2034|0
90
对比方案赛+LM5122AsynchronousBoost [复制链接]
WEBENCH设计的过程+LM5122Asynchronous BOOST Required:
Inputvoltage: 10 – 15V;
OutPutvoltage:35 ;
MaxOutputCurrent: 5Amp;
Ripple: ±5%;
Ambient Temp: 85
Step1:
Step2:
Step3:
Step4:Power Efficiency Compare
Webench Result
Actual Result
Step 5: the actual PCB Drawing
Step 6: Loop Analyzer
    The LM5122 is a multiphase capable synchronous boost controller intendedfor high-efficiency
synchronous boost regulatorapplications. The control method is based upon peak current mode control. Currentmode control provides inherent line feedforward, cycle-by-cycle currentlimiting and ease of loop compensation.
For Cost Pressure,we hereimplemented asynchronous boost topology power supply, where the rectifierMOSFET was replaced by a Schottky Diode. That means the power efficiency wentworse than the synchronous boost topology.
