3244|1
182
关于TM4c123X的PWM输出 [复制链接]
TM4c123gh6pm只能输出两路pwm吗,如果配置才能输出四路pwm啊
#include #include #include "inc/hw_memmap.h" #include "inc/hw_types.h" #include "driverlib/sysctl.h" #include "driverlib/rom.h" #include "driverlib/gpio.h" #include "driverlib/pwm.h" #include "driverlib/fpu.h" #include "driverlib/pin_map.h" #define GPIO_PB6_M0PWM0         0x00011804 #define GPIO_PB7_M0PWM1         0x00011C04 #define GPIO_PB4_M0PWM2         0x00011004 #define GPIO_PB5_M0PWM3         0x00011404 void PWM_init(void) {         //PWM时钟配置:64分频         SysCtlPWMClockSet(SYSCTL_PWMDIV_64);         //使能PWM0模块         SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);         //使能PWM0模块         SysCtlPeripheralEnable(SYSCTL_PERIPH_PWM0);     //GPIO引脚配置         GPIOPinConfigure(GPIO_PB7_M0PWM1);         GPIOPinConfigure(GPIO_PB6_M0PWM0);         GPIOPinConfigure(GPIO_PB5_M0PWM3);         GPIOPinConfigure(GPIO_PB4_M0PWM2);         //配置引脚为PWM功能         GPIOPinTypePWM(GPIO_PORTB_BASE, GPIO_PIN_7);         GPIOPinTypePWM(GPIO_PORTB_BASE, GPIO_PIN_6);         GPIOPinTypePWM(GPIO_PORTB_BASE, GPIO_PIN_5);         GPIOPinTypePWM(GPIO_PORTB_BASE, GPIO_PIN_4);         //配置PWM发生器0和发生器1:加减计数不分频         PWMGenConfigure(PWM0_BASE, PWM_GEN_0,PWM_GEN_MODE_DOWN | PWM_GEN_MODE_NO_SYNC);         PWMGenConfigure(PWM0_BASE, PWM_GEN_1,PWM_GEN_MODE_DOWN | PWM_GEN_MODE_NO_SYNC);         //设置PWM发生器1的频率,时钟频率/pwm分频数/n,80M/64/3125=400hz         PWMGenPeriodSet(PWM0_BASE, PWM_GEN_0, 3125);         PWMGenPeriodSet(PWM0_BASE, PWM_GEN_1, 3125);         //设置PWM0/PWM1输出的脉冲宽度         PWMPulseWidthSet(PWM0_BASE, PWM_OUT_0, 1200);         PWMPulseWidthSet(PWM0_BASE, PWM_OUT_1, 1200);         PWMPulseWidthSet(PWM0_BASE, PWM_OUT_2, 1200);         PWMPulseWidthSet(PWM0_BASE, PWM_OUT_3, 1200);     //使能PWM发生器         PWMGenEnable(PWM0_BASE, PWM_GEN_0);         PWMGenEnable(PWM0_BASE, PWM_GEN_1);         //使能PWM0和PWM1的输出         PWMOutputState(PWM0_BASE, (PWM_OUT_0_BIT), true);         PWMOutputState(PWM0_BASE, (PWM_OUT_1_BIT), true);         PWMOutputState(PWM0_BASE, (PWM_OUT_2_BIT), true);         PWMOutputState(PWM0_BASE, (PWM_OUT_3_BIT), true); } void GPIOPin_init(void) {         SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);                //使能启动GPIOF         SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);                //使能启动GPIOD         SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);                //使能启动GPIOA         GPIOPinTypeGPIOInput(GPIO_PORTD_BASE,GPIO_PIN_6|GPIO_PIN_2);  //设置GPIOD_PIN2、6 为输入         GPIOPinTypeGPIOInput(GPIO_PORTA_BASE,0x3C);                                    //设置GPIOA_PIN2-7 为输入         GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE,GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3|GPIO_PIN_4);         GPIODirModeSet(GPIO_PORTD_BASE,GPIO_PIN_6|GPIO_PIN_2,GPIO_DIR_MODE_IN);         GPIODirModeSet(GPIO_PORTA_BASE,0x3C,GPIO_DIR_MODE_IN);         GPIOPadConfigSet(GPIO_PORTD_BASE,GPIO_PIN_6|GPIO_PIN_2,GPIO_STRENGTH_2MA,GPIO_PIN_TYPE_STD_WPU);//上拉         GPIOPadConfigSet(GPIO_PORTA_BASE,0x3C,GPIO_STRENGTH_2MA,GPIO_PIN_TYPE_STD_WPU); } void StartElCo(void) {         uint32_t h0=1250,h1=1250,h2=1250,h3=1250,i;         SysCtlDelay(48000000);//2s         for(i=0;i  详情 回复 发表于 2014-9-5 01:22
24
#include
#include
void PWM_init(void)
        //PWM时钟配置:64分频
        //使能PWM0模块
        //使能PWM0模块
    //GPIO引脚配置
        //配置引脚为PWM功能
    //使能PWM发生器
        //使能PWM0和PWM1的输出
        for(i=0;i<4;i++)
                SysCtlDelay(2400000); //100ms
                if(h0<1643)
                        h0+=110;
                        h1+=110;
                        h2+=110;
                        h3+=110;
                if(h0>=1643)
                        h0=1643;
                        h1=1643;
                        h2=1643;
                        h3=1643;
                PWMPulseWidthSet(PWM0_BASE, PWM_OUT_0, h0);
                PWMPulseWidthSet(PWM0_BASE, PWM_OUT_1, h1);
                PWMPulseWidthSet(PWM0_BASE, PWM_OUT_2, h2);
                PWMPulseWidthSet(PWM0_BASE, PWM_OUT_3, h3);
        //        SysCtlDelay(24000000); //1s
int main(void)
        //系统和时钟设置
        SysCtlClockSet(SYSCTL_SYSDIV_2_5|SYSCTL_USE_PLL|SYSCTL_XTAL_16MHZ|SYSCTL_OSC_MAIN);
        PWM_init();   //PWM中断
        StartElCo();  //启动电调
        while(1);
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
