2043|0
LPC24xx系列ARM7 系统时钟配置代码(转自微控制器硬件及驱动网) [复制链接]
NXP公司 LPC246x系列ARM7功能强大,最高主频可达72MHz。主频需要通过锁相环倍频产生,因此配置比较麻烦,不像51等单片机简单明了。配置主频主要就是要根据硬件晶振频率和你希望得到的系统主频,计算出M, N, 分频系数等几个重要参数。
该代码为LPC246x系统时钟PLL配置代码。范例代码给出了硬件配置为晶振24MHz,配置后系统主频为最高频率72MHz的配置方法。更改M,N和分频系数后可以得到更多的系统主频。
M,N和分频系数如何计算,芯片用户手册上有介绍,但比较复杂。我为此制作了代码生成器,自动计算参数并生成配置代码。只要在主函数开始初始化时调用void ConfigurePLL (void)就可以完成配置,非常方便。
使用代码生成器可以访问 http://www.hdmcu.com/codegenerator_html/webcg-6.html
//使用需#include “LPC246x.h“
//晶振频率 24MHHz
//预设主频 72MHz
    unsigned long MValue=0, NValue=0;
    //关键参数值
    unsigned short PLL_M=6, PLL_N=1;
    unsigned char  PLL_FcclkDiv=0;
    unsigned char  PLL_FusbDiv=6;
    if(PLL_M==0)        //M=0 is Caculate error, system can-y-o-u-g-a-n-g-‘t work
      while(1);
    //no Caculate error
    if ( PLLSTAT & (1 << 25) )
        PLLCON = 1;         /* Enable PLL, disconnected */
        PLLFEED = 0xaa;
        PLLFEED = 0x55;
    PLLCON = 0;         /* Disable PLL, disconnected */
    PLLFEED = 0xaa;
    PLLFEED = 0x55;
    SCS |= 0x20;         /* Enable main OSC */
    while( !(SCS & 0x40) );        /* Wait until main OSC is usable */
    CLKSRCSEL = 0x1;         /* select main OSC, 12MHz, as the PLL clock source */
    PLLCFG = ((U32)PLL_M-1) | (((U32)PLL_N-1)<< 16);
    PLLFEED = 0xaa;
    PLLFEED = 0x55;
    PLLFEED = 0xaa;
    PLLFEED = 0x55;
    CCLKCFG = (PLL_FcclkDiv-1);        /* Set clock divider */
    //配置USB_48M
    PCONP |= 0x80000000;
    USBCLKCFG = PLL_FusbDiv;         /* usbclk = 48 MHz */
    while ( ((PLLSTAT & (1 << 26)) == 0) );        /* Check lock bit status */
    MValue = PLLSTAT & 0x00007FFF;
    NValue = (PLLSTAT & 0x00FF0000) >> 16;
    while (((MValue+1) != PLLinfo_M) && ( (NValue+1) != PLLinfo_N) );
    PLLCON = 3;         /* enable and connect */
    PLLFEED = 0xaa;
    PLLFEED = 0x55;
    while ( ((PLLSTAT & (1 << 25)) == 0) );        /* Check connect bit status */
    return;
此帖出自单片机论坛
