:  break;        // Vector 66:  ADC12MEM27
    case ADC12IV_ADC12IFG28:  break;        // Vector 68:  ADC12MEM28
    case ADC12IV_ADC12IFG29:  break;        // Vector 70:  ADC12MEM29
    case ADC12IV_ADC12IFG30:  break;        // Vector 72:  ADC12MEM30
    case ADC12IV_ADC12IFG31:  break;        // Vector 74:  ADC12MEM31
    case ADC12IV_ADC12RDYIFG: break;        // Vector 76:  ADC12RDY
    default: break;
2549
问题已经解决,忘了说了,谢谢@qiushenghua 的热心帮助
2549
问题找到了,ADC12MCTL0 |= ADC12INCH_2| ADC12VRSEL_2;  //选择通道2,参考电压2.5v
这一句开启的实际不是2.5V的参考电压,而是外部输入参考电压
2549
还有这一句 :    ADC12MCTL1 |= ADC12INCH_3| ADC12VRSEL_2; 应该是ADC12MCTL0
2549
解决问题不能光检查思路,还得检查一些基本错误 啊
