2416|1
spi同步模式 [复制链接]
#include
unsigned char MST_Data, SLV_Data;
int main(void)
  volatile unsigned int i;
  WDTCTL = WDTPW + WDTHOLD;                 // Stop watchdog timer
  P1OUT = 0x00;                             // P1 setup for LED & reset output
  P1DIR |= BIT0 + BIT5;                     //
  P1SEL = BIT1 + BIT2 + BIT4;
  P1SEL2 = BIT1 + BIT2 + BIT4;
  UCA0CTL0 |= UCCKPL + UCMSB + UCMST + UCSYNC;  // 3-pin, 8-bit SPI master
  UCA0CTL1 |= UCSSEL_2;                     // SMCLK
  UCA0BR0 |= 0x02;                          // /2
  UCA0BR1 = 0;                              //
  UCA0MCTL = 0;                             // No modulation
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  IE2 |= UCA0RXIE;                          // Enable USCI0 RX interrupt
  P1OUT &= ~BIT5;                           // Now with SPI signals initialized,
  P1OUT |= BIT5;                            // reset slave
  __delay_cycles(75);                 // Wait for slave to initialize
  MST_Data = 0x01;                          // Initialize data values
  SLV_Data = 0x00;
  UCA0TXBUF = MST_Data;                     // Transmit first character
  __bis_SR_register(LPM0_bits + GIE);       // CPU off, enable interrupts
// Test for valid RX and TX character
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCIA0RX_ISR(void)
  while (!(IFG2 & UCA0TXIFG));              // USCI_A0 TX buffer ready?
  if (UCA0RXBUF == SLV_Data)           // Test for correct character RX'd
    P1OUT |= BIT0;                          // If correct, light LED
  else
    P1OUT &= ~BIT0;                         // If incorrect, clear LED
  MST_Data++;                               // Increment master value
  SLV_Data++;                               // Increment expected slave value
  UCA0TXBUF = MST_Data;                     // Send next value
  __delay_cycles(50);                     // Add time between transmissions to
这是一个TI的SPI通信例程,显然主机发送,从机接收并返回给主机,显然红色标记的那句不成立,为什么P1,.1还输出高电平
打错了,应该是为什么p1.0还输出高
