2415|2
msp430 的DCO怎么校正啊 [复制链接]
DCO怎么校正啊,网上找了半天也没有
本帖最后由 Study_Stellaris 于 2014-11-19 13:28 编辑 有一个官方的校准程序,我曾经也遇到过这个问题。这个是 G 系列的,你参考一下 /****************************************************************************** //  MSP430G2xx3 Demo - Basic Clock, Output Buffered clocks with preloaded DCO //                     calibration constants for BCSCTL1 and DCOCTL. //   //  Description: Buffer ACLK on P2.0, default SMCLK(DCO) on P1.4 and MCLK/10 on //  P1.1. DCO is software selectable to 1, 8, 12, or 16Mhz using calibration //  contstants in INFOA. // //  ACLK = LFXT1 = 32768, MCLK = SMCLK = Selectable at 1, 8, 12 or 16Mhz //  //* External watch crystal installed on XIN XOUT is required for ACLK *//        // //               MSP430G2xx3 //             ----------------- //         /|\|              XIN|- //          | |                 | 32kHz //          --|RST          XOUT|- //            |                 | //            |       P1.4/SMCLK|-->SMCLK = Default DCO //            |             P1.1|-->MCLK/10 = DCO/10 //            |        P1.0/ACLK|-->ACLK = 32kHz // //  D. Dang //  Texas Instruments Inc. //  December 2010 //   Built with IAR Embedded Workbench Version: 3.42A //****************************************************************************** #include  <msp430g2553.h> void main(void) {   WDTCTL = WDTPW +WDTHOLD;                  // Stop Watchdog Timer   if (CALBC1_1MHZ ==0xFF || CALDCO_1MHZ == 0xFF)                                       {       while(1);                               // If calibration constants erased                                             // do not load, trap CPU!!   } //1Mhz   BCSCTL1 = CALBC1_1MHZ;                    // Set range   DCOCTL = CALDCO_1MHZ;                     // Set DCO step + modulation */ /* //8Mhz   BCSCTL1 = CALBC1_8MHZ;                    // Set range   DCOCTL = CALDCO_8MHZ;                     // Set DCO step + modulation */ /* //12Mhz   BCSCTL1 = CALBC1_12MHZ;                   // Set range   DCOCTL = CALDCO_12MHZ;                    // Set DCO step + modulation*/ /* //16Mhz   BCSCTL1 = CALBC1_16MHZ;                   // Set range   DCOCTL = CALDCO_16MHZ;                    // Set DCO step + modulation*/   P1DIR |= 0x13;                            // P1.0,1 and P1.4 outputs   P1SEL |= 0x11;                            // P1.0,4 ACLK, SMCLK output   while(1)   {     P1OUT |= 0x02;                                // P1.1 = 1     P1OUT &= ~0x02;                         // P1.1 = 0   } }复制代码   详情 回复 发表于 2014-11-19 13:25
578
一般官方在出厂的时候就设置了一些校准值,分别有1M,8M,12M和16M,如果这些特定频率不是你想要的,你可以先将DCO作为MCLK的时钟源,然后设置(P1.1还是P1.2,忘记了)输入MCLK,外部用示波器或者其他测量设备进行测量,再通过逐步调节DCO相关的寄存器以达到你想要的频率
个人签名刻苦学习,共同进步
1803
  1. /******************************************************************************
  2. //  MSP430G2xx3 Demo - Basic Clock, Output Buffered clocks with preloaded DCO
  3. //                     calibration constants for BCSCTL1 and DCOCTL.
  4. //
  5. //  Description: Buffer ACLK on P2.0, default SMCLK(DCO) on P1.4 and MCLK/10 on
  6. //  P1.1. DCO is software selectable to 1, 8, 12, or 16Mhz using calibration
  7. //  contstants in INFOA.
  8. //
  9. //  ACLK = LFXT1 = 32768, MCLK = SMCLK = Selectable at 1, 8, 12 or 16Mhz
  10. //  //* External watch crystal installed on XIN XOUT is required for ACLK *//
  11. //
  12. //               MSP430G2xx3
  13. //             -----------------
  14. //         /|\|              XIN|-
  15. //          | |                 | 32kHz
  16. //          --|RST          XOUT|-
  17. //            |                 |
  18. //            |       P1.4/SMCLK|-->SMCLK = Default DCO
  19. //            |             P1.1|-->MCLK/10 = DCO/10
  20. //            |        P1.0/ACLK|-->ACLK = 32kHz
  21. //
  22. //  D. Dang
  23. //  Texas Instruments Inc.
  24. //  December 2010
  25. //   Built with IAR Embedded Workbench Version: 3.42A
  26. //******************************************************************************
  27. #include  <msp430g2553.h>
  28. void main(void)
  29. {
  30.   WDTCTL = WDTPW +WDTHOLD;                  // Stop Watchdog Timer
  31.   if (CALBC1_1MHZ ==0xFF || CALDCO_1MHZ == 0xFF)
  32.   {
  33.     while(1);                               // If calibration constants erased
  34.                                             // do not load, trap CPU!!
  35.   }
  36. //1Mhz
  37.   BCSCTL1 = CALBC1_1MHZ;                    // Set range
  38.   DCOCTL = CALDCO_1MHZ;                     // Set DCO step + modulation */
  39. /* //8Mhz
  40.   BCSCTL1 = CALBC1_8MHZ;                    // Set range
  41.   DCOCTL = CALDCO_8MHZ;                     // Set DCO step + modulation */
  42. /* //12Mhz
  43.   BCSCTL1 = CALBC1_12MHZ;                   // Set range
  44.   DCOCTL = CALDCO_12MHZ;                    // Set DCO step + modulation*/
  45. /* //16Mhz
  46.   BCSCTL1 = CALBC1_16MHZ;                   // Set range
  47.   DCOCTL = CALDCO_16MHZ;                    // Set DCO step + modulation*/
  48.   P1DIR |= 0x13;                            // P1.0,1 and P1.4 outputs
  49.   P1SEL |= 0x11;                            // P1.0,4 ACLK, SMCLK output
  50.   while(1)
  51.   {
  52.     P1OUT |= 0x02;                                // P1.1 = 1
  53.     P1OUT &= ~0x02;                         // P1.1 = 0
  54.   }
  55. }
复制代码
